Hi Pawel,
Looks pretty good. Now I wished I put put yellow strips on my interior canopy myself but I already scratch built and installed the helmet sight system (HSS) rails and cables on the interior side of the top canopy. The AH-1S(Mod) had a black interior so the yellow border would have really popped against the black interior. I'm doing canopy doors open to to match my 1/48 scale kit I just finished. I think I'll do the yellow strips on my 1/48 AH-1G though , I'm almost done with the cockpit and canopy pieces are primed and interior painted already so I probably get to that this weekend.
The vaccum form canopy looks good to. I've always wished kit manufactures would just inject the frame and make thin vaccum formed clear pieces instead of injecting one big thick piece, but thats wishful thinking, unless I made my own kits. :)
Oh, I was going to tell you, I confirmed what the serial number was of my AH-1S(Mod) cobra was. I was looking at some of my Army pictures for interior references for color and wear patterns and I had my magnifying headset on and low and behold the radio call sign placard was visable in a shadow on the instument panel on the left side. It was serial number 15641, built in 1967 and I searched google and found out was in the 7/17 calvary, C Troop, 1st Calvary division. Sure enough the two brothers I told you about S/N 15642 was also in the 7/17 Cav C Troop in Vietnam. I also googled another serial number 68-15139 I took at Fort Eustis Virgina training and it's one of the famous Cobras "Squatter Swatter", apparently there were two named that. Microscale makes decals for it but I can't find them on e-bay so I might just make them.
Sorry to chatter on, I was going to ask you about your vaccum form canopy and how you made it?
I also looked at the US Army Painting and Marking manual TM 55-1500-345-23 for the interior yellow strips on both doors for the AH-1 and the spec says they are 0.5 inches wide and the color is FS33538. It looks like a standard insignia yellow for color.
1/72 Scale= (0.007 inches/0.176 mm) wide.
1/48 Scale = (0.010 inches/0.026 mm) wide.
A couple quick notes with the Special Hobby G kit before you paint the exterior, remove and fill the pitot tube port on the upper left side of the rotor tower. The G model's pitot tube was on the nose and wasn't moved to the rotor tower until the TSU for the TOW missiles was mounted on the nose on all models after the G series. The G series also had 2 options for the landing light. If you use the clear nose tip landing light, get rid of and fill the landing light on the bottom behind the M28 turret and vice versa if you use a solid nose tip, then use the landing light on the bottom behind the turret.
Also early G models deployed in Vietnam did not have Environmental Control Units (ECS) installed. This cooled down the cockpit especially in the hot environments. I’m not sure when they switched over, and/or modified old cobras, however you can easily tell if its installed or not by if there is a circular vent on the left side panel right behind the pilots canopy. No vent, no ECU if you wanted to depict a early G model, especially one with the tail rotor on the left side.
Thanks,
Tom
