How I Build Dioramas(step-by-step)
    February 2004
Posted by JohnReid on Saturday, September 30, 2006 8:47 AM
Guide my hand in your work today.JWRR. My goal in life is to be as good a person as my dog already thinks I am. My Photoshop: http://s6.photobucket.com/albums/y250/JohnReid/
    February 2004
Posted by JohnReid on Saturday, September 30, 2006 9:14 AM
    February 2004
Posted by JohnReid on Saturday, September 30, 2006 10:02 AM
Modifying Scratch Figs
These are the 1/16th(120mm) figures and some of the heads that I received yesterday.The figs look great but require a little flash removal .The heads are outstanding!I purchased these from the "The Lost Battalion Miniatures" company.
I have also recently purchased a Eric Hartmann figure from "Legends and Lore" which I plan to modify into a barnstormer of the 20's for the "Memories of Flight School "diorama.I am planning to radically modify the Hartmann figure using the manniquin for positioning reference and heads to alter the facial expression.
This will be a first step down the road to sculpting miniatures.This figure will also be used to start to improve my painting skills beyond the indoor lighted figure.
On the diorama,I will be starting the roof of the engine shop today.When it is completed I plan to break everything down and begin to sheath the walls both indoors and out and then start thinking about the furnishings.All of my structures are made to be taken apart for maintenance which calls for some pre-planning on how they are put together.Having fun!
Cheers! John.
Manniquins and heads www.tlbminiatures.com
Eric Hartmann figure www.greatmodels.com
Great forum on figures www.timelinesforum.com
__________________
It has been said that the difference between a "pilot" and an "aviator" is that a pilot is a technician,and an aviator is an artist in love with flight.
JohnReid (Aviator)
    February 2004
Posted by JohnReid on Sunday, October 1, 2006 10:15 AM
Another change in plans!
I have decided to delete the engine test stand from my diorama.I like the idea but have rejected it for two reasons.#1 a company of this size would not normally be investing this kind of money into test stands etc.. unless they were actively engauged in constructing engines. #2 the decision to build it was made before the Camel kit became available.There will be enough going on at the back of the hangar when the Camel-Ford T towing assembly is built.The outside area that was reserved for the test stand will now become a loading dock for trucks.
When the main hangar and all the modules directly attached to it are finished this will end phase #1 of this project.The radio shack/dispatch area may be built as a single add on or as part of phase#2 if I ever decide to build it.
As you guys can see this is an ever evolving project but that is the way I like it,nothing is written in stone.The only thing that still bothers me though , am I getting to far off the original theme of "Memories of Flight School" ?
I still plan to have all the figures(except maybe 1 or 2 )looking directly at the main pilot group of WW1 Aces,even the ones outside looking though the hangar windows at the center of the action.I am hoping that this will even increase the viewers curiosity to look inside the hangar and downplay any thing outside to only a supporting role.Any ideas or suggestions?
Cheers! John.
    February 2004
Posted by JohnReid on Sunday, October 1, 2006 10:28 AM
    February 2004
Posted by JohnReid on Monday, October 2, 2006 10:18 AM
    February 2004
Posted by JohnReid on Tuesday, October 3, 2006 1:11 PM
    February 2004
Posted by JohnReid on Wednesday, October 4, 2006 12:39 PM
    February 2004
Posted by JohnReid on Thursday, October 5, 2006 10:29 AM
    February 2004
Posted by JohnReid on Thursday, October 5, 2006 11:37 AM
As I mentioned before I am posting these pictures in no particular order to be used as a reference for future Jenny builders.The jig that I devised for this seemed to work out very well as it held everything squarely in place and yet I still had fairly easy access to work on the model.I never came up with any formal plans for this but I am sure that the pics speak for themselves.This jig is designed to evolve with the build,if you guys refer to some of the earlier pics that I posted you can see where it was progressively cut away to accomadate both left and right hand wing structures and the tail assembly.The supplied plans are very vague in this critical area of the build and some sort of jig is needed to hold everything square.Another nice feature of this jig is that the airplane can easily be removed at any time.
Update:the outside walls of the engine shop are sheathed but yet to be battened and weathered.The inside walls will be insulated with laquered cardboard, then battened painted and weathered.Doors and windows are next and then the furnishings,engine stands,workbenches etc..
    February 2004
Posted by JohnReid on Friday, October 6, 2006 9:52 AM
    February 2004
Posted by JohnReid on Friday, October 6, 2006 10:21 AM
    February 2004
Posted by JohnReid on Friday, October 6, 2006 10:50 AM
The above pic is of the same basic jig with wing extension pieces added and the original jig cut to accomodate the R/H wing and tail assembly.I used clamps,battens,pieces of wood etc... to line up wings with the fuselage and still have lots of room to work on the rigging.It also makes for a very safe enviroment to work in , as the model is well protect from inadvertent bumbs and bashes as the wing extention pieces extend well beyond the wingtips.
Posted by Lufbery on Friday, October 6, 2006 12:18 PM
 JohnReid wrote:
John,
Thanks for the photos. Your jig and construction photos look a lot like what I saw on the real thing when I visited the Golden Age Air Museum a few years ago. Thy were working on building a replica Jenny and had it looking almore exactly like the photo above. Smile [:)]
Regards,
-Drew
Build what you like; like what you build.
    February 2004
Posted by JohnReid on Saturday, October 7, 2006 10:54 AM
Hi Drew!Nice to hear from you.This is truly a nice kit.Thanks for the website.
Cheers! John.
    February 2004
Posted by JohnReid on Saturday, October 7, 2006 12:00 PM
    February 2004
Posted by JohnReid on Saturday, October 7, 2006 12:38 PM
The above pic was taken a couple of years ago when I first took the airplane out of the jig to see how it would look in the hangar.
    February 2004
Posted by JohnReid on Saturday, October 7, 2006 3:52 PM
    February 2004
Posted by JohnReid on Sunday, October 8, 2006 8:29 AM
    February 2004
Posted by JohnReid on Sunday, October 8, 2006 1:58 PM
The above pic gives you a good idea of how the jig was adjusted to accomodate the wing and tail assemblies.Except for the fact that I have finished the wing rigging ,this is how she looks today.The wheels and all control surfaces are done but have yet to be permanently installed .After the hangar, and modules are finished and the lighting is completed the airplanes,cars and figures will be placed and finally secured down.Then I will build the Camel/truck assembly and place the exterior trucks ,cars,figures,fuel pump etc....
I haven't yet quite figured out how I want to do the exterior.I want to leave it quite simple with a minimum of flora and fauna.Mud , well worn grass patches and some crushed stone would be about it.November in Canada is a real transition period and there could even be some snow on the ground.If anyone has any ideas on this I would like to hear from you as this will be my first attempt at an outside enviroment.
Cheers! John.
    February 2004
Posted by JohnReid on Monday, October 9, 2006 5:52 PM
    February 2004
Posted by JohnReid on Tuesday, October 10, 2006 9:44 AM
    February 2004
Posted by JohnReid on Tuesday, October 10, 2006 11:07 AM
QUOTE(bcauchi @ Oct 10 2006, 06:22 AM) *
Hey John, what are you currently working on? Are you experimenting with the figures? Last recent post was about the figures you got. Are you getting them together?
Hi! It is a busy time of year here in the G.W.N. getting ready for Winter and putting the Model A away in storage etc....I still try to model each day and at present I am trying to complete the new engine shop module.Once I get the hangar and modules finished and the lighting installed I plan to spend much more time with the figures.All the interior figures are finished but the new figures will be destined for the exterior where they will be much more visible to the viewer.I plan to spent a lot more time on each figure than I did with the interior ones where I could use the lighting to my advantage.
Scratchbuilding miniature figures is such a major departure for me, from what I am used to doing ,that I know that it will take a major chunck of my time to get to where I want to go.I dont want to rush it,in fact I am planning to deliver the present piece to the museum and add the exterior figures later when I feel that I can do them justice.I have always admired the miniature figure makers and I think that it is one of the highest expressions of this artform of ours.Personally I would be more than happy to end up there but until then I have so much to do just to finish what I have already started.
Cheers! John.
    February 2004
Posted by JohnReid on Wednesday, October 11, 2006 9:09 AM
    February 2004
Posted by JohnReid on Wednesday, October 11, 2006 9:46 AM
QUOTE(Jens @ Oct 10 2006, 04:28 PM) *
i must once again tell you John, you are one great modeller, and writer! wink.gif
Well thank you Jens for your kind remarks.They really are appreciated.It is very simple,I do it because I love it.
I was born in an era when aviation was still a very exciting thing to do.My Dad was a fighter and airline pilot and so is my brother.Aviation is what I have known since I was a small child,hanging around airports,going to air shows,building models and the real thing.I was even luckly enough to have flown commercially with quite a few WW2 pilots and even a few aces.I started flying just at the end of an one era and the start of another, so I have one foot in the early days and the other in the modern era.I am soon coming up to 50 years as a pilot and I just can't believe where the time has gone.
These days I am getting to re-live my childhood.My next door neighbors son (my adopted grandson as his mother calls it)is soon turning 12 years old and he is heavily into playing with my flight sims.On his birthday I am organizing to take him on a fam flight for his first flying lesson.He doesnt yet know about it and doesn't read this thread,so hopefully it will be a big surprise for him.I am just as excited about it as if was my own first solo!
Cheers! John.
    February 2004
Posted by JohnReid on Wednesday, October 11, 2006 3:57 PM
    February 2004
Posted by JohnReid on Wednesday, October 11, 2006 4:21 PM
    February 2004
Posted by JohnReid on Wednesday, October 11, 2006 4:42 PM
the figure is of the WW2 ace Eric Hartmann by Legends & Lore.This figure is easily adaptable to a barnstormer of the 1920s with very little modification.
The hands are by Verlinden and make excellent 3D references for scratchbuilding.I picked up both at Greatmodels.
    February 2004
Posted by JohnReid on Wednesday, October 11, 2006 8:19 PM
    February 2004
Posted by JohnReid on Wednesday, October 11, 2006 8:57 PM
I was reading somewhere the other day that about 90% of all pilots flying in North America in the 1920's trained on the Jenny.Its safety record was incredible for its day ,and most pictures that I have seen of accidents involving the Jenny ,look as though the pilot could probably have walked away.With that fuel tank just behind the firewall(not shown in this pic) it is remarkable how few accidents seem to have involved fire.It was only when pilots went on to advance training in some of those hot fighters that a lot of them got into trouble.Maybe in some respects Jenny was a little too forgiving and the transition to the new fighters was simply too big a step for a lot of those inexperienced pilots.Something like going from a Cessna 172 to a Beech 18 or Spitfire
