Hasegawa 1/48 Myrt WIP (COMPLETED)
    April 2020
Posted by Eaglecash867 on Saturday, August 6, 2022 1:14 PM
plasticjunkie
I used Montex vinyl masks that the edges kept lifting up. I had to continually press down on the mask to keep it down  and quickly spray. Still I had several edges to clean up with a sharp wood toothpick. The Eduard masks are far better than this vinyl stuff.
Those canopy pieces look pretty sharp PJ.  I've always loved the Eduard masks because of how well they stay put, without having an aggressive adhesive.  I have been using Tamiya masking sheets for the same reason (pretty much the same material as the Eduard masks).  They work so much better than tape and don't harm the paint or Alclad underneath.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    November 2008
Posted by plasticjunkie on Saturday, August 6, 2022 1:22 PM
Eaglecash867
plasticjunkie
Thanks Eagle. Oh yes, forgot to mention the gummy residue left behind from the Montex crap. Eduard is the best.
 GIFMaker.org_jy_Ayj_O
    April 2020
Posted by Eaglecash867 on Saturday, August 6, 2022 2:11 PM
Heh...I was thinking about giving Montex masks a try some time.  Looks like I won't be doing that now.  The masks I used for the camo on my F-16B were also vinyl masks.  I made them work, but MAN what a pain vinyl is to work with.  Its like trying to mask a complex shape with little blocks of wood.  Next time I'll use them as stencils for cutting the shapes out of the masking sheets. Beer
    May 2013
Posted by Greg on Saturday, August 6, 2022 2:56 PM
plasticjunkie
Heyvare you gonna make it to Modelpalooza this Oct.?
It's a bit early this year, isn't it?
I was thinking about making an early trip down just to go, but just noticed we have a conflicting Dr appt , so I'm afraid not. Darn it.
    November 2008
Posted by plasticjunkie on Saturday, August 6, 2022 2:56 PM
Eaglecash867
Yes
    November 2008
Posted by plasticjunkie on Sunday, August 7, 2022 11:16 PM
Greg
plasticjunkie
Yes it’s a bit earlier this year. Sorry you can’t make it this time.
    November 2008
Posted by plasticjunkie on Thursday, August 11, 2022 7:59 AM
A little more progress done on the Myrt, more weathering yet to come.
Chipping done using a combo of hairspray, sharp blade and masking tape.
The prop got some chipping on the leading airfoil edge of the blades.
The Tamiya  decals went on without a problem but are very thick. Solvaset came thru as usual, melting down the decal film to make them look as if they were painted.
    November 2008
Posted by plasticjunkie on Saturday, August 20, 2022 10:11 PM
The Myrt is completed. I didn’t like the thick toy like loop antenna in the pit so I made one from thin wire. Unfortunately it’s hard to  see thru all the greenhouse partitions of the canopies. I also added a PE sight for the rear MG. The chipping  was done differently this time using hairspray but no water to attack the hairspray layer under the green. I sprayed the entire plane with Floquil Old Silver and when dry, decanted some hairspray and shot it thru my AB. The Tamiya Imperial Japanese Green was sprayed on and set aside to dry. I then used the tip of a #11 blade to create the chips along with using masking tape to pull up and clean up the chip edges. Flory Washes popped all recessed details. The cowling color is Tamiya Nato Black with some blue added. Artists oils were used for streaks.
    March 2013
Posted by patrick206 on Sunday, August 21, 2022 3:01 PM
That's a dandy fine job you made of it, Ernie. Really nice finish and added details, the work paid off. That fuselage is so long, it looks like it has enough tail for a 737.
Thanks for the post and photos, always good to see your latest project.
Patrick
    November 2008
Posted by plasticjunkie on Sunday, August 21, 2022 7:04 PM
Thanks Patrick. The long fuselage v shape looks very cool.
fox
    January 2007
Posted by fox on Sunday, August 21, 2022 7:43 PM
W - O - W! Great build PJ! Bow Down Bow Down Bow Down
Jim Captain
Stay Safe.
 Main WIP:
    November 2008
Posted by plasticjunkie on Sunday, August 21, 2022 10:56 PM
fox
Jim Captain
Stay Safe.
Thanks Jim.
    July 2008
Posted by Est.1961 on Monday, August 22, 2022 4:01 AM
Lovely finish, really like the chipping effect I'm taking notes.
    May 2022
Posted by Eugene Rowe on Monday, August 22, 2022 8:31 AM
Great job!it really is a nice kit!
    May 2022
Posted by Eugene Rowe on Monday, August 22, 2022 8:34 AM
Did you do the anticoate?
    November 2008
Posted by plasticjunkie on Monday, August 22, 2022 1:20 PM
Thanks Est and Eugene.
What is an anticoate?
GAF
    June 2012
Posted by GAF on Monday, August 22, 2022 1:59 PM
Splendid work, PJ!  Good job on the chipping.
Anticoate? Perhaps "undercoat"?  Or perhaps the aotake?
Gary
    May 2022
Posted by Eugene Rowe on Monday, August 22, 2022 3:46 PM
Anti corrosion coating inside of the wheel wells .Characterized by it's transparent blue appearance best simulated by first painting the wells silver followed by clear blue
    November 2008
Posted by plasticjunkie on Monday, August 22, 2022 5:29 PM
Eugene Rowe
Its called Aotake. Depending on the colors at hand it ranged from green to blue. Some late  war aircraft didn't have the Aotake or even primer as shortages were getting worse.
    November 2008
Posted by plasticjunkie on Monday, August 22, 2022 5:30 PM
Thanks Gary.
