1/48 B-17 Group Build...ALL INVITED TO JOIN!
    September 2009
Posted by B17Pilot on Sunday, January 1, 2012 5:30 PM
Its from Amazing Stories.  IIRC it starred Kevin Costner has the pilot
    June 2011
Posted by Ghostriderp-47 on Sunday, January 1, 2012 7:25 PM
Photobucket
this was at the Reading air show about 2 years ago
    June 2011
Posted by Ghostriderp-47 on Sunday, January 1, 2012 7:37 PM
Photobucket
    March 2008
Posted by B-17 Guy on Sunday, January 1, 2012 7:56 PM
handiabled
Looks great!!    Did you use a wash on them ?
Yep, but there's a bit more there. Added the ignition wires, the ignition harness (the metal rings around the crankcase) and scratchbuilt prop govenors. Then, did it 24 times!! By the time I finished....Propeller
    July 2011
Posted by handiabled on Sunday, January 1, 2012 8:53 PM
B-17 Guy
 handiabled:
Yeah it looked like there was more than meets the eye,,,,awesome work Guy!!  Thats really thinking out of the box,,,the prop govs look great,, thinking of doing another 17G just because I liked how the last one I did turned out but she's under glass 160 miles away now,,,so I think the saga will continue...........Smile
    June 2008
Posted by Hans von Hammer on Monday, January 2, 2012 12:55 PM
B17Pilot
We have a winner!
Yupper, Costner was in it as was Keifer Sutherland...
Here it is, in case any of y'all are needin' a "paint-drying"  break from the B-17 you're working on...
http://www.youtube.com/watch?v=WD7B0cfTXlc
    June 2008
Posted by Hans von Hammer on Monday, January 2, 2012 1:01 PM
Just thinkin' out loud, but wouldn't this make a fun diorama for competiton?  It'd drive a couple anal-retentive aircraft judges (and one former IPMS Chapter Prez) I know nuts on how to categorize it, lol...
    May 2006
Posted by Shipwreck on Monday, January 2, 2012 4:19 PM
Hans von Hammer
http://img.photobucket.com/albums/v233/HansvonHammer/Aircraft%20Profiles/B-17/B-17tiresamazing-14.jpg
I remember this one when it first came out on regular network a few years ago.
On the Bench:
Revell 1/96 USS Constitution - rigging
Revell 1/48 B-1B Lancer Prep and research
Trumpeter 1/350 USS Hornet CV-8 Prep and research
    December 2011
Posted by Luft Modeler on Wednesday, January 11, 2012 3:42 AM
So I have started work on LMM tail swapped version now going to use Model Masters Aluminum Plate paint for the exterior to give the "weathered" aluminum skin look. Tested the paint on a spare fuselage I have and buffed it a little. Also started the flight deck, using real wood and canvas where called for. This is in crude form and still needs alot of work...
    June 2011
Posted by Ghostriderp-47 on Wednesday, January 11, 2012 8:03 AM
I have seen a lot of you are using the cheyenne turret. I have exhausted all of my resources trying to find this up grade kit the suppliers i have found ether do not carry it or do not have it in stock. This one bye Verlinden Productions SUCKS and is not like anything i have seen you guys using. Does any have any ides? Also Im looking for anything to do with the 339th bombardment group heavy More or less pictures. See i already asked my grand father about it and he can not remember his tail number. Mysteriously all of his pictures and documents and anything else relating to the 339th have disappeared. I have 4 pictures of B-17Gs in the 339th from the internet but nothing i can really go on.
Photobucket
    September 2009
Posted by B17Pilot on Wednesday, January 11, 2012 8:15 AM
I have a book called "Battle Colors Vol. 1" at home.  It has all the markings of the BGs that served in the 8th AF in it.  Great book to have! I'll take a picture of the 339th page and post it when I get home, if you would like.
If you can find it, Paragon makes a Cheyanne tail for the fort.  The Pro Modeler version of the kit includes a Cheyanne tail as well, but these are getting hard to find as well.
    July 2011
Posted by handiabled on Wednesday, January 11, 2012 8:31 AM
Ghostriderp-47
I believe I have what your lookin for with the tail assmb and glass still on the sprue,,,,they give both tail gun options with the Visible kit that I just completed and I didn't use the Cheyenne version,,,just a matter of finding it,,,,I'll look today thru my mess,,  if I find it it's yours,,,,,
    December 2011
Posted by Luft Modeler on Wednesday, January 11, 2012 10:53 AM
Canvas trimmed and painted
    December 2011
Posted by Luft Modeler on Wednesday, January 11, 2012 2:07 PM
Shelf and insulation added
    January 2003
Posted by bigfoot01 on Wednesday, January 11, 2012 4:36 PM
Looking good pzl66! Here is an update on BBtPPMBig Smile
 I custom mixed the Tamiya olive drab to get the nice faded color I wanted but the pictures look more green for some reason. The entire aircraft was brush painted with Tamiya acrylics and sealed with testors dullcote:
Here some stuff is dry fitted for a sneak peak:
John
    May 2006
Posted by Shipwreck on Wednesday, January 11, 2012 5:08 PM
Bigfoot01, I am really impressed with your 17, and brush painted too! I am not sure I can do as well with an airbrush. Do you thin your Tamyia to brush it?
On the Bench:
    December 2011
Posted by Luft Modeler on Wednesday, January 11, 2012 5:26 PM
Bigfoot your b-17 looks great!!!
    January 2003
Posted by bigfoot01 on Wednesday, January 11, 2012 5:31 PM
Shipwreck
Thank you Shipwreck. Normally I use it straight from the bottle. Sometimes when the bottle is sitting around for a while I need to add some water to replace what evaporated. I get the best results using a soft camel hair brush and apply in light coats. Most colors take two coats. White, silver and yellow generally take 4-6 coats to get even coverage. The first coat normally looks bad, but the second brings it all together. . I also brush from nose to tail on the final strokes so if there are any streaks it looks like weathering. Then I apply 2 coats Testors dullcote with a rattle can, apply the decals, and then two more coats of dullcote,
John
    June 2011
Posted by Ghostriderp-47 on Wednesday, January 11, 2012 8:08 PM
Photobucket
Photobucket
    June 2011
Posted by Ghostriderp-47 on Wednesday, January 11, 2012 9:13 PM
PhotobucketjI just grinned in front of the light to get a better feel of how close i was to the other side of the foliage
    December 2011
Posted by Luft Modeler on Thursday, January 12, 2012 2:22 AM
    June 2011
Posted by Ghostriderp-47 on Thursday, January 12, 2012 6:27 PM
Cant believe it did not come with the J piece. thank god other people used this up grad kit
Photobucket
Photobucket
    December 2011
Posted by Luft Modeler on Friday, January 13, 2012 11:12 AM
Quick question, how would I have the landing gear in the up position on the revell B-17G??
    August 2011
Posted by plasticutter on Friday, January 13, 2012 1:51 PM
The same as on the Monogram B-17G!
    December 2011
Posted by Luft Modeler on Friday, January 13, 2012 2:34 PM
Ha ha wise man... I mean I dont see an option for gear up... And since Im working on the tail swapped version and the other is gear down I want to portray this one on its last landing which was a belly landing
    August 2011
Posted by plasticutter on Friday, January 13, 2012 3:48 PM
Actually, niether of the kits- the Monogram or the Revell 1/48 kits have provisions to model the kit with the landing gear retracted. You have to "scratch" the main strut attachment point to have the gear in the retracted position. As for the supporting struts on the front side of the main strut, they bi-fold up into the nacelle and are basically hidden by the main strut and wheel when retracted, so you don't really need to bother with them. But if your going to diplay it on the ground, as in a belly landing, I would't worry about the looks of it too mauch as you probably won't be able to see much more than the retracted main wheel and strut, if you even see the strut itself.
    December 2011
Posted by Luft Modeler on Friday, January 13, 2012 3:58 PM
Model Masters Aluminum Plate after sanding:
    December 2011
Posted by Luft Modeler on Friday, January 13, 2012 4:00 PM
plasticutter
Thanks !
    January 2003
Posted by bigfoot01 on Friday, January 13, 2012 11:11 PM
pzl66, that finish is awesome! I am going to try to duplicate that on my next project, the B-17G "Liberty Belle".
Here are some update photos of the Pistol Packin Mama. Just need to do a little weathering, apply the final coats of dullcote, unmask the small windows, install all the remaining clear parts, guns, turrents and props and put her next to "Rain Check" which is a B-17G my Dad road the tail gun postion on a few non-combat flights, his regular job was Armament.
And here are some pictures of "Rain Check". I built this kit over 25 years ago as a birthday present for my Dad. I tried to be creative in the finish. I used Testors enamel and painted each panel individually using alternating brush strokes to simulate "grain" of the weathered aluminum. Since then I got smart and use rattle cans on large projects. Big Smile
Now I just need to figure out were to put Betty Boop once shes done!
John
    December 2011
Posted by Luft Modeler on Friday, January 13, 2012 11:34 PM
The B-17F looks great! Wish Revell would still make it though... I have never seen the co-pilot side of that plane before, only the pilot's side. But very nice job on that one!!
