COMPLETED: Mustang Mk.II, RAF No.2 squadron, 1/48 Acc Mini
    July 2013
Posted by IL2windhawk on Tuesday, March 17, 2009 7:47 PM
While Allison mustangs generally carry a good reputation, it seems to me that they are always belittled as being a stepping-stone to the real mustangs: the Merlin variants. Unfortunately, what is usually not mentioned is just how well these early mustangs filled an important niche at low altitude.  AAF performance charts show that below 10,000ft Allison mustangs had almost the exact same top-speed as Merlin mustangs at full WEP boost (+/- 5 MPH).  Climb rate was slower for the Allisons, which probably also meant poorer acceleration in level flight.  However the Allisons were lighter, meaning better turn capability and speed retention while maneuvering.
The Allison mustangs were so good in their low altitude roles that they remained in action through the end of the war: a service length of over three years for some airframes.  I've read that many RAF pilots considered changes to even the mighty Spitfire MkXIV a step-down in capability.  That's quite a compliment for an aircraft that entered service at the beginning of 1942.
If the Merlin mustangs were prize horses, then the Allison mustangs would have to be called work horses.  While the Merlin mustangs earned their glory escorting bombers and making pilots into famous aces, the RAF Allison birds worked down in the soup busting trains, convoys, and river traffic.  They did all of this while providing vital reconnaissance for D-Day and the subsequent push to Germany.  This model was built in honor of the brave men who performed these perilous tasks with little or no expectation of fame or glory in return.
This build was my contribution to the Mustang GB.  It depicts a Mustang Mk.II (P-51A) in service with No.2 squadron, Royal Air Force.  The aircraft is heavily weathered with dirt to reflect its expeditionary deployment to grass/dirt airfields in northern France.  RAF No. 2 squadron was known for flying recon flights in pairs with one aircraft flying as "weaver", covering the leader who was solely focused on the target package.
Construction points of interest:
- 1/48 Accurate Miniatures P-51A kit
- Squadron Vacform canopy, Revell pilot
- Ultracast fishtail exhausts
- Tamiya acrylics, pro-modeler wash, enamel weathering
- Scratchbuilt antennas, mirror, various cockpit items
- Control surfaces cut and repositioned for in-flight
- Squadron letter "N" was masked and painted to match
- Model pivots on it's mounting mast
Hope you all like her.  Constructive criticism is always welcome.
Build and Research References
1) Glen Phillips, Allison Engined Mustangs, Squadron/Signal
2) Jerry Scutts, Mustang Aces of the Ninth & Fifteenth Air Forces & the RAF, Osprey Publishing
3) Mustang Speed charts, M. Williams archived, http://www.wwiiaircraftperformance.org/
4) MustangsMustangs, http://www.mustangsmustangs.com/p-51/p51variants/MustangI-IV.shtml
5) No. 2 Squadron (RAF): Second World War, http://www.historyofwar.org/air/units/RAF/2_wwII.html
  1/32 Revell Duo Discus
  1/32 Revell ASK-21
  1/48 Ardpol SZD-51 Junior
  1/48 Czech Models Grumman Goose
  1/144 FineMolds Millennium Falcon
    September 2004
Posted by razordws on Tuesday, March 17, 2009 8:11 PM
She's a beauty Sir Il2!  Looks like a great build from all angles.  Thumbs Up [tup]Thumbs Up [tup]Thumbs Up [tup]  What did you use for the in flight support?
Dave
    December 2003
Posted by hkshooter on Tuesday, March 17, 2009 8:24 PM
Awesome model, great back story. I really like the possable stand, nice touch. Very well built and I like the way the vac lid turned out. Takes a lot of patience and skill to make those vac parts look that good.
On a technical note, depending on how fast the pilot wanted to roll the airplane, he may have cross controlled the plane, stick in one corner of the cockpit, rudders in the opposite corner. In other words your rudder should be deflected in the other direction to coincide with the deflection of the aielerons. It's violent roll, to be sure. Great way to bounce the passengers head off the canopy if you don't warn him first.
Under more sedate conditions, in a turn like you have indicated on the aielerons, the rudder now acts as the elevator and again needs opposite deflection to keep the nose up. In a turn the wings lose lift perpendicular to the ground and the a/c will lose altitude. Right rudder keeps the nose up and helps maintain altitude.
I hope my mumbling made sense. Very nice model! Looking forward to seeing more or your rarely seen work.Big Smile [:D]
Posted by jeaton01 on Tuesday, March 17, 2009 9:41 PM
Windhawk, nice model, nice description, and nice display concept.  It would be neat if it were mortorized, maybe I should rent you my granddaughter who supplies the windpower for my spinning prop pictures.Smile [:)]
HK, what you describe is a snap roll, and it is not allowed in a Mustang, or any other high performance aircraft, save those built especially for it, like the Extra 300, Pitts Special, and that sort.  The snap roll is an accelerated stall, meaning a stall done in excess of 1G, usually at 2G's in most aircraft.  In an aircraft with a higher stall speed such as a Mustang, the forces are too extreme on the airframe, most particularly the tail, so they are prohibited.
Proper use of the rudder is one of the most difficult things to teach a new pilot.  In Windhawk's pose, in my opinion it is believable for a slow airspeed maneuvering turn, in the transition from level flight to the final bank angle.  Perhaps the elevator is up a bit more than in might be, and maybe the rudder is over a bit more than it might be, but not too much.  Then again the airplane might have just flown through some turbulence and anything goes, especialy at lower speeds.
When I would use rudder opposite the aileron would be in a slip to a landing, knife edge flight, or a snap roll.
John
    September 2003
Posted by Daywalker on Tuesday, March 17, 2009 10:20 PM
Excellent build, and the in-flight display is a nice touch.  Weathering is subdued, yet noticeable.  I really like it! Thumbs Up [tup]
Frank
    July 2013
Posted by IL2windhawk on Tuesday, March 17, 2009 11:18 PM
Thanks for your comments and suggestions.
To answer Razor's question, I mounted this plane much the same as my other builds: by filling the fuselage with balsa and saturating with thin-CA.  I've written extensively about this technique in the thread below, with photos of this same model as a work-in-progress.  Let me know if you have any questions, and I'd be glad to assist.
/forums/1068904/ShowPost.aspx
For the record regarding the control surfaces, I originally built the model with the intent of mounting the aircraft in a more-docile banking turn (sorta like in the last photo).  Then as the build approached its end, I decided to really tilt the orientation as if the pilot was lining up for a recon photo.  I read that pilots would circle their target at ~9,000 ft taking photos.  To that aim, I think hkshooter is probably right: the rudder should be swung in the opposite direction for the aircraft to maintain altitude in the turn.   I suppose the pilot could be yawing the aircraft to make an adjustment for the photo, or just setting up the run.
But having studied the model a little bit more, I think the flight scenario that best fits is an immenent banking & pitching maneuver into a steep dive.  Rather like the pilot is at the peak of a 'high yo-yo' maneuver: relatively slow and using left rudder to coordinate his turn so he can bounce a FockeWulf below!   Ahhh.... time to go play some IL2 online.
Thanks for the suggestions and input.  This is why I invite criticism: I always learn something worthwhile.
  1/32 Revell ASK-21
    July 2008
Posted by vetteman42 on Wednesday, March 18, 2009 12:52 AM
IL2windhawk Nice build my friend ! To my eye the weathering couldn't be better. I am going to have to pick on you for your secret to that vacuformed canopy though as mine is giving me fits and I dont mean the good kind.
I do hafta put in my 2 cents worth at this point about the control surface deflections. A high yo yo is one manuver he could be doing, however I have used slipping turns to turn around a point on the ground to take pictures. The way I recovered from that was to add in oppisate rudder to push the nose back down then roll the wings back to level or just to continue the turn. I have also used slipping turns to lose alitude if a little high on aproach for landing. This trick works really on no flap planes like a cub or cessna 120, have to kick some opisate rudder to strighten that bird out.
HK at low airspeeds thats a perfect setup for a spin, at high speeds you gonna snaproll that bad boy.
Randy So many to build.......So little time
    October 2003
Posted by ModelNerd on Wednesday, March 18, 2009 1:34 AM
This is awesome! The "in flight" display looks really excellent! Great work!
- Mark
Posted by rjkplasticmod on Wednesday, March 18, 2009 8:27 AM
Excellent build & display Thumbs Up [tup].  Thanks for sharing.
Regards,  Rick
    February 2007
Posted by Luftwoller on Wednesday, March 18, 2009 8:42 AM
Excellent build and weathered to perfection. For me the plane looks like the pilot is making desperate attempts to find somewhere flat to lay her down, seeing as the prop isnt spinning Whistling [:-^]
If ever there was a quality build that is crying out for a 'Prop blur' then this is it.
Gorgeous.
...Guy
..'Your an embarrassment to the human genus, makes me ashamed to call myself Homo'.
    January 2003
Posted by yardbird78 on Wednesday, March 18, 2009 9:41 AM
Very nice work on the early Mustang.  The weather is very realistic.
Darwin, O.F.  Alien [alien]
The B-52 and me, we have grown old, gray and overweight together.
    May 2008
Posted by MIflyer on Wednesday, March 18, 2009 1:28 PM
Beautifully built Mustang. The weathering is nice, and the vac canopy is really thin and clear - good choice there. The "razorback" models, and especially the Allison-engined variants, are my favorite Mustangs. Very nice job. Approve [^]
As to the control input discussion: if all the aircraft is performing is a turn, and not some specialized maneuver, then it goes:
Ailerons to turn the plane
Elevator back pressure to hold altitude, even if you're banking 60 degrees or more. A little throttle helps, too.
Rudder to keep the tail from slipping or skidding around - keep the tail following the nose, in other words. Large cross-controlled rudder inputs at high bank angles are generally a bad thing... that is, unless you're trying to spin. Wink [;)]
New pilots very often forget to use their feet. It's one thing that I don't like about training in the Piper Cherokees my employer has - the Cherokee is so stable that you can get away with being lazy on the rudder 90% of the time. I really prefer teaching steep turns and stalls in a Cessna, because it's more likely to bite the pilot for a mistake - makes for a more effective lesson.
Kevin
Kevin Johnson    Ypsilanti, Michigan USA
On the bench: 1/72 Fujimi Ki-36 J-BAAR
    January 2007
Posted by trexx on Wednesday, March 18, 2009 2:09 PM
Your well written notes and model are OUTSTANDING!
Truly, a compelling and well executed MUSTANG! I can practically hear it whizzing through the air!
 Critique: not a one.
    May 2006
Posted by Edgar on Wednesday, March 18, 2009 4:00 PM
Nice to see a return to subtle weathering; my only comments are that, long before 1944, the RAF were using VHF radios, which only needed a short aerial, and that was contained, out of sight, inside the mast, and you'd never, normally, see weathered trailing edges of the prop blades.
Edgar
    April 2005
Posted by wing_nut on Wednesday, March 18, 2009 5:43 PM
IL2... That is just beautiful.  great story and some great poses.  I hope you don't mind butthere was one the really caught my eye and I just had to see how itlook really in flight.  i know what I think... how do you like it?
Marc
    July 2013
Posted by IL2windhawk on Wednesday, March 18, 2009 9:01 PM
Wow, wing_nut!  That is an great photo-edit!    It looks increadibly real: like it's flying over the English channel on a hazy day.  Thanks - that's my new desktop wallpaper!
And thanks to everyone for your comments and encouragement.  I really strived to improve my weathering skills on this bird, so it's nice that everyone has taken notice of that particular aspect.  Everything I've learned has come from right here, watching you guys and others on FSM and it's very rewarding to receive your compliments.
I would have to agree with those who said a blurred prop would add alot.  I sorta wish I had installed a motor.  Unfortunately, the prop doesn't rotate freely enough to spin when exposed to a fan, so we'll have to settle for Wing_Nut's simulated wartime photo.
Edgar, I really appreciate your input from a historical standpoint.  Accuracy was another goal I strived for on this build.  So if I understand you correctly, I should trim away the antenna wires but leave the mast?  That would be quite easy to do, although admittedly I would like to leave the antenna wire!  LOL - it's a cool detail.  Would the RAF have retrofitted their allison mustangs with new radios?  I suppose that would be necessary to talk with other VHF radios.
And the prop blades: that should be easy enough to rework.  Thanks for the other great tip.  There's a famous photo of Duane Beeson sitting in his P-51B that shows chipped paint all over the prop blades.  Unfortunately I've used this as a weathering reference for several builds!  Apparently this photo is the exception, not the norm.  It's a great photo anyways. http://www.acesofww2.com/Canada/aces/beeson.htm
Vetteman, I'd be glad to step you through my process for vac-canopies.  I estimate that my method is fairly unorthodox because I usually bond with CA glue (and accellerator to prevent fogging).  An important step is to make sure you buy two or three extra canopies before you start, LOL Big Smile [:D] Anyway, PM me and I'll be glad to explain the process.
This canopy was unique in that it wrapped over part of the fuselage.  Although it involved some tricky cutting of the fuselage, I actually wish more vac-canopies were like this.  I suppose you would still have the option of trimming the vac part if you didn't want to cut the kit parts.
One thing I haven't mentioned yet is that I also built this model as a prelude to a larger project: an RC mustang of the same subject.  I'll be sure to bump the thread when I finally finish building it (maybe in a year!).  Building the model helped me sort out some of the details for the RC project.
  1/32 Revell ASK-21
    July 2008
Posted by vetteman42 on Sunday, March 22, 2009 12:27 PM
I used to build and fly RC so do tell more about your RC P-51, what size, what kit ? Unfortunally I cant afford to buils the RC stuff anymore, but still love to hear about it all. I do have a small helicopter I chase the dog around the house with, course she turns around and chases it too.
Inquiring minds need to know.
    May 2006
Posted by Edgar on Monday, March 23, 2009 3:02 AM
Sorry, I missed this, first time round, but you're quite correct; keep the mast, but not the wires (any of them.)  For some reason, initially Mustang I, and Ia, airframes had the wires, but, by 1944, they were gone.  If you ever do a III, there was a whip aerial further aft (presumably to keep it out of the way of the Malcolm hood.
Edgar
    July 2013
Posted by IL2windhawk on Monday, March 23, 2009 1:00 PM
Thanks for confirming, Edgar. I wanted to be certain before I went ahead cutting!
Vett, i'll be modifying a Top Flite .60 size kit into an Allison Mustang Mk.I (RAF). Don't hold your breath though, because this project has been on going for two years now (with little progress regrettably).
Right now I'm building a 51D of the same size, but to a lesser degree of scale accuracy. I plan to practice my warbird flying a bit more with this one.
  1/32 Revell ASK-21
