1/18 scale Tervamaki Engineering JT-9T autogyro
    May 2009
Posted by Nick_Karatzides on Saturday, September 26, 2009 9:29 AM
 Back to the bench wrote:
Nick, you have to be one of the most creative modelers I have seen. Your use of every day materials in new and unique ways is really inspiring! Amazing photography on the builds as well. As I have mentioned in other posts I know I may never reach the skill level of builders like you, but your work inspires me try new techniques and look at new sources for modeling materials.Wow!! [wow]Bow [bow]
Thanks mate! My point is to present a step-by-step scale model scratchbuilding and expose the photographic process to this, so an interested fellow modeler or scale modeling enthusiast could find out how he can achieve this using simple & cheap materials to assemble. If you also notice, every single step of the construction of both this 1/18 scale autogyro JT-9T project and my other 1/18 scale F-16C project, I do present new or unconventional techniques, simple tips & tricks and (most importantly) low-cost methods to achieve the best possible result and plausibility as a model to scale.
Of course my wife and daughter may start looking at me like I am a bit strange when I go "dumpster diving" and come up excited with some scrap wire and other treasuresSmile,Wink, & Grin [swg]
Yeah, I know exactly what are you talking about!
    May 2009
Posted by Nick_Karatzides on Sunday, September 27, 2009 3:45 PM
Using my X-acto knife, I removed the formed fuselage from the styrene sheet and test fitting on the autogyro scale model airframe. Few drops of cyanoacrylate glue applied on the right spots across the fuselage joints to make the contact secure, did some light sanding on the fresh produced thin-skinned right side fuselage to eliminate some tiny marks and as you can see at the following pictures, the nearly transparent result is more than realistic to scale and completely satisfies to me.
    September 2003
Posted by Daywalker on Sunday, September 27, 2009 4:37 PM
Absolutely brilliant!  So many ideas presented here, and great photography to back them up.  Nick- keep those updates coming, this is REALLY good stuff! Bow [bow]
Frank
    May 2009
Posted by Nick_Karatzides on Wednesday, September 30, 2009 6:37 PM
Do you remember the wooden picture frames I found at the local IKEA store for only 1€ each, securing the styrene plastic sheet to be vacuum formed? I kept these thin plexiglass plates, to use them as required. Continuing the cockpit construction, I had to build the rear cockpit cover, so I placed the autogyro model upside down facing a glass surface, I boxed it by placing the thin plexiglass plates around it, securing in place with modeling clay for kids. Then, I removed the scale model carefully, leaving space between these thin plexiglass plates. Wet white plaster mixture, applied into the gap, between the thin plexiglass plates to fill the area. When the first layer of thinned plaster was dry and hard enough, two or three extra layers of white plaster followed to finally build the basic cast. Keep in mind that adding salt into wet plaster mixture, reduce the plaster's hardening time and adding vinegar into wet plaster mixture, extend the plaster's hardening time.
    May 2009
Posted by Nick_Karatzides on Wednesday, September 30, 2009 6:38 PM
When the plaster cast was dry and hardened after few hours, I removed the modeling clay for kids and the thin plexiglass plates. The white plaster cast got shaped into proper dimensions but cutting it with saw, filling with tiny quantities of modeling putty added to close minor scratches and pores on white plaster cast surface, dry sanded and finally sprayed overall with gloss shiny coat.
    May 2009
Posted by Nick_Karatzides on Wednesday, September 30, 2009 6:39 PM
Because I was planning to use smaller wooden frame to secure the styrene plastic sheet (the piece to be vacuum formed is too small, there is no need to spend big plastic card), I had to close the outer holes on the hardboard high-density fibreboard plate. To do so, I cut a plastic bag in shape and covered as required the desired area. I pined a styrene plastic sheet on the wooden frame, insert it into the preheated electric oven as described before and as soon as I noticed that the plastic started drooping down, I removed it on the vacuum former plate, while the vacuum cleaner was already plugged & switched on. The plastic nicely formed around the plaster cast and here is how it looks like.
As long as the piece looked satisfying to me, I removed the formed plastic from the styrene sheet with a new Nr 11 surgical blade on my cutter, test fitting on the scale model and later start adding internal detail.
    February 2007
Posted by Luftwoller on Thursday, October 1, 2009 11:33 AM
I was wasting my time LOL showing the missus your fantastic post and guess what she said....'Hey, hes got a local Ikea'...Geez, Women eh?
Great work Nick. Really coming together.
...Guy
..'Your an embarrassment to the human genus, makes me ashamed to call myself Homo'.
    January 2003
Posted by el_jere on Friday, October 2, 2009 9:15 AM
Wow!!! what a gret project!!! I love to see this rare birdes... thanks for sharing your techniques and tips, very useful!
best regards
Jeremias
Res non verba
    May 2009
Posted by Nick_Karatzides on Sunday, October 4, 2009 7:12 PM
I placed the rear cockpit’s cover in place and secure it with just one or two drops of cyanoacrylate super glue. Then, using a small pencil, I defined the exact line that the rear cockpit cover should be cut in order to let the inside structure visible. Using the mini Dremel tool, I cut and removed the left half part, in a way to look kind artistic.
    May 2009
Posted by Nick_Karatzides on Sunday, October 4, 2009 7:13 PM
My good friend Demitris “Jagdpanther” Pravinos, who is a WWII German tanks specialist scale modeler, sent me about five hundred (!!!) cups he found and looked ideal to use them for mixing colours, modeling putty etc. Few drops of nitrocellulose lacquer thinner and just a little amount of Humbrol modeling putty, were more than enough to prepare a nice liquid mixture to apply on the rear cockpit cover surface, to ensure that little tiny scratches would disappear.
    May 2009
Posted by Nick_Karatzides on Sunday, October 4, 2009 7:14 PM
Few hours later, soft sanding and a quick airbrushing with white color to make mistakes, scratches etc become easy to spot, the rear cockpit cover was finally ready.
    May 2009
Posted by Nick_Karatzides on Sunday, October 4, 2009 7:17 PM
CHAPTER V - "H" shaped tail construction
The Jukka Tervamäki Engineering JT-9T autogyro designed by Finnish engineer Mr. Jukka Tervamäki, is equipped with a twin "H" shaped tail. To build this, I started by rolling flexible styrene sheet around a plastic tube and forming as required to look like the real JT-9T autogyro right side elevator main wing - only 18 times smaller. Following, using the sandwich method (placing one plastic sheet over another), cutting carefully and working extensively with sandpaper to form into desired size and aerodynamic shape, I manage to build the right side stabilizer wing. As you understand, the left side elevator wing, the stabilizer and rudder, will be stripped in a way to show the airframe aluminum skeleton.
    May 2009
Posted by Nick_Karatzides on Monday, October 12, 2009 6:19 PM
    May 2009
Posted by Nick_Karatzides on Wednesday, October 14, 2009 8:41 PM
CHAPTER VI - Landing gear system construction
The single seat JT-9 and the tandem seating JT-9T, are available with tricycle landing gear system with a steerable nose wheel or a taildragger version too. For both types, the type of landing gear is based on the placement of the exact CG position, determined after complete weight calculations according the owner/pilot's personal needs. My 1/18 scale model is designed to be equiped with a tricycle landing gear system with a steerable nose wheel. An utility free-spinning tail wheel is also placed, to prevent any accidental damage on tail structure if the autogyro raise nose too high while in ground. Feel free to check the diagrams and images found into my first post of this project, back in page 1.
Using plastic card, sprue, metal wire, resin tires and brakes fit accurately to 1/18 scale diagrams and few unidentified parts found in the sparebox, I build a realistic looking 1/18 scale main landing gear system with absorbers and a steerable nose gear. I stole a nickel plated button from GF's favorite dress (hope she'll never find out where's the missing button or I'm in real trouble), placed it into a plastic tube piece, covered with with transparent plastic card & add some details to simulate the landing light in scale.
Yeah, yeah, yeah... I know! I am a button stealer, but let's admit it! We all prefer less buttons on female dresses :lol:
    May 2009
Posted by Nick_Karatzides on Thursday, October 15, 2009 2:57 PM
CHAPTER VII - Canopy construction
The Jukka Tervamäki Engineering JT-9T autogyro canopy is made by bented and cold-formed 3mm polycarbonate sheet. The backwards sliding canopy of the single seat JT-9 version, offers the possibility to taxi and fly slowly with the canopy open, a benefit in a hot climate. The trainer / tandem seating JT-9T, has a side opening one piece canopy. Of course, canopy modifications can be done, according the autogyro owner's personal needs or desires.
    May 2009
Posted by Nick_Karatzides on Thursday, October 15, 2009 2:58 PM
I used styrene plastic card to form it as shown into following pictures to give the basic shape of the canopy. Then, a layer of polyester filler applied on the styrene. The specific polyester filler I used, comes with the proper catalyst which provides a solid rock build and approximately 3 to 5 minutes time window to form it into shape. I prefer to use epoxy putty or polyester filler with fiberglass grains for special purposes, because:
  • It becomes solid rock within only few minutes or seconds,
  • it does not shrink and does not crack after months or years,
  • you can pour to any shape that you want but you need to work fast because as soon as you mix it with catalyst cream approx 5%, you have limited time before becoming solid rock,
  • you can also put additional layers of epoxy or polyester filler to build up,
  • you can sand it, you can drill it, you can use any type of scale modeling glue, any type of primer or enamel / acrylic paint on it with no problem,
  • can be purchased at any good crafts store into 250ml, 500ml, 1lt (comes with a tube of catalyst hardener) or bigger canisters and if you can't find it, fear not and try your local decent hardware store and finally...
  • it is cheaper than dirt - estimated prices are £3 to £10 depending the canister size, the quality, if contains fiberglass grains for maximum strenght etc.
Keep in mind that the chemical reaction after mixing the polyester filler with the catalyst hardener, produces some heat that possibly effect on thin plastic parts, so test it first before try it on your scale model. I don’t think that the produced heat is more than Fahrenheit 110, but better watchout. Remember that epoxy materials are dangerous when breath or shallow and could result skin, eyes or lungs problems or even cancer when used for long period with no precaution measures. Always keep in mind, that a powerful vacuum system to suck away the epoxy dust should be used all time to keep the workbench area clean while sanding or milling epoxy or resin materials. Using an issued breathing mask and a pair of surgery latex gloves to prevent dust contact with lungs and fingers while sanding or milling epoxy, is also an important matter that you should seriously take care of! My recommendation is to also wear an overall working suit (as I do) to keep your clothes dust free while sanding epoxy. Some people might find it too much, but I wouldn't like to bring epoxy dust & grains from my work bench into living room and my beloved.
When the basic canopy shape made by styrene sheet, was fully covered by a a thin layer of polyester filler and had enough time to polymerize and get solid rock, I sand it with wet sandpaper to make the cast curved and shiny. To produce a thin-skinned canopy, the polyester part should be vacuum formed. As described into previous chapters, a transparent plastic sheet were pined on a wooden frame, preheated into electric oven and as soon as I noticed that it started drooping down, I vacuum formed it. The clear plastic nicely formed around the canopy cast following the curves & details as planed. Using an X-acto, I removed the formed canopy buble from the transparent sheet and start adding details, such as canopy's frame. Few drops of cyanoacrylate glue applied on the right spots with great caution. Remember that CA glue does fog the transparent parts and this canopy would not be an exception - that's why I placed some very tiny drops of it, just on few spots.
    February 2007
Posted by Luftwoller on Thursday, October 15, 2009 3:23 PM
Nick, This build is just amazing. It makes me feel gutted to see so few responses to such stunning work. I feel like i should wear a advertising board say 'Everyone look at this build!'
Really looking forward to the next installment.
...Guy
    January 2006
Posted by dirkpitt77 on Thursday, October 15, 2009 7:09 PM
You Greeks never do anything small, do you?
    Seriously though, fantastic work.  Simply amazing.
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
    May 2003
Posted by styrene on Thursday, October 15, 2009 8:07 PM
That does it.  I'm throwing all my kits away and becoming a monk....
Absolutely fabulous work, Nick.
Gip
    May 2008
Posted by MIflyer on Friday, October 16, 2009 11:38 AM
Wow... where do I start? This whole build is just amazing. Bow [bow]
Kevin
Kevin Johnson    Ypsilanti, Michigan USA
On the bench: 1/72 Fujimi Ki-36 J-BAAR
    July 2009
Posted by 40.mm on Saturday, October 17, 2009 5:35 PM
im blown away at this build .and all scratch built. it has given me some how to ideas keep it up its knocked my socks off and put them away. i bow to you sir
http://www.vairhead.net/forum/dhg.jpg
    April 2004
Posted by vespa boy on Sunday, October 18, 2009 11:10 AM
This is am amazing scratch build project. Thanks for the step by step as you go. There is nothing more fascinating than seeing how a build goes together. I like it so much better than just showing the glamour shots at the end. Thanks for sharing this with us.
http://public.fotki.com/nkhandekar
This ain't no Mudd Club, or C.B.G.B.,
I ain't got time for that now
    May 2009
Posted by Nick_Karatzides on Wednesday, October 28, 2009 10:38 AM
It’s sad! Obviously, voodoo curses came from the unspeakable dirty Viper snake, got real and the final varnish finishes on the model suffered what the Americans call as FUBAR - F@cked Up Beyond All Recognition.
In brief words, the color layers popped and “cracked” everywhere on the model’s surface, just before the final touch. For some mysterious reason, the color looked peeled off and an unexpected chipping (I would never succeed this by purpose) appeared! The scale modeling accidents committee is expected to investigate the possible reasons within following days, but unconfirmed sources report "pilot’s error" - OK, I made a rookie’s mistake, while using old colors or coat varnish.
Meanwhile, the following actions took place:
  • Garlic cloves were hanged across the workbench to keep away evil curses, vampires and “snakes” (or those who claim themselves as “snakes”),
  • The scale model were covered with a thick layer of ModelStrip product, locked tightly in a plastic bag and left overnight to let the chemical work.
    May 2009
Posted by Nick_Karatzides on Wednesday, October 28, 2009 10:40 AM
CHAPTER VIII - Live After Death
When I started building the model, I did not expect to present the CHAPTER VIII under this title. Bus as all the sad & bad situations in life, it was unexpected and accompanied by great frustration because suddenly I saw months effort to dissolve in only few minutes. The old colours (or bad white spirit solvent) that I used, have led to drying crack. Unfortunately, I ignored all the warning signs such as thick grains left by the white colour in which I primed the scale model before the final painting. Having as target to make this model alive again, just like Iron Maiden Eddie’s Live After Death, I decided to try a full reset – after all, I had nothing to lose! The scale model was already FUBAR.
The following photos show the unsuccessful paint process. The problems appeared marked inside the red circles. Unfortunately, I have no photos of the model while looked completely written-off, because at that time I was not in a mood to take pictures!
    May 2009
Posted by Nick_Karatzides on Wednesday, October 28, 2009 10:43 AM
ModelStrip, was the first thing came up as the most conventional solution to try paint removing. Following the instructions on the box, a generous stuff applied on the model, wrap it with airtight plastic bag to prevent drying and wait about 15 hours to let the chemical work. Opening the bag next day and checking the results, the colour (or rather the colour layers) were soft and could be removed by rubbing vigorously with an old toothbrush. Unfortunately, using the brush on some very delicate spots (even with careful use), had as result to break / or ruin a couple of plastic pieces. Moreover, the paint could not be removed through narrow points and difficult locations.
At this point and while I’ve already used all the ModelStrip material without being satisfied with the outcome, I decide to change tactics to something more unconventional, such as oven cleaner.
Following the product’s directions as always, I sprayed the model with the material, wrap it with airtight plastic bag to prevent drying and wait about 15 hours to let the chemical work. Testing results next day, the oven cleaner failed no more than ModelStrip. I noticed that the colour could be removed but only when pressure and persistent rubbing with brush and that was prohibitive for some parts of the model. Not having another solution, I approached the most unconventional method and visit a science specialist - my local grocery store!
- Hey man! I need something really strong to clean up kitchen’s oven?
- Really strong? Use this!
…and he gives me a dust covered 1lt plastic bottle found in an almost unreachable shelf. Reading the bottle’s label, I found out that it contains sodium hydroxide also known as lye (corrosive alkaline substance) or caustic soda and is a caustic metallic base. It is used in many industries, mostly as a strong chemical base with chemical type NaOH.
- Are you sure that this will work? Are you sure that this is safe to use?
- Trust me. It’s gonna clean up the kitchen’s oven like a nuclear bomb!
- How much?
- 3.50 € . Take it or leave it.
Thinking about a possible failure, I filled a plastic bowl with the milky liquid contained in the bottle and threw all the model pieces inside. As long as the autogyro model was already FUBAR, I had nothing to loose to try. I sealed the bowl with a cover and leave the sodium hydroxide to act for 20-30 minutes while the instructions sets out to wipe the sodium hydroxide chemical liquid after 10 minutes. Opening the plastic bowl’s cover, a nice surprise followed...
The truth is I was delighted! Styrene pieces simply and magically totally striped off the enamel colour layers! Absolutely success, without even apply brush cleaning! Amazing product - incredible grocer! Just because I couldn’t believe it and I wanted to make sure that the colour striped off because of the sodium hydroxide chemical (and not the previous used ModelStrip product or the kitchen oven cleaner), I decide to experiment. I threw in a bowl, already filled with the chemical, a 1/18 scale female figure that I was about to convert for a future project. The specific 1/18 scale female figure, is made by Fast Women brand and can be found by clicking HERE). The results after just 15 minutes in the sodium hydroxide chemical - Perfect! The following pictures, show the "before" and the "after".
Keep in mind that the sodium hydroxide is (and thus should be considered) a strong caustic base. This means that:
  • Throughout the impregnation of the model parts into sodium hydroxide, you should take all the necessary protective measures (like mentioned in the warnings on the bottle’s label) and is certainly to use disposable surgical gloves made by latex and breathing mask with appropriate filters to protect against possible fumes.
  • The colour stripped plastic parts must be rinsed with soft acid to neutralize the caustic base and produce salt and water. Dunking the colour striped parts in plastic container filled with cooking vinegar and then rinsing with plenty of lukewarm water, plastic is now safe to handle with bare hands.
Under the above "adventure" circumstances and considering that all these years dealing with the scale modeling I've tried many color striping methods (including ModelStrip, kitchen oven cleaners, blue alcohol, brake fluid, nitro laquer disolvent, etc), I think that sodium hydroxide NaOH is the best method so far, for the following reasons:
  • Kitchen oven cleaners in spray canisters, can do the job, but they cost 3 - 4 € for a 300ml product in which also includes the propellant gas. On the other hand, the NaOH in liquid form is a pure substance, much less price, taking for 1lt bottle, which equals 3.3+ times more product! Using the liquid form NaOH (which you can fill a plastic bowl), you can sink several plastic pieces, same time!
  • The brake fluid may be effective and remove paint, but it is not plastic friendly plastic and is likely to convert the scale model into a blob of molten plastic. It is clearly more expensive and as far it is highly toxic, flammable and hardly to manege, I will not recommended it for scale modeling use.
  • Nitric acid laquer disolvent, could be a nice solution for metal figures paint striping, but it is not the best for the plastic. Just like the brake fluid, it does melt and damage plastic parts.
    May 2009
Posted by Pawel on Thursday, October 29, 2009 3:47 AM
Hey Nick!
Ain't that a shame when it happens... But, as they say, as long as you're fightnig, you're a winner... I had my adventures with paint stripping recently and I used brake fluid for it. It isn't as powerful as NaOH, but gives good results too. With brake fluid cleaning delicate assemblies isn't so easy too, but you can strip clear and metal parts, which you reportedly cannot with NaOH.
Nice model for the second experiment, by the way. I hope the watchers ain't gonna get you for this - after all you removed underwear from a girl's model Big Smile [:D]. Good luck with the autogyro, and have a nice day
Pawel
www.vietnam.net.pl
    January 2008
Posted by 666Irish on Thursday, October 29, 2009 4:30 AM
Sorry to see and hear about your paint issues. Being someone who restores cars and military equipment for a living, I can certainly feel your pain. From what I can see, it looks like you had one of two issues. The most likely answer is that one of the layers (primer, color coat, or sealer/clear coat) was old product, and had already begun to break down before using it. Another possibility is contaminants on the surface before you painted.
What did you use to prepare the surface before painting? And what kind of paint did you use?
You might want to look into an automotive surface preperation for future use. Simply Known as "DX" here in the States. It is made by PPG paints. It removes all grease, dirt, waxes, and contaminants on the painting surface before you shoot color. You also might want to pick up a tack cloth. They are excellent for getting even the tiniest speck ofdust from the surface, and remove any static buildup before painting.
Just a suggestion. Fantastic build, by the way. I am loving it.
She was only a whiskey maker, but he loved her still.
    September 2003
Posted by Daywalker on Thursday, October 29, 2009 7:37 AM
That really is too bad about the paint, but glad you were able to find a product to remove the offending paint.  Too bad you didn't happen to find it before scrubbing and breaking off a few bits.  Glad to see the project will go on, as I am really enjoying watching this one come together.  Fantastic stuff! Bow [bow]
Frank
    May 2009
Posted by Nick_Karatzides on Thursday, October 29, 2009 8:16 AM
Pawel, as long as brake fluid is not plastic friendly, it is NOT recomended for color striping on plastic or styrene parts. Brake fluid can and will melt the plastic and convert it into a corroded mass. Brake fluid can strip colors only from metal parts, but I wouldn't recomend it, because it is expensive, extremely toxic and flameable. According to me, the best solution from color striping metal parts, is to sink metal parts into a bowl filled with nitro lacquer thinner which is much cheaper and can be also used as modeling putty dissolvent too as I describe in previous pages. As a conclusion, I believe that NaOH is the best enamel color stiper so far, because:
  • It is cheap with only 3.50 € per litre,
  • It is plastic friendly and does not damage or effect modeling putty inserts,
  • It is easy to use, because you only need to simk the model into a bowl filled with NaOH and wait 20 to 40 minutes until it is copletely color free without even try brushing.
I used enamel Humbrol colors and White Spirit as thinner. After decades in scale modeling, it's the first time I witness such a color dissaster.
    May 2009
Posted by Nick_Karatzides on Monday, December 21, 2009 12:46 PM
CHAPTER IX - Applying paint, wash & weather effects
Model parts were washed with liquid soap and warm water to disappear leaving oil traces, fingertips etc and then sprayed with light grey primer.
