AMT A-20 done(dio)
    January 2009
AMT A-20 done(dio)
Posted by fermis on Sunday, January 17, 2010 11:09 PM
 With all the talk of AMTs(Italeri/Revell) A-20 over the last week or so, I got fired up to get this $5 vendor table wonder knocked out. Adding some scratched detail and some leftover PE to the pit. As of now, I'm not planning on duplicating the boxart, probably will just make something up. I'm planning on putting a cover on the turret(like my B-25) and having ground crew getting her ready( I will probably never get around to the figs though!!!)
 Anyway, work starts with the front office.
left side, all hand painted, added some throttle/mixture handles and friction locks from some PE leftovers. Placards are little bits of paper, CAed and painted.
001-1.jpg picture by fermisb
right side, added a few wires, reworked the map case and put a map in it. Also added some framing to the rear area.
002-1.jpg picture by fermisb
The IP is all hand painted, with testors clear parts cement for the inst. faces
003.jpg picture by fermisb
seatbelts are made from masking tape, with some PE buckles
004.jpg picture by fermisb
Rudder pedal area was cut out, then cut notches out of sheet styrene "panel", details are wire and stretched sprue. Rudder pedals are # tabs from a PE fret.
005.jpg picture by fermisb
    November 2003
Posted by tempestjohnny on Monday, January 18, 2010 9:15 AM
Great stuff so far.  From experience before you glue the fuselage halves together make sure the nose fits with no steps on the sides.
    January 2003
Posted by yardbird78 on Monday, January 18, 2010 9:26 AM
Looks really good so far.  Keep us posted on your progress.
Darwin, O.F.  Alien
The B-52 and me, we have grown old, gray and overweight together.
    October 2009
Posted by Medicman71 on Monday, January 18, 2010 8:33 PM
Looks great already. Always look forward to seeing your builds. Gives me inspiration on my builds. Thanks.
Building- (All 1/48) F-14A Tomcat, F-16C Blk 30, He 129
Posted by Melgyver on Monday, January 18, 2010 8:38 PM
"Pit" looks good!  Don't forget the main gear needs to be moved forward 1/4 inch.
Clear Left!
Mel
    June 2009
Posted by figure freak on Monday, January 18, 2010 8:46 PM
this is an awsome aircraft and so far the cockpit looks nice.  My grandpa flew in one of these and the nose art was a donkey bucking and the name was Red$1***$2and it was a NMF bird
    December 2009
Posted by ww2psycho on Tuesday, January 19, 2010 3:16 PM
Very nice work. I just got mine in the mail today and will be doing planning for a bit. Too bad there isnt a group build for this, atleast I didnt see one. I can never keep to a schedual anyway. Great job keep up the good work.
    December 2008
Posted by New Hampshire on Tuesday, January 19, 2010 6:27 PM
Rock on Fermis!  Can't wait to see some more!
Brian
    January 2009
Posted by fermis on Wednesday, January 20, 2010 12:10 AM
 Thanks alot everybody.
Main gear will be moved, thanks Mel (I woulda missed that!!!)
Little progress, fuse is buttoned up, and tail is all chopped up to reposition rudder and elevators.
002-2.jpg picture by fermisb
 Little problem, discovered while test fitting the wings. Big gap at the bottom of right wing/fuse joint. Left side is just fine though!
001-2.jpg picture by fermisb
 A little sheet styrene, that luckily is just the right size fills it perfectly.
003-1.jpg picture by fermisb
 And replaced the molded in brake lines with wire from an old speaker cable.
004-1.jpg picture by fermisb
    January 2009
Posted by fermis on Wednesday, January 20, 2010 1:55 PM
 More ill fits!!!
 The left nacelle to wing joint has a big gap on the inboard side.(right nacelle fits OK)
005-1.jpg picture by fermisb
 So, after moving the gear forward(thanks again Mel!!!) I added some strips, cut from sheet styrene, to act as a spreader for the nacelle, and added detail. (the black dots are where the locator holes for the gear were)
006.jpg picture by fermisb
Worked like a charm!!!
007.jpg picture by fermisb
    January 2009
Posted by fermis on Friday, January 22, 2010 12:22 AM
 We've got power!!!! Engines are done, added some wires.
001-3.jpg picture by fermisb
 There is really nothing solid to mount the engines to. Just a step to the front of the cowling. The only points of contact are the front corners of the engine...BOOOOO!!!
002-3.jpg picture by fermisb
 So, I CAed a few bits of sprue to the cowling and engine backs. Without em, I think a small amout of pressure, (putting the props on) would have dislodged the engines.
003-2.jpg picture by fermisb
And the wing root fit is beautiful!!!
005-2.jpg picture by fermisb
    March 2006
Posted by simpilot34 on Friday, January 22, 2010 1:39 AM
Fermis you never cease to amaze!!! Love those engines!!! The whole build is looking great!!!Toast
Cheers, Lt. Cmdr. Richie "To be prepared for war, is one of the most effectual means of preserving the peace."-George Washington
    November 2003
Posted by tempestjohnny on Friday, January 22, 2010 5:38 AM
I like what  you did to fix the gap at the nacelle.  That idea can come in handy alot.
    December 2009
Posted by ww2psycho on Friday, January 22, 2010 2:14 PM
Very nice work, I cant wait to start working on mine.
Does anyone know of some small electric motors I can get to make the props spin? I'm planning on doing mine on a base with a rod attacked to it to make it looks like its flying.
    January 2009
Posted by fermis on Friday, January 22, 2010 2:42 PM
 I had gotten a few a while back, from radio shack. They were pretty big though, about an inch diameter. You could probably find smaller ones that would fit the center of those radials. Like a cell phone vibrator motor. Radio Shack may have em, if not, try a cell phone shop.
    December 2009
Posted by ww2psycho on Saturday, January 23, 2010 12:04 AM
Hey Fermis, on the nose bulkhead, was there an chunk of plastic on that back thats not suppose to be there?
    June 2008
Posted by Hans von Hammer on Saturday, January 23, 2010 7:06 AM
Outstanding work so far, mein Freund..  I love that kit.  Still have one (way back) in the pipeline, although I don't know when I'll get into it, since I usually have to get a case of "Multi-engine fever" to start building those birds... THEN, I'll likely have a two or three twins going on at once (I got another Monogram B-25, B-26 Marauder, and A-26 starin' at me from the shelf) ...
Haven't had a touch of it since Tiny's B-17 GB... Hopefully, I'll come down with a bout of it before summer..
As for finishing it, you said earlier you might do the boxart or may make something up..  Would the "Made-up" version (if you choose that) be a USAAF Havoc or (hint) perhaps an RAF or RAAF Boston ( I always liked the RAF camo for these aircraft) instead?
Whistling
    January 2009
Posted by fermis on Saturday, January 23, 2010 8:53 AM
Thank Hans, the finish is goona be US, Swanny is sending me some pyn-up decals, so I'll do an actual bird. Simple OD and grey.
Psycho, that big hunk of plastic is burried bihind the IP. If it's supposed to be there or not, I have no idea. Iy's burried behind the IP and won't be seen, and does not get in the way at all.
    June 2008
Posted by Hans von Hammer on Saturday, January 23, 2010 9:09 AM
Simple OD and grey.
Ah... Nothing wrong with a KISS-finish either, heh...
    January 2009
Posted by fermis on Saturday, January 23, 2010 10:29 AM
That's the way I like em!!!! And I live by that!!!(KISS)
    December 2009
Posted by ww2psycho on Sunday, January 24, 2010 4:05 PM
Hey fermis, got another question for you. I'm planning on making mine with bomb bay doors open, but the instructions dont do a good job of showing exactly how high up to mount the bomb rack. any idea?
    January 2009
Posted by fermis on Sunday, January 24, 2010 6:08 PM
 I have no idea about the bomb rack. Never bothered with one on an A-20.
    March 2006
Posted by simpilot34 on Sunday, January 24, 2010 7:16 PM
Just make sure you have plenty of ammo for all the guns though!!!!!!Yes
    January 2009
Posted by fermis on Tuesday, January 26, 2010 10:59 AM
Started the finishing process.
Here's the reason for my method. s s *report me* cheapo testors s s *report me*/B from Wal-Mart. It only offers s s *report me* little more control than s s *report me* rattlecan. Smallest spray that I can get out of it is about 1/2 inch diameter. You can use this method with s s *report me* rattlecan or even if you use s s *report me* brush.
004-2.jpg picture by fermisb
First, I s s *report me*/Bed MM neutral grey straight(just thinned for s s *report me*/B)
001-6.jpg picture by fermisb
I use s s *report me* piece of sandpaper as s s *report me* palette for pastel powder, just gring it down.
002-6.jpg picture by fermisb
I then work the powder into the panel lines, lightly.
003-4.jpg picture by fermisb
For s s *report me* model of this size, I use s s *report me* 5/0 brush, for drybrushing.
004-4.jpg picture by fermisb
I drybrush randomly, mostly just over the powder, using the same paint as the s s *report me*/B. Left side had had first D/B, right has not.
005-4.jpg picture by fermisb
For the second D/B, I add s s *report me* fair amount of white to the grey. With this, I try to brush mostly with the airflow to get s s *report me* bit of streaking, then randomly over the panels. Left wing and fuse have second D/B, right wing and nacelle just the first.
006-1.jpg picture by fermisb
Once the senond D/Bing is done, I leave it alone til green is done and decals, clearcoats.
More to come.
    January 2009
Posted by fermis on Tuesday, January 26, 2010 11:02 AM
Re: RE:AMT s s *report me*-20 wip
What the hell's *report me* all about????????
    May 2005
Posted by Bgrigg on Tuesday, January 26, 2010 12:06 PM
The nanny program went berserk and decided "a" was a bad, bad word.
So long folks!
    January 2009
Posted by fermis on Tuesday, January 26, 2010 12:35 PM
HAHA, I'll have to keep that in mind and find a substitute!!!
    June 2008
Posted by Hans von Hammer on Tuesday, January 26, 2010 3:27 PM
Hey... How about we we ALL report him?  Maby that'll shake things up at the Headshed... Besides, abuse works two ways..
EDIT: Done.. I wrote, "Turn off the nanny-bot, guys... It's gone insane and thinks the letter, 'a' is a bad word... Frankly, It's *Report me*-ing everybody off...
    June 2008
Posted by Hans von Hammer on Tuesday, January 26, 2010 3:58 PM
Looks like it got fixed...
Posted by Butz on Wednesday, January 27, 2010 12:19 AM
 I am really liking what I am seeing here my friend!! I especially like the office and the engines. A question on your pastel weathering, did you gloss coat it first or go straight over the finish?
 Looking forward to seeing her finished!!
Flaps up,
Rangers Lead The Way
  If you would listen to everybody about the inaccuracies, most of the kits on your shelf would not have been built Too Close For Guns, Switching To Finger
