AMT A-20 done(dio)
    January 2009
Posted by fermis on Wednesday, January 27, 2010 9:28 AM
Thanks Butz!
 The pastels have to be done on a flat surface, as they don't stick to gloss well.
    March 2006
Posted by simpilot34 on Thursday, January 28, 2010 8:47 AM
Fermis she is looking great mate!!!!! Love your technique with the pastels!!!
Cheers, Lt. Cmdr. Richie "To be prepared for war, is one of the most effectual means of preserving the peace."-George Washington
    July 2007
Posted by troublemaker66 on Thursday, January 28, 2010 6:13 PM
Amen Brother! The carcass of my 1st A-20 attempt stills rests atop my paint booth and is used for testing new paint techniques, etc. because of exactly what you stated...screwed it up beyond repair trying to fix the afore mentioned step in the nose. The good news...I have another one in the stash!
Len Pytlewski
    July 2007
Posted by troublemaker66 on Thursday, January 28, 2010 6:31 PM
Hi Fermis, What kind of brush or instrument do you use to paint all the detail in your cockpit?  Or do you do it the way I try to do it...the old Pro Modeler painting tip way...paint the instrument panel gloss white or gloss yellow then flat black. Then use a # 11 blade and scrape the black off of the dials? I really like the way yours came out and any tips or tricks you could throw my way would be appreciated!  Thanks...Len
Len Pytlewski
    January 2009
Posted by fermis on Thursday, January 28, 2010 10:46 PM
 Thanks Sim and Len.
 Len, I sprayed the IP flat black(rattlecan), then just painted all the details with a little brush. No real "tips or tricks", just a steady hand  and a tiny brush. Testors clear glue for the instrument faces.
    January 2009
Posted by fermis on Friday, January 29, 2010 10:15 PM
 Time for some green.
All the grey is masked over and ready to go.(masking tape and poster tack for the edges)
001-7.jpg picture by fermisb
And, she's green!
002-7.jpg picture by fermisb
black pastel powder.
003-5.jpg picture by fermisb
First drybrushing (half and half)
004-5.jpg picture by fermisb
Really looks like hell!!!!
005-5.jpg picture by fermisb
Second drybrushing(again half and half) Still really looks like poop, but the clearcoats will take care of that later!!!
006-2.jpg picture by fermisb
007-1.jpg picture by fermisb
    December 2009
Posted by FastEagle1 on Friday, January 29, 2010 10:32 PM
Fermis,
Great work so far.  Your pastel technique is very convincing and the engines and cockpit are simply supurb!
Oh, one more thing - I saw your "Man Cave" posted on another thread.....dude, that's sweet!!!
Peace, out.
    March 2006
Posted by simpilot34 on Saturday, January 30, 2010 12:57 AM
Looking great Fermis!!!!Bow Down
    January 2009
Posted by fermis on Sunday, January 31, 2010 11:31 AM
Thanks FE1 & SP!!!
 Thanks to Swanny(for sending some mkgs) this bird has a name and a face,(Dinah-Mite was actually a "B" model not a "G", but that don't bother me none!!!) Also note the turned nosewheel.
011-1.jpg picture by fermisb
 The tail #s(17) was large enough to be easily painted, so I masked it off and painted it by drybrushing several times.
010-1.jpg picture by fermisb
I also masked and painted the wing walkways and non-slip surface.
009-1.jpg picture by fermisb
You can see how the dullcote(Testors rattlecan) blends in all the drybrushing.
012-1.jpg picture by fermisb
One thing that always bugs me (just a little) is to see an offset rudder with a straight nosewheel(or tail wheel for that matter). So, I cut out the oleo, drilled some holes and replaced it with a finish nail, cut to size.
001-8.jpg picture by fermisb
And a few other details. Props are weathered and ready to go. I drilled out all the holes in the rear canopy part and painted the inside framework  and liferaft(True Details) In hindsight, There really is no need for the resin wheels and liferaft, the kit wheels are decent, already "weighted", just need to sand down the tread a touch, and a rolled up liferaft would be a very simple scratch. I got the kit for $5, what's another $2.50 for some resin?!!!
013-1.jpg picture by fermisb
 Cheers!!!
    March 2006
Posted by simpilot34 on Monday, February 1, 2010 1:10 AM
Fermis that is some great work!!!! Loving everything about this build!!!Toast
    January 2009
Posted by fermis on Monday, February 1, 2010 9:57 AM
Thank again Sim!!!
 Haven't made much progress on the plane. Been focusing on the figs.(If I finish the plane, it'll go straight to the shelf and on to the next). Planning a little dio, simple base with a bit of ground work(grass and some weeds just), ground crew getting her openned up, ready to go.
 Here's the basic layout. Figs are a mix of Monogram and Eduard.
032.jpg picture by fermisb
This guy up front openning the canopy.
033.jpg picture by fermisb
This guy lifting the turret cover(coming later) so the two guys on the ground can pull it off.
034-1.jpg picture by fermisb
Any tips or suggestions are welcome. I haven't done much dio work at all!
Here's the final pic of the nose gear with new oleo.
036-1.jpg picture by fermisb
Scratched the antenna(sheet styrene) and loop(wire wrapped around a brush handle)
035.jpg picture by fermisb
    December 2009
Posted by ww2psycho on Monday, February 1, 2010 4:15 PM
Thats some really good work there. I'll have to try some of your tricks sometimes.
Unfortunatly my A-20 is put on hold as I have adopted a 1 year old pug, so she will be getting most of my attention for a bit.
    March 2006
Posted by simpilot34 on Tuesday, February 2, 2010 4:11 AM
Fermis, That ,again, is looking AWESOME!!! Just looks "RIGHT"!!! Mate of mine built a 1/32 F-14 and used cut off drill bits for his oleos. I must say, after seeing it in person, was just speechless!!! IT ACTUALLY HAD THE MOST REALISTIC HYDRAULIC RAM EFFECT I HAVE EVER SEEN!!!!!!!! When you use real metal to achieve the metal look......need I say more? You r nose oleo is spot on!!!!Toast
    January 2009
Posted by fermis on Wednesday, February 3, 2010 9:54 AM
 Awe, come on Psycho, put the dog in the kennel and get building!!!!!
Sim, believe it or not, I first tried to cut off the end of my drill bit ti use for the oleo, couldn't find my hacksaw and the steel bit I had in a skillsaw didn't even scuff the drill bit. The nail is a touch undersized, but close enough for me!!!
 Got the figs all done and painted up, using Testors enamels.
I wanted the pilot figs to have wool lined flight jackets(I love them things!!!). So, Monograms pilot figs needed altering. I used testors clear glue around the cuffs and collar and skrinkled on some model RR turf.
001-9.jpg picture by fermisb
I thinned some white(half n half, paint/thinner) and touched it to the "wool", allowing capilary action to pull it through the wool.
002-8.jpg picture by fermisb
This worked so well, I just left it as is for final painting. I copied a couple ref pics that I took a few years ago at a local airshow.
009-2.jpg picture by fermisb
I added the rest of the straps for the May West using thin strips of Tamiya tape.
010-2.jpg picture by fermisb
And the rest of the guys all painted up.
003-6.jpg picture by fermisb
004-6.jpg picture by fermisb
005-6.jpg picture by fermisb
006-3.jpg picture by fermisb
007-2.jpg picture by fermisb
008-2.jpg picture by fermisb
  Now, I'm under the gun, there is a local(ish) contest comming up on Saturday. The last three shows I've gone to have seen a build finished late the night before or in the wee hours the morning of. Three days!!! I aint scared!!!
    June 2008
Posted by Hans von Hammer on Wednesday, February 3, 2010 10:21 AM
Gonna need a step-ladder or workstand for those ground-guys up on the aircraft...
    January 2009
Posted by fermis on Wednesday, February 3, 2010 10:44 AM
I forgot to mention a ladder, and figured you'd be the first to catch that Hans!!!
 It's in the plans, I'm also gonna scratch a couple ammo crates. Maybe a couple fuel/oil drums off in the corner somewhere also.
    June 2008
Posted by Hans von Hammer on Wednesday, February 3, 2010 11:12 AM
Heh, just keepin' ya honest, my friend...   Toast
I did something similar, posing the armorers transferring 20mm linked from the crate to the mags for my Tigercat while a couple more were hand-pumping fuel into the left wing tank from drums.... Used the Tamiya 1/48th fuel drums an' a scratch-buit pump & hose assy with solder fuel hose...  Didn't get to finish it though...  My housecat knocked out my Tigercat...
    December 2009
Posted by ww2psycho on Wednesday, February 3, 2010 5:26 PM
Hey Fermis, I'm hoping to get the fusalage together this weekend. Did you cut off the machine gun barrels before masking the turret?
    January 2009
Posted by fermis on Wednesday, February 3, 2010 9:19 PM
ww2psycho
I never installed the guns. Then I lost them. I just used some wire for the barrels. With a cover on it, you wouldn't see the guns anyway. I'll have more pics up in the A.M.
    March 2006
Posted by simpilot34 on Thursday, February 4, 2010 12:38 AM
Hans? The cat still kicking? lolPropeller
    June 2008
Posted by Hans von Hammer on Thursday, February 4, 2010 5:08 AM
Technically... I made a pair of slippers out of him...
    January 2009
Posted by fermis on Thursday, February 4, 2010 8:48 AM
Hans von Hammer
 Awesome!!!!! One of the many reasons I won't ever have a cat. Evil little bastards!!!!
 Got a bunch of work done last night.
  As promised, details on how I make a turret cover.
 I started by thermo-forming the top piece.
012-2.jpg picture by fermisb
I cut it off around the edges of the fuselage and up high, where the crewman will be lifting it up. I cut an eye shape out of alum foil.
013-2.jpg picture by fermisb
I cut the foil in half, to make it easier to work with. It's a real PITA because everything is so flimsy. I then cut out the middle portion, about  1/8" inside the ring, and cut little tabs to glue inside the top(thermoform)piece.
014-1.jpg picture by fermisb
015-1.jpg picture by fermisb
After doing the other side, I stuck in my wire gun barrels(lost the real guns, bent wire to a "U"shape. I used small rectangle pieces of foil to make the gun sleeves, and built up glue where they meet the main part of the cover. I painted the inside, and added some fibric "ripples" with testors clear glue.
001-10.jpg picture by fermisb
After painting, some more riplles were needed.
003-7.jpg picture by fermisb
Installed!
006-4.jpg picture by fermisb
For the rest of the dio work, I'm gonna start a new thread over in the dio section. Hope to see you there!!!
    FERMIS
    June 2005
Posted by Lancair IV on Thursday, February 4, 2010 9:18 AM
WOW Fermis.  WOW....  You are a master.  Wish I would have seen this from the beginning.
Cheers
Rob Byrnes
Novi, Mi
    June 2008
Posted by Hans von Hammer on Thursday, February 4, 2010 12:02 PM
Actually, I like cats better'n dogs... Low maintenance, much quieter, practically born housebroken, vermin-killers, and EVIL little bastards...
It's just THIS particullar evil one I don't like much...  He's too high-strung and gets wound up at the drop of a hat.. But that'll change soon enough when he goes to the vet and I gets his marble-sack emptied...  Then he'll get fat & lazy like the th' other one I made a slipper out of..
    January 2009
Posted by fermis on Thursday, February 4, 2010 12:45 PM
 But they still poop in your house!!!! If anybody poops in my house, it's gonna be me!!!!! My dogs go off into the woods, I don't even have to clean up the yard!!!! If you like cats, that's OK, I aint mad atchya!!! I just haven't met one that I liked yet.
    June 2008
Posted by Hans von Hammer on Thursday, February 4, 2010 1:07 PM
Heh... Druther have the cats poopin' in m' house than the dog or the wife passin' gas... (I got one each of them, too... An audibly flatulent pug with digestive problems and a wife that doesn't react well to my chili...)
If I was so inclined, I could buy a self-cleaning litter box...  Can't even get the wife to shut the bathroom door anymore..
    January 2009
Posted by fermis on Thursday, February 4, 2010 1:14 PM
 Oh, that makes me laugh!!!! I'm pretty immature and find farts to be about the funniest thing on earth!!! All my friends have changed "Fermis" to "Furnace" on account of all the hot air being blown out!!!!!
   SICK!!!!!!
     Furnace!!!
    March 2006
Posted by simpilot34 on Friday, February 5, 2010 1:26 AM
Furnace that is some great work Mate!!!!! Sorry couldn't resist!!Propeller
    January 2009
Posted by fermis on Friday, February 5, 2010 8:59 AM
Much thanks again SIM and Rob!!!
 I got her all done last night, all the dio work is over in the dio section, but since her came into life over here, I'll finish her off over here as well. A couple things could have been a bit better, mainly with the base, but whatever, I learned a thing or two......baby steps!!!!
012-4.jpg picture by fermisb
011-4.jpg picture by fermisb
010-4.jpg picture by fermisb
009-4.jpg picture by fermisb
008-4.jpg picture by fermisb
007-4.jpg picture by fermisb
006-5.jpg picture by fermisb
005-8.jpg picture by fermisb
004-8.jpg picture by fermisb
001-11.jpg picture by fermisb
Added a touch of smoke to the "Brass" and pilots cigs with a bit of stuffing from an old comforter.
002-10.jpg picture by fermisb
003-8.jpg picture by fermisb
B'DEE B'DEE B'DEE....That's all folks!!!
    August 2004
Posted by a6m5zerosen on Saturday, February 6, 2010 10:53 PM
Pretty awesome baby steps-I would be OVERJOYED if anything I ever built turned out this well...
"no, honey, of course that's not another new model. I've had that one for a long time..."
