B-1B Hard Rain; 85-084
    October 2007
Posted by pordoi on Monday, January 17, 2011 5:02 PM
For those of you who don't follow the Group Build forum, below are some photos of a modern B-1B that I built over the last 7 months as part of the Variable Geometry: the Swing Wing GB.  The kit was a real bear with fit issues with the three fuselage parts and problems with the wings that forced me to glue them in the extended position.  The model represents B-1B 85-084 based in Ellsworth AFB (using the TwoBobs decal sheet) and served (or is still serving) in Afganistan.
The base kit was the Revell 1/48 B-1B, which has been reissued several times in essentially the same form; a B-1B from the SAC strategic bomber era that is supplied with a nuclear payload. It's a huge kit; fuselage length and wingspan are both approximately 36 inches (~0.9m). To update the kit to a more modern Bone, I scratch built a rotary dispenser for the fore bomb bay, and two tactical munitions dispensers (TMD) for the center and aft bays. ShawnHull JDAMs and cluster bombs were added to the fore and center bay, respectively, while the aft TMD was left empty.
Other mods include the addition of a ShawnHull towed array and sniper pod, the addition of the vortex generators (from Evergreen sheet), Eduard interior and exterior details sets, Hasegawa figures for the aircraft Commander, co-pilot and the DSO climbing the crew ladder, and scratch built wing shrouds covering the wing retraction mechanism. The cockpit detail is hidden and the bomb bays will need a mirror to see, but for those of you who have too much time on your hands Big Smile, the complete WIP is documented in the Swing Wing GB forum and includes photos of the cockpit, figures and rotary and TMD dispensers. Here are some photos:
Please feel free to comment and criticize.
Don
    August 2009
Posted by Sparrowhyperion on Monday, January 17, 2011 5:58 PM
Beautiful build.  I assume that the reason for having the wings extended was because it's a gear down configuration.  One little thing though.  I don't know if it's the lighting or what but my eye keeps drifting to the port inboard engine.  It just looks a bit lower than the outboard one in the pod.  I love the detail in the bombay.  All in all it's a million times better than any of mine will come out nowadays. :)
Rich
In the Hangar: 1/48 Hobby Boss F/A-18D RAAF Hornet,
On the Tarmac:  F4U-1D RNZAF Corsair 1/48 Scale.
    June 2009
Posted by STFD637 on Monday, January 17, 2011 6:32 PM
Don! Great job on the "BONE!" You are truely a master!Bow Down And in 1/48 it must be huge!!!! I have been looking for one in 1/72. for my collection. I love the use of the JDAMS and Cluster mix. adds a little more interest to it. Great job.
Travis
"If a lie is told often, and long enough, it becomes reality!"
Travis/STFD637
make an avatar
    January 2010
Posted by Klik on Monday, January 17, 2011 9:08 PM
Gorgeous work!
It's funny that the kit is for a Nuclear-capable Bone, when all modern B-1s lack nuclear capability (shame).
keep up the good work!
oneyearwar1
The hardest part of flying isn't flying...it's landing.
Posted by Butz on Monday, January 17, 2011 9:19 PM
Howdy Don,
 First off, gotta love the B-one..!! Secondly, georgous work over all on a rather non forgiving kit!! The over all build is spot on but I have one question... I can not tell by the pix but did you do a panel wash? Like I said, it is some what hard to tell but I think it would look striking with a wash of a slightly darker gray.
I remeber seeing a few of these @ my LHS thinking WOW, check out the size of the box...
 Mmmm maybe one day I should grab one if I see it on the shelfStick out tongue Thank you for sharing
Flaps up,
Rangers Lead The Way
  If you would listen to everybody about the inaccuracies, most of the kits on your shelf would not have been built Too Close For Guns, Switching To Finger
    May 2009
Posted by Andrew Magoo on Tuesday, January 18, 2011 3:00 AM
I was born and raised in Newcastle, Wyoming, its about 54 miles almost due west of Rapid City, South Dakota. The 28th Bomb Wing B-1Bs would fly over Newcastle and surounding area frequently and at times practicing their low level radar avoiding runs. Ellsworth also hosts an air show about every other year and I use to attend every chance I got. I now live in Riverton, Wyoming and don't get the enjoyment of seeing, hearing, and going to an Ellsworth air show just so I could watch those beautiful B-1B s roar down the run way , over head, and for the croud almost break the sound barrier, but I'm here to tell you; you did the 28th Bomb Wing proud! An excellen job. Magoo
    February 2007
Posted by Buckeye on Tuesday, January 18, 2011 6:21 AM
Very nice build!  The figure on the boarding ladder really adds to the scale.Yes
Posted by rjkplasticmod on Tuesday, January 18, 2011 9:07 AM
Very nice Build Don Yes.  Thanks for sharing.
Regards,  Rick
    October 2007
Posted by pordoi on Tuesday, January 18, 2011 12:04 PM
Thanks all!
Sparrowhyperion:  the wings are extended because the swing joint failed after I glued the fuselage halves together.  That gave each wing a little vertical play at the joint and the weight of the wings eventually  stressed the fuselage seam to the point that it started splitting.  So I glued the wings permanently in the extended position to strengthen the joint.
I think that the inboard engine looks lower due to distortion in the photo.  I don't think that it looks that far off on the model.  If it is, it will just have to stay that way  Smile
Butz:  I did not do a panel wash; I didn't want to do anything that might highlight the panel lines because I think that they are overdone to begin with.
Andrew, I chose to build this kit after a similar experience watching B-1B flyovers at Thunder over Louisville last Spring.  They are impressive aircraft, especially with the afterburners fired up.  Talk about loud.
Don
    December 2003
Posted by hkshooter on Tuesday, January 18, 2011 12:53 PM
Klik
Since when?
    January 2010
Posted by Klik on Tuesday, January 18, 2011 2:37 PM
hkshooter
 Klik:
Since when?
Since the end of the cold war. The B-1 is so stealthy, and has such a long range, that it scared the former Soviets that it was nuclear-capable, so one of the stipulations of a treaty between us and them was that all B-1s be downgraded. Please Correct me if I'm wrong, I've only got hearsay from an AF Captain who used to do maintaince on them as an Enlisted man.
By the way, I went up to Ellsworth over the summer, and saw the Bones up there practicing touch and goes all day. Impressive, considering that we were only a half-mile from the runway. In Colorado, they've got one on permanent display at Lowry, where they used to train technicians to repair them. When Lowry was decommissioned, they left the "practice" Bone and turned the hanger into a museum, Wings over the Rockies.
oneyearwar1
    December 2003
Posted by hkshooter on Tuesday, January 18, 2011 3:01 PM
Interesting. I was not aware that the B-1's were no longer nuke capable. Seems to me they could load a rotary with nuke cruise units and blast away fairly easily. It's not something I know a lot about though, your statement piqued my interest, new news to me.
Posted by Gamera on Tuesday, January 18, 2011 3:19 PM
Nice! I've seen the gigantic box at shows but I think this is the first time I've seen a built-up 'bone'.
Absolutly first-rate job! Great subtle weathering, love the work you put into the gear and weapon bays, and the figure gives a great sense of scale to her.
    October 2007
Posted by pordoi on Tuesday, January 18, 2011 3:31 PM
hkshooter
Current loadout can be found here:
http://www.targetlock.org.uk/b-1/weapons.html
Before START, the B-1B could carry 24 SRAMs, eight in each bay on rotary dispensers.  The bulkhead between the fore and mid bay was removable to accommodate cruise missiles, and there were external hardpoints that could also be loaded with cruise missiles.  START mandated that these planes be converted to conventional heavy bombers, the removable bulkhead was not continued and the external hard points were removed.  But it is likley that B1s could be quickly re-modified to carry nuke again if necessary.
Don
