The Sky Samurai (1/48 Hasegawa A6M2 21 Zero)
Posted by Gamera on Wednesday, July 25, 2012 7:59 AM
Great looking work!
You might try a light misting of your base colour over the decals to fade them down a little.
    April 2005
Posted by JohanT on Wednesday, July 25, 2012 8:45 AM
Well, that did set the scene allright :)
Awesome work on that cockpit and engine!
The pre shading looks very convincing too.
They have the cockpit section of a Zero on display in the IWM London.
IRL it is so petite it is plain obvious that I could never get my 183cm 110Kg in there.
I wonder if I still have that photo around somewhere...
Thank you for sharing and please keep us up to date with your progress.
Very Best Regards
Johan
    February 2012
Posted by lawdog114 on Friday, July 27, 2012 8:02 PM
Well, I'm in the home stretch now.  I painted the blue stripes and must say I'm happy with the way they turned out.  The Fuselage stripe was kind of a pain in the Censored to get the angle right when compared to the decal reference sheet, which was further complicated by me trying to make sure the upper and lower angles were centered.  Kudos to Tamiya tape...no bleeding.  The wing walk boxes continue to haunt me.  During fuselage stripe taping, I accidentally caught a piece of the tape on the starboard front strip and it tore a chunk out Bang Head.  So I scraped the rest off the front on both sides.  I may end up ripping up the rest and painting them in after all.   The panel lines were then washed with Windsor Newton acrylics.  I'm more partial to water based washes because there is room for error.   I just finished the landing gear.  I decided to use the kit wheels instead of the TD set.  The TD example just seemed a bit small and out of scale to my eye.  My method for painting wheels is fairly painless and if you hate doing this, try this technique:
1.  Prime the wheels then spray the hub the appropriate color for that plane (silver, black, whatever..)
2.  Purchase a dark grey enamel that will simulate real rubber.  Make sure it is enamel so it will be compatible with mineral spirits as you will see shortly.  I use Floquil Grimy Black which is a nice dark grey.
3.  Use a plastic paint palette with the concave dimples (Hobby Lobby sells them cheap) and put some of the aforementioned  mineral spirits in one dimple (lack of better terms?) and the black paint in another.
4.  Take a fine pointed paint brush of your choice with some spirits and touch the rim on the wheels side.  Capillary action will carry the fluid around the rim.  You may have to repeat this.  Make sure its mineral c, anything stronger, such as lacquer thinner, may eat into the paint on the rim.  Ask me how I know this...
5.  Then dip it in the black which will then carry around the color in the already present spirits.  Again, you may need to doing this a few times to build up the color.  You now have a good starting point to bring the paint out to the rest of the tire and if you be patient, the result is a perfect rim.  I suppose you could use any enamel, but I  Floquil Grimy Black because it goes on nice smooth and there are no brush marks when dry.  I usually slightly thin it with the spirits but this is not necessary
6. For weathering, I take some diluted Tamiya Buff, crank down the air pressure to about 5 psi, then spray the treads to simuluate wear, dirt and dust .  Some people dry brush this with neutral grey or such, but I prefer this method.
This techinque is easier than it sounds.  I want to say I read about a similar  technique years ago in FSM where someone was painting tank wheels and I have been using it ever since, of course modified to fit my needs.
There ya have it, use freely and I hope it will help people who loath painting wheels (I happen to dread canopy taping...)
Joe
    December 2011
Posted by Luft Modeler on Friday, July 27, 2012 8:11 PM
Joe I wish my models looked as good as the way this Zero is sitting there! Again keep up with the great work! Also what glue are you using to secure the canopy to the fuselage?
    February 2012
Posted by lawdog114 on Friday, July 27, 2012 10:30 PM
pzl66
Thanks for the compliment!..  I normally use Testers clear parts cement in the goofy looking triangular bottle.  I sometimes use good old Elmer's Glue too.
    April 2009
Posted by Cadet Chuck on Friday, July 27, 2012 11:19 PM
Lawdog114:  390th BG?  Then you must be familiar with the 390th BG Memorial Museum in Tucson.  I am a member and send them a contribution every year.  I learned about them when I took a ride in the B-17 Liberty Belle in Georgia back in 2006. Quite a wonderful experience!
Chuck
    February 2012
Posted by lawdog114 on Saturday, July 28, 2012 12:25 AM
Cadet Chuck
Chuck
Hey Chuck, I am familiar with the 390th museum.  Unfortunately I live in a suburb of Cleveland, Ohio, otherwise, I would go there often.  As I said, my grandfather was a turret gunner in the 570th.  I built an almost exact replica of the plane he was shot down in and their web site was instrumental in my research.  I typed in his name and received a plethora of information about his combat history.  They actually had pictures of the nose art in their gallery section which I used to have decals made.  Its Funny, I offered to build them a J group B-17 free of charge to display but they turned me down. The lady was kind of rude about it too....oh well.
Joe
    May 2012
Posted by Old Ordie on Saturday, July 28, 2012 1:50 PM
pzl66
Joe I wish my models looked as good as the way this Zero is sitting there! ...
Ditto (aka "ditto" ...)
Joe,
The Zero is looking great!
I'm painting some wheels later today, so you're tip is right on time.  I was going to try my hand at cutting some perfect circles out of masking tape, but I wasn't looking forward to it.  Now, I don't have to ... and I just happen to have a bottle of Floquil Grimy Black on hand.  Thanks!
Smile
Flight deck:  Hasegawa 1:48 P-40E; Tamiya 1:48 A6M2 N Type 2 ('Rufe')
Elevators:  Airfix 1:72 Grumman Duck; AM 1:72 F-4J
    February 2012
Posted by lawdog114 on Tuesday, August 7, 2012 12:14 AM
Hello all...I'm finally done!  Have you ever had one of those kits that in theory should be a piece of cake...but challenged you from start to finish;  whether it be the kit's fault or just your own ineptness?  Well,  this one tried my patience and often.  First the warpage in the wing and fuselage, then the wing walk decals, the latter being minor but still annoying. I eventually had the plane completely assembled and commenced to do some minor post shading and weathering before display.  Just as I was congratulating myself, the plane slipped out of my hand and crashed onto the desk.  The cowl, engine, fuel tank, and all canopies pieces came off.  The starboard landing gear and antenna post also snapped off.  Angry did not even describe it Angry.  After a few deep breaths, and a game of Madden 12 (to prime myself for the upcoming 13), I reconvened at the desk.  Fortunately I was able to fix it and for all intents and purposes, you can't tell it happened.  Gorilla Glue took care of the gear and as good fortune would dictate, I had learned that Sakai's zero did not have an arial wire, so the post was apparently sawed off at the rear canopy.  I followed suit.
The figure is from the Hasegawa pilot set, which comes with American, British, Japanese and German pilots.  I'm not impressed with the detail on these, which is soft.  In my opinion, I wouldn't waste your money and just use figures from Monogram or ICM kits which are much better.   I have no experience with other brands, such as Verlinden or Legend.  I'm a particularly lousy figure painter but I like to add them for a sense of scale.  For those who are curious, I use brush painted Tamiya Acrylics and enamel Model Master Dark Skin Tone (i think thats what its called) for the flesh areas.  After a drybrushing with lighter versions of the original color on the clothing, its then sealed with a clear coat and washed to bring out the detail.  The base is real dirt glued down with Elmer's glue.  The grass is a scenic railroad  product which I airbrushed to make it appear dried out from the Pacific climate.
I have been experimenting with my wife's camera in Macro mode.  It should also be noted photography is not one of my talents.  With some advice I've read, I decided to try using a background other than my work bench.  Some of the pics are with a white posterboard, others with a light blue one.  They both look ok to me and I cannot decide which looks better.  The blue came out almost grey.  Opinions are welcome.  Here she is...
Joe
Posted by jeaton01 on Tuesday, August 7, 2012 12:32 AM
Looks real good, Joe,
The painting on the figure looks fine, but I see what you mean about the softness of the features.  Except for the uniform he might be taken for a Tuskegee Airman.
John
    May 2012
Posted by Old Ordie on Tuesday, August 7, 2012 2:45 PM
Joe,
Another great build, and a nice presentation as well.  A fine tribute to a true sky warrior.
I have a question about the xf-76 paint:  Which shade do you think best represents the actual color to the eye, in natural light, real time:  the top one below (looks more tan to me), or the bottom one (looks more green ...)?  I know what lighting can do to color in a photo, which is why I'm asking.
    February 2012
Posted by lawdog114 on Tuesday, August 7, 2012 10:56 PM
Thanks for the compliment Mark! You raise a good question.  The top photo is with a light blue poster board background and the lower is with a white one.  As I said, I was experimenting with my wife's camera and I have no really working knowledge of how photography works.  Aperture....shutter speed,,...yadda...yadda....blah....blah..  I just decided to play around and see what looked the best to my eye.  I used macro mode with these which supposedly makes the detail pop out.   One think I did notice was that the posterboard reduced the glare on the wings, which I find appealing.  I'm leaning towards the white background for future builds.  These pics are without the posterboard background.
Joe
    April 2005
Posted by wing_nut on Wednesday, August 8, 2012 7:16 AM
That color shift in the plane is likely due to using the AUTO setting for the color balance. Essentially each of these situations has just 2 colors.  The background and the plane.  The camera computer is trying to come up with a balanced image based on what the chip is programmed for “normal”.  The one with the white background has less to “shift” the blue one does.  It is also why in many cases the pics taken with the workbench background look better since there is a lots of different colors in the shot so when that averaging is done is will shift any one single color less.
Try setting the color balance to match the light source.  Many cameras have a choice to set the “white balance” manually.  It involves taking white background, pointing the camera at it so it fills the field of view and pressing a button.  This will white balance for whatever light source you are using and can be used no matter what the background color is without worrying about color shifts.
And sorry for not saying this 1st… but nice looking Zero.
Marc
    May 2012
Posted by Old Ordie on Friday, August 10, 2012 5:59 PM
Joe,
Yeah, the most recent photos look in between to me (but more green, less tan), and real, real good.  I'm gonna get me some of that paint for some of my (ta-da!) upcoming IJN builds.  Thanks!
wing_nut - I gotta find that white balance thing on my camera.  Thanks for the tip!
    April 2005
Posted by wing_nut on Friday, August 10, 2012 7:27 PM
Dunno how standard the icons are but an 2 cameras I have this is the icon for setting the white balance.  the whiter the background piece you use to set it the better.  And of course.... do it with the light source you are about to take your pics with.
Marc
    February 2012
Posted by lawdog114 on Friday, August 10, 2012 11:18 PM
Thanks!  I'll try to find it on my camera.  its a fancy one so I'm sure this option is in there somewhere.
    August 2012
Posted by Winetanker on Friday, August 24, 2012 10:07 PM
Nice Build, lawdog....
Just re-read Samurai this summer. I had no idea there were so many P-39's in Port Moresby.
....working my way up the airbrush learning curve......
