I know there is an older Heller kit of teh French Mirage IV - has anyone seen any other options?
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
The Heller kit in 1/48!
Either way, they are both elderly kits - raised detail, not that much in the box & a few issues. I did the 1/72 a while back & wished that I'd gone 1/48th - 1/72 just doesn't seem to do the IV much justice at all.
There are (were) a few extras available for the 1/48 kit.
WWW.AIR-CRAFT.NET
Soooo Heller, or Heller... ;) I'm not put off by the raised lines, especially if it's the only way to get the machine. More looking for options in case it gets hard to track one down. Wonder if any of the eastern-European companies have re-release it?
Hmmmm - in 1/48 also...
Did I mention that Heller did one?
I couldn't find a 1/72 at the time & went fleabay on it - it was warped & the decals had seen better days, but I see that both new 1/72 & 1/48 are currently available.
It's a georgeous bird even if it was a one way ticket & to my eye the best looking Mirage out there (well except possibly the 4000). Some links to get you in the mood , all 1/48 but interesting all the same;
http://www.modellversium.de/galerie/8-flugzeuge-modern/4610-dassault-mirage-iv-heller.html
http://www.britmodeller.com/forums/index.php?showtopic=41754&mode=threaded
http://www.arcair.com/Gal2/1201-1300/Gal1233_Mirage_Aibara/00.shtm
http://www.aircraftresourcecenter.com/Gal4/3901-4000/Gal3958_MirageIV_Whitehouse/00.shtm
I try to keep my jets in the 1/72 zone due to display space, but I wouldn't say no to a 1/48 version if there is a deal to be had.
Wow, that build at Modelversium is really sharp. I like the smaller scale, but I'd have a better shot at scratchbuilding details in 1/48. Decisions decisions. Need to do some searching when I'm clear of the office "internet fun-filter", see what I'm looking at $$-wise.
BTW, thanks for the info Milairjunkie!
Check out the new High Planes one in 72nd...
Nice! But the Mirage IV is a bigger/pointier twin-engine version of the III & V. (Which I didn't realize until recently! )
Flagon don't care...
That will be the Mirage IV Version 0.5
Flagon (at 1,386 mph) would care, if it was trying to catch a Mirage IV traveling at 1,454 mph with a nuclear device strapped to it's belly.
Just sayin'...
Ah, the French strategic nuclear bomber! Are these still in current use?
"All you mugs need to get busy building, and post pics!"
Nope, the bomber variants were retired in '96 with a handful of these machines converted to recon platforms, and those were phased out in 2005. Still an impressive aircraft though.
Manstein's revenge Just sayin'...
THAT's the baby. Think I need to track one down soon.
Texgunner Ah, the French strategic nuclear bomber! Are these still in current use?
The IV's role switched to reconnaissance only in 1996 & continued until 2005 when the fleet was retired
A bit slow off the mark it seems...............
Dagger laughs at Mirage IV...
Manstein's revenge Dagger laughs at Mirage IV...
Only because it has recessed panel lines & included resin+PE...
Mirage IV walks into bar,
Milairjunkie Mirage IV walks into bar, Manstein's revenge Dagger laughs at Mirage IV... Mirage IV knock's Daggers block off,
Mirage IV orders a Flagon at the bar & waits patiently for Dagger to pick himself up from the floor while pondering where Dagger found the audacity to behave in such a disrespectful manner....
Still showing as in stock at Hannants. The page also lists some accessories available.
www.hannants.co.uk/.../HE80351
http://david-j-ross.smugmug.com/
davros Still showing as in stock at Hannants. The page also lists some accessories available. www.hannants.co.uk/.../HE80351
Thanks for that davros, I never think to check with Hannants on the other side of the pond. I'll have to take a look after work hours, the office webfilter screens most online sellers...
