1/48 Hasegawa A6M2 Model 21 Pearl Harbor Zero (Niihau Incident) FINISHED...
    February 2012
Posted by lawdog114 on Wednesday, January 14, 2015 2:17 PM
Mike:  I lighten in with a couple drops of XF-2 Flat White
Allen:  Thanka Allen.  Reference the IP decal, I put the whole decal over the dials and then soak it in Microsol.  Just monitor it as it melts to make sure the gauges stay in the dials. Once dry. I like to put a drop of 5 minute clear epoxy on each dial to simulate glass.  I must caution that some work better than others.
Are you washing the plastic before paint?  If your having issues with Tamiya lifting than it may be surface prep.  I Always wipe my plastic down with Isoprophyl Alcohol to make sure all mold releasing agents, finger prints, or other oils are off of it. I've never had Tamiya tape lift Tamiya paint.  There tape is generally fantastic.
Gamera:  Thanks for the kind words.  I will be buying some of that ASAP.
Stuart:  Thanks.  I use the airbrush for just about everything.  The panel line application does not need to be perfect. It's going to be covered anyways.  Just make sure the lines is covered with the black.  I've seen a technique where modelers paint the whole plane black then go back and filter in the base color panel by panel.  That just seems like too much work for me though,  especially since my air compressor is on its last legs. Try getting in relatively close with low pressure.
Joe
    January 2015
Posted by atomicholiday on Wednesday, January 14, 2015 4:01 PM
That is looking fantastic.  Very realistic.
    May 2008
Posted by MIflyer on Wednesday, January 14, 2015 4:12 PM
Beautiful paint work. I realize that the use of pre/post shading, weathering, and all that are very subjective, but you have a distinctive style that just looks "right" to my eye. Good stuff.
Kevin Johnson    Ypsilanti, Michigan USA
On the bench: 1/72 Fujimi Ki-36 J-BAAR
    May 2014
Posted by SubarooMike on Thursday, January 15, 2015 9:52 PM
Lawdog114,  I bought a bottle of the brown and black.  Unfortunately I really do not like the stuffSad  I have also read quite a few accounts of it peeling up with age.    If you would like, send me a PM with an address that way  I can send them to you.  Free of charge.
    February 2012
Posted by lawdog114 on Friday, January 16, 2015 11:38 PM
Thanks folks.  I do believe I'm finished.  To recap, its the Hasegawa A6M2 Model 21 in the markings of Petty Officer 1st Class Shigenori Nishikaichi off the carrier Hiryu on the morning of December 7th 1941.  The scene is depicted just before take off, as if Nishikaiachi had posed for a quick picture before jumping into the cockpit.   At least that's what I was going for....
Reference the kit itself, its nice but has wing root issues.  My advice is to glue the upper wings to the wing roots first.  I used the controversial XF-76 Grey Green to represent the "Ame-hiro" color of the early Zeros.  These planes were fairly new so I kept weathering to a minimum.  I even left a slight sheen on the plane to depict this.  The plane received engine wiring and brake lines from fuse wire and the only aftermarket addition was an Ultracast seat.  The decals are a mixture of the kit's sheet and Berna.  The pilot is one of the four choices that came with the Tamiya A6M5 I built last year.   The "chunk" of Hiryu was taken from a illustration I found online.  I painted cardboard stock to replicate this particular section.  It's a tad one dimensional but it was much cheaper than those aftermarket bases.
Notes regarding the pilot:  Figure painting is not my strong point.  As I said, it's one of the pilot figures in the new tooled Tamiya Zero series.  These are nicely detailed and I brush painted my example with Tamiya Paints using the side of the box as reference (glad I saved it).  It was then washed with a brown Detailer wash.  This may or may not be the same uniform the pilots wore at Pearl Harbor.  I doubt they changed much.  I had read that Japanese pilots carried ceremonial Samurai swords, so I chose to include this.
The said Illustration of the Hiryu deck. I opted to replicate the area with the green circle
The "snapshot"..
Reality....
The rest...
Thanks for following  The D3A1 Val that George Welch shot down is coming soon too.
Joe
    June 2014
Posted by BrandonK on Saturday, January 17, 2015 12:07 AM
Joe,
You rocked another one. Sweet built, it looks great. I see your grey green better now, I changed the setting on my monitor and that is nearly the exact color I will paint mine when completed. Again, fantastic build.
BrandonK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    April 2005
Posted by wing_nut on Saturday, January 17, 2015 6:50 AM
Outstanding Joe. Another beauty. I would have been surprised if it were otherwise.
Marc
    May 2008
Posted by MIflyer on Saturday, January 17, 2015 4:10 PM
Good stuff. The base is a very nice addition, too.
    February 2012
Posted by lawdog114 on Saturday, January 17, 2015 6:36 PM
Thanks guys....
Posted by Gamera on Monday, January 19, 2015 8:18 AM
Well I still have no bleeping idea if that's the 'right' colour or not but as usual she looks terrific! If this isn't the right shade then it ought to be!
And really nice work on the deck, great idea there and the figure despite your questions looks pretty darn good to me too.
    February 2013
Posted by Chanter on Monday, January 19, 2015 8:33 AM
Joe, thanks for the advice.
It could very well be prep work, or incorrect prep work prior to painting that causes my peeling problem.  I do wash everything initially, so I'll try a wipe down with ISO prior to painting, to ensure all is spotless.
Allen
ButcherbirdBadgesmall_zps1d50c6bb1944 GB
    June 2013
Posted by bvallot on Monday, January 19, 2015 5:11 PM
Yeah.  I think the color is just fine.  Fantastic build here Joe.  Makes me itch to start my Zeros! =D  I like how you've included a specific part of the deck.  I've been mulling over a similar idea with any grounded planes I do.  I wasn't sure how'd it come out, but after seeing you do it a few times...I think I know just what to do about it now.  =]
On the bench:
Tamiya F4U-1  Kenneth Walsh
    February 2012
Posted by lawdog114 on Monday, January 19, 2015 11:50 PM
Thanks guys....yep, I like the color too.  Nobody really knows for sure what color those Zeros were.  Perhaps several shades...
Joe
    January 2014
Posted by Silver on Thursday, July 23, 2015 7:08 PM
Thank god for google
    August 2013
Posted by Jay Jay on Monday, July 27, 2015 8:23 AM
Again I'm drooling over yet another build of yours Joe.  Your artisitic abilities never fail to amaze me.
We so do appreciate your willingness to share your techniques as well.
    January 2014
Posted by Silver on Monday, July 27, 2015 10:38 AM
Great job and craftsmanship. I could of takin this model and win best aircraft at the nationals in Columbus compared on what models I saw.
    January 2014
Posted by Silver on Monday, July 27, 2015 10:39 AM
Looks very real and historic.
    February 2012
Posted by lawdog114 on Monday, July 27, 2015 7:08 PM
Thanks Silver and JJ.  I made a google search?.....wow!
Posted by jeaton01 on Monday, July 27, 2015 10:25 PM
Nicely done, lawdog.  I'm soon going to build the same kit, thanks for the tips.
John
    January 2014
Posted by Silver on Tuesday, July 28, 2015 9:52 AM
Now I am going to scratchbuild a Pearl Harbor "Val" in 1/24th scale w// engine.Thank God for sheet plastic☺️
    February 2012
Posted by lawdog114 on Friday, July 31, 2015 7:08 PM
Very cool.  I hope to see it on here.
Joe
    March 2015
Posted by Toshi on Friday, July 31, 2015 11:47 PM
Man, your work is absolutely stunning.  It's incredibly real life like, great job sir!
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
