Hi Gang,
Finally , after much trials and tribulation, here's my update to the B-26.
The wings where assembled , sanded and primerd with Alclad Primer and micro scratch filler. This is the 1st. time I used this stuff and I am impressed. No polishing of the plastic was required prior to priming, but I did clean everything with 91% alcohol like Lawdog says. The fit of the engine / wheel nacells left much to be desired especially in the hardest to sand areas where they fit up with the wings... that figures.
The 1st 4 pics are of these areas after fixing.
1 step Bondo was used smoothing it out some with a Q-Tip dipped in acetone...( that's a cotton bud for you Brits. lol ) then CAREFULLY filed and sanded to avoid removing the raised details. Man that took some time to accomplish.
The last 2 pics are of the fixed, filed and sanded engine cowlings( Arrrgh !) with the PE exhaust flaps installed. That was fun and I really mean it Herbie.
I now can begin to understand why big bucks are spent on model kits. The expensive ones just hafta fit better than this $25 one. More time was spent on this kit fixing the ill fitting parts than anynthing else combined. Waaaa. and I'm only half done with the ass'y. But because of all you good fellows' advice on here, I'm up to the challenge.
Next up is the ass'y of the fuselage halves and completing the Bomb Bay PE stuff.
I'm going to also pose the canopy in the open position with the gull wings and side glass open. I have a vacuu-formed canopy on the way to facilitate this operation.
