Monogram 1/48 B-29
    May 2006
Posted by Shipwreck on Monday, May 9, 2016 7:07 PM
Geezer, earlier today you had some comments about how well the greenhouse did not fit. Well from what I see yours fit a lot better than mine. And then mine cracked when I tried to force it to fit!
On the Bench:
Revell 1/96 USS Constitution - rigging
Revell 1/48 B-1B Lancer Prep and research
Trumpeter 1/350 USS Hornet CV-8 Prep and research
    October 2012
Posted by Geezer on Tuesday, May 10, 2016 9:08 AM
Shipwreck, I did post those comments. I can't explain it, but in both before and after the front edges were flush. It just seemed to fall into place with minimal gaps. I'll take that anyday. I really didn't need to force it at all. I hope you were able to get a replacement from Revell.
www.spamodeler.com/forum/index.php
Mediocraties - my favorite Greek model builder.
    September 2006
Posted by the Baron on Tuesday, May 10, 2016 11:53 AM
Great build, Geezer!  I built one back in 1980 and thoroughly enjoyed it back then.  Such a huge model, and a lot of detail, and Shep's excellent "Tips on Building Dioramas" introduced me to using optic fibers (how many things did I learn from those brochures!).  I have two now in my stash, to do as you're doing, to see if I learned anything in the intervening years.  I look forward to your next installment!
Shipwreck
I want to share this photo of a dry fit of my B-29 wing roots. I am considering not using any glue so that I can move the model from place to place by simply pulling the wings off. The wings will fit snug with the right amount of tape!
If I am not mistaken, that was the point of this design.  It definitely was for the B-17 and the B-24.  Monogram intentionally designed the wings to be removed easily, to transport the model.  I believe they intended this for the B-29, too.
Best regards,
Brad
    October 2012
Posted by Geezer on Tuesday, May 10, 2016 12:51 PM
Brad, thank you very much. Doing the rest of the "glass" today. Meh.
As for the detachable wingy tings, that would not have been possible on this one. Leads me to think I did something wrong.
    May 2006
Posted by Shipwreck on Tuesday, May 10, 2016 3:09 PM
Geezer
Actually I know now that I should have rquested a replacement canopy from Revell but I had to be a hero, of a sort, and fix it. Now after lots of putty, I will end up with a crack in the middle of the canopy. Then I discovered a little kown story that when Col. Tibbits was flying out of Japan a bird flew into the canopy and cracked it!!! Well, maybe you never heard that story.
On the Bench:
    October 2012
Posted by Geezer on Wednesday, May 11, 2016 9:35 AM
Shipwreck, I like that story. Make some little-bitty strips of duct tape and apply!
    September 2006
Posted by the Baron on Wednesday, May 11, 2016 2:31 PM
Geezer
That's the piece that I do remember from when I built this as a kid, that the canopy didn't fit too well.  I didn't mind it, at the time, but I realize the difficulty it can present now.
I drilled out the pilot's window, just like Shep, so I could put the pilot figure there.  Then I hung it from my bedroom ceiling, because it was the only place to display the finished model! Big Smile
    May 2016
Posted by learmech on Wednesday, May 11, 2016 3:14 PM
Geezer,
I live about a half mile from the old Martin Bomber Plant in Nebraska where they built these monsters. When your ready to paint, maybe I can put in a good word for you to use the old paint facilities.
Posted by Ish47guy on Thursday, May 12, 2016 1:40 AM
Another option is to order a replacement vacu-form canopy  (part SQ9641) from  Squadron.com.
Will follow this thread with great intrest.  I've got two in the stash, but for the first one, I'm going to go the way less traveled route and build this one first:
Second time around will be a BMF with Paragons KB-29 conversion kit that I've had in the resin stash for a good while now.
    February 2012
Posted by lawdog114 on Thursday, May 12, 2016 3:28 AM
Nice work on that greenhouse Lyle. It seems to fit fine from what I can see.
    October 2012
Posted by Geezer on Thursday, May 12, 2016 7:48 AM
Baron, I have no idea where I'm going to put this. I love Shep's old brochures that were included in kits. Great stuff.
    October 2012
Posted by Geezer on Thursday, May 12, 2016 7:52 AM
learmech, thanks! I will certainly be using acrylics on this feller. Otherwise, it would resemble this "Up in Smoke" scene.
    October 2012
Posted by Geezer on Thursday, May 12, 2016 7:54 AM
Ish47guy
I am going with the OD/NG scheme. Not blemish-free enough for the NMF. Where did you get your decals?
    October 2012
Posted by Geezer on Thursday, May 12, 2016 7:56 AM
lawdog114
Lawdog114, it did settle into place much more bettererer than I thought it would. The blisters on the other hand.....kept wanting to fall inside the fuselage. *** waining. Coffee running out.
    May 2006
Posted by Shipwreck on Thursday, May 12, 2016 9:38 AM
learmech
A little history:
The Martin-Omaha, Nebraska B-29s were of the best quality of the four manufacturing facilities. The Enola Gay was hand picked by Col.Tibbets from the MO assembly line. The Martin-Omaha plant produced 536 planes while Bell-Marietta(Atlanta) 668, Bowing-Renton(Navy) 1,119, and Bowing Wichita 1,768. The main wing assembly differed from plant to plant. Some attached each wing to the side of the fuselage (like the model); BN plant. Another approach was to drop both wings as a sub-assembly onto a notch in the fuselage (center attachment); all other plants BW, BA, and MO.
On the Bench:
    May 2016
Posted by learmech on Thursday, May 12, 2016 10:42 AM
Shipwreck, Our local modeling club had a guest speaker back around November or December of 2015. I forget the lady's name, but she started out as a riveter at the Martin Bomber plant (it is actually in Bellevue, Ne.) on B-26s before they switched over to B-29s. She ended up running the crane that lowered the B-29 wing assys to be attached to the fuselage. And the were lowered into a notch in the fuselage.
    September 2006
Posted by the Baron on Thursday, May 12, 2016 11:33 AM
I like the OD-over-gray scheme, too.  I'm going to do one of mine in those colors, too, if for no other reason than that you don't see it that often.
Posted by Ish47guy on Friday, May 13, 2016 12:45 AM
Geezer, the decals are Iliad Design 48-021. At the time, I ordered them directly from their website (they are in Canada).  I haven't used them yet, so I can't attest to their quality.  I wrote a review of the sheet on Modeling Madness:
http://modelingmadness.com/others/decals/iliad/48021.htm
Baron, I'm with you 100%. Also, I've never done any kind of BMF in all my decades of "sorta" building models. It would probably be modeling suicide to make my first BMF project a B-29.
    October 2012
Posted by Geezer on Friday, May 13, 2016 10:28 AM
Ish47guy
lsh47guy, I was afraid you would say that. Iliad doesn't have any (OOP) and no one else does, either...inspite of what their site says (flightdecs)
    April 2015
Posted by RudyOnWheels on Friday, May 13, 2016 11:50 AM
Just finished the same plane myself in the Boeing Group Build. Had a hell of a time locating the "Enola Gay" decals (mine was the later 90's-early 200's P.C. version, but still had the Atomic bombs with no mention of them in the instructions) I ended up having to order the decals out of Canada at CanMilAir.com.... Jeez what a PITA. I had serious issues fitting the fuselage halves together, and the obligatory ***-poor greenhouse fit. But oddly, mine came out ok like yours once I torqued it this way and that while gluing it..... Mine will be hanging from the ceiling with the little boy bomb hanging below the bay, Right next to this:  Keep up the good work! I look forward to seeing the finished product!
    October 2012
Posted by Geezer on Saturday, May 14, 2016 7:52 AM
Rudyonwheels, that is something to treasure. This boxing has the EG decals, instructions on the a-boms, and all that.
Good to know yours turned out as it did.
    May 2010
Posted by sbemo13 on Saturday, May 14, 2016 8:52 AM
Great build! I was going to say same thing, I swear buy Tamiya Extra Thin. I add strips of styrene put into any gaps. This will make very strong bond. Shawn B
    October 2012
Posted by Geezer on Monday, May 16, 2016 9:46 AM
I got some of the "new" Tamiya Extra Thin Quick Setting formula - came from Japan and took about 3 weeks. Smells exactly like a strong fingernail polish remover!
On the B-29 front. No *** is no go go. Man, the last several days have been tough. Painting small parts. Feel like being told by mom to clean your room. Moving at the speed of Eyore. I've also been straightening up the room. My three year old granddaughter was in here the other day...said, "Your room is a mess!" I replied, "Where?" She answered, "EVERYWHERE!" Out of the mouths of babes.
The beast is now officially green or Tamiya XF-58 Olive Drab. So far only 2-3 gallons.
    August 2015
Posted by crown r n7 on Monday, May 16, 2016 11:11 AM
Nice to see a B-29 in O/D
 Nick.
    September 2006
Posted by the Baron on Monday, May 16, 2016 11:24 AM
Nice progress, Geezer!  Looks pretty cool.
    October 2012
Posted by Geezer on Monday, May 16, 2016 1:15 PM
From above post, "...On the B-29 front. No *** is no go go. Man, the last several days have been tough. Painting ..."
Wowie, zowie....guess I can say that. The four letter moe joe variation was whacked and replaced by astericks...can I say that? C'mon guys.
    October 2012
Posted by Geezer on Monday, May 16, 2016 1:20 PM
Baron - Thank you.
Crown r n7 - Thank you - The OD version sort of started growing on me at Stikpusher's suggestion. That and there was no way it would be "clean" enough for NMF!
    February 2012
Posted by lawdog114 on Monday, May 16, 2016 6:58 PM
Nice to see a OD Superfort. I wasn't sure if you knew, but Tamiya make Olive Drab. It's XF-62. I usually mix it with a touch of XF-49 Khaki to brown it up a bit. I look forward to the decals...
    June 2003
Posted by allan on Monday, May 16, 2016 11:13 PM
It does look great in OD. Cant wait to see this done.
No bucks, no Buck Rogers
    March 2005
Posted by philo426 on Monday, May 16, 2016 11:31 PM
Wow!That is a monster!Did not realize that they were ever painted OD but with the yellow markings it should be a refreshing change of pace!Good job!
