Hasegawa Tomcat and Weapons set Question
    August 2005
Posted by eizzle on Tuesday, March 6, 2007 5:51 PM
I am using the Weapons set to outfit my Hase Tomcat and I want to use the JDAM's on it, but my question is which adapters do I use or do they even come in the kits??? Thank you gentlemen!
Colin
 Homer Simpson for president!!!
    June 2006
Posted by fjlom on Tuesday, March 6, 2007 7:43 PM
Depends on what scale you're working in. In 1:72, the Hasegawa weapons kit X72-11 (laser guided bombs) does include appropriate F-14 bomb racks that can be used with the JDAMs from the X72-12 kit.  Hasegawa seems to have a way of doing that...makes you have to buy several different kits. I would assume that the same set up is true for their corresponding 1:48 weapons kits, but can't be sure. Hope that helps. Frank
    June 2006
Posted by SoD Stitch on Tuesday, March 6, 2007 8:03 PM
Negative, the 1/48th scale weapons set does not come with the proper adapters for the F-14 (I've got several boxes of each of the 1/48th weapons sets); the Tomcat uses the Phoenix "pallets" when carrying JDAM's (and GBU-28's), but I'm not sure where you can get the adapter to adapt from the Phoenix pallet to the GBU-31. Here is a good picture of an F-14 with the adapter installed:
For more info on the Tomcat and the various weapons it can carry, go here:
http://www.anft.net/f-14/f14-detail-weapons.htm
1/48th Monogram A-37 Dragonfly: 95% (so close!); 1/35th Academy UH-60L: 90%; 1/35th Dragon "Ersatz" M10: 75%; 1/35th DML E-100 Super Heavy Tank: 100%; 1/48 YF-12A, 95%; 1/48 U-2R: 90%; 1/48 B-58 Hustler: 50%; 1/32 F-117, 50%; 1/48 Rafale M: 50%; 1/48 F-105D: 75%; 1/48 SOS A-1H Skyraider: 50%; 1/48th Hobby Boss Su-27: 50%; 1/16th Revell Lamborghini Countach: 75%; 1/12th Otaki Lamborghini Countach: 25%; Tamiya 1/35th M3 Bradley Cavalry Fighting Vehicle: 25%
    August 2005
Posted by eizzle on Wednesday, March 7, 2007 3:27 PM
Thanks for the help guys! Kinda weird that they include the F-14 as one that would carry that bomb in the weapons set, but they dont make an adapter for it! Maybe I can make one? THanks again!
Colin
Posted by TANGO 1 on Wednesday, March 7, 2007 3:44 PM
Hi. I just caught this, I have the Black Box F-14D conversion set and I'm pretty sure that it has those adaptors.
I'm not able to go check right now, but I'll have a look for you later to see.
Regards, Darren. C.A.G. FAA/USNFAW GB
    August 2005
Posted by eizzle on Wednesday, March 7, 2007 4:00 PM
Thanks Tango, the build is on hold anyway, I dropped my airbrush and ruined my medium nozzle and needle, gotta order a new one tomorrow!
Colin
Posted by TANGO 1 on Wednesday, March 7, 2007 4:14 PM
Ouch! I hate it when that happens! I'll get back here when I've had a good peek at that conversion kit.
Wink [;)]
    June 2006
Posted by fjlom on Wednesday, March 7, 2007 4:57 PM
A company called Eagle Designs (www.eagledesigns.50megs.com) has a resin F-14B/D "Bombcat" conversion, including rear cockpit displays, new gun port, correct sidewinder rails with the BOL chaff dispensers, LANTIRN w/correct adaptor and the correct weapons pylons for the Phoenix pallets (all for ~ $20 in 1:48). Hope that helps. Frank
Posted by TANGO 1 on Wednesday, March 7, 2007 7:06 PM
Hi Colin,
I just checked and yes, the adaptors are in the Black Box set. You get the hardpoints, adaptors, bombs, Lantrin pod and stuff for  the office too. Its a nice set.Thumbs Up [tup]
