Hey Dupes, great work! That Flakpanther turned out sweet.
If it were me, I think I'd weather up the tools just a touch, particularly the super bright red fire extinguisher... they just seem a touch out of place on that weathered, streaked up kitty. Just a suggestion...
Ernest - Man, that sux about the steel rod running thru the length of the barrel. Yeah, it keeps it straight... but makes your life miserable when trying to actually add an inner diameter to the barrel. For an AM part it's hard to believe it was solid! I don't know which kugelblende is correct for the F. I think the flange on the middle one is supposed to represent a weld seam where it meets the glacis.
Mike - I feel your pain... Just lost a part that I can't readily manufacture due to a shortage of right-sized PE fret... This hobby can be so amazingly frustrating sometimes. ![Bang Head](http://cs.finescale.com/emoticons/icon_smile_banghead.gif)
Dan - the camo job looks awesome. I love looking at all the detail you put into her. ![Cool](http://cs.finescale.com/emoticons/emotion-11.gif)
Well, I was sort of on a roll last weekend until Sunday. That's when everything seemed to be heading in a negative direction. I first broke off and then proceeded to lose the rear bracket for the cleaning rod stowage tube. (This after telling myself to be extra careful of said occurrence...) So I decided to start painting the wheels the base rubber color. That didn't go as planned either as I couldn't get the airbrush to perform as desired. So I walked away before any more damage was done...
Here's what I was able to accomplish before that. I did manage to finish up the grilles. The rectangular ones are two parts - the grille/frame and a frame (I guess that adds a little dimension). In the rear gaps I added a little extra material so the bolts didn't look like they attached to nothing. It also closed up the overall gap a little to make it more true to the real thing. I unfortunately only had 4 PE hex bolt heads I used on the front edges of the front grilles. The other attachments are nuts/bolts combos. They will look pretty good I think even if they are not the correct attachment. I plan on adding a little more detail back here before calling it quits...
![](http://i1064.photobucket.com/albums/u376/dwhaasie/Italeri%20Panther%20Ausf%20A%20-%20Dec2012/IMG_2739_smpb_zps430f4f7e.jpg)
Again, the overall view of where she stands.
![](http://i1064.photobucket.com/albums/u376/dwhaasie/Italeri%20Panther%20Ausf%20A%20-%20Dec2012/IMG_2740_smpb_zpsb60d8ce8.jpg)
