Okay. I still have to fit the fuel lines to fix up and match them to the wing surface. But for now I have just about everything done for this one...
Here's the APS-13
image by brittvallot, on Flickr
The antenna is made from very tiny brass rod. To solve the problem of inserting them I used a brand new exacto blade and made a very small hole straight down. The sharp tip ensures the hole's low profile. The light on the dash was made from a female end of pin that connects a fuselage. It was originally the pin part to the P-40 I'm working on. I cut it out from the cowl flaps and thought I might make it of some use. So, I filed and sanded it down into shape and I think it worked out fairly well. I'd like to have gotten the thickness down a bit more...but I think it's a good first attempt.
Radiator...
Didn't want to overdo the weathering here. I kept it simple and let what I'd previously done with the NMF surface to stand up on it's own.
Glass for the gun site.
I haven't finished the wooden base yet. I've got a piece of oak to cut and stain, but for now I've got it on a temporary stand.
