Jibber and Bish, those Tamiya 48th scale armor kits really are the bomb! They practicly fall together they are so well engineered. Mind you I have not yet added the few pieces of plastic to metal that need to be done, but the engineering really needs to be expereinced to be appreciated. It is just that good!
Seeing how last night was a "build night" at the monthly AMPS meeting, and pizza and beer were involved, not to mention 20-30+ guys building elbow to elbow at long bench work tables, I bounced around in the instructions and tried to keep it as simple as possible for the construction work.
upper hull so far
turret so far- I left the gun tube loose for seam clean up when there is no beer involved
and a test fit of everything together so far...
if you notice the open engine hatch and MG ball mount space, that is where the screws go in to attach the upper hull to the lowed hull. Then you glue (or place if you fell so inclined) those items over those openings.
If Tamiya had come out with these kits before I decided to standardize my AFV builds in 1/35 I would have been all over them based off this expereince. it's a true shame that they (or nobody else) does any modern armor in 1/48... except for the Warrior IFV from Airfix. At least not in new tooled or decently detailed kits of post 1975 vintage. Talk about a huge gap needing to be filled. This kit is really a gem so far.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
- Plankton
LSM
