Ridge, T-bolt....looking sweet. Jer, neat info regarding fuse bands. Howard, thanks for the offer but I decided to go with Hackl's markings. I was reading up on him and learned he served on every front at one point and had 192 confirmed kills with 34 being "heavies". Consider me inspired! I'll probably use the kit's tail scoreboard but will source the rest from my Aeromaster stash. I'm not that brave.....lol. I'll just live with the cannons. I like instrument decals too, but on my kit it came in black when it was suppose to be RLM 66. I decided to make mine a drybrush exercise. A question about the Airscale decals though, are they already pre-cut individually into circles or is a punch set needed? I may try these out. Can someone post a small tutorial on this?
Last night it was me, Net-Flix, and RLM 74, 75, 76 through my airbrush. I can attest to German mottling being somewhat challenging when your airbrush needle is going bad, for I'm having a hard time getting those fine lines down. Here I preshaded the panel lines and then added the ID colors (white tail, yellow nose and fuse band) which were taped off.
RLM 76 was next. For some reason I couldn't seem to get this right to my eye. I used the recommended 2 parts (drops) XF-66 Light Grey, 1 part XF-23 Light Blue and then 7 parts XF-2 Flat White, but it just looked too pale grey. I added a touch more of the blue. This is why I hate trying to make RLM colors out of Tamiya paint and use Gunze Aqueous for this. RLM 76 is the only one I dont have. Here we are with "F it...good enough". I streaked and weathered it with a diluted red-brown/black post shading.
I then pulled out the Gunze for the 74 and 75. I love the Aqueous line for RLm colors. They look right on to me. 75 was first.
I then used the instruction sheet profile for an Idea how Hackl's camo pattern went. It appeared to be field applied void of the normal splinter pattern. I am however skeptical since the sheet calls for this pattern on all three planes, two being on the Eastern front??? I decided to freehand spray on the 74. I then added a touch of XF-2 Flat White to fade it out a bit in the wings. As I said, needle issues prevented this from being a convincing mottling job and really tried my patience. Hopefully it will be passable after decaling and weathering later.
Decals soon...
Joe
