Hi Randy and all,
Finished the first NMF model ever Friday and took some pictures. Model is Revell 1/72 P-51D Mustang with AM decal set from Eagle Strike (Blue Nose Birds of Bodney-Option 3).The model was 4 bucks-decal setr was 5. I described the process in previous posts: cut off the Snaptite pegs and glued it with no putty or filler.I used MrSurfacer1000 as primer, then a mix of Testors gloss black and aluminum rattle can enamel undercoat. Then,Future on body and canopy,masked off parts of the body and painted areas needed with Tamiya acrylic blue,red, and black as shown here:
Then, after that dried, I reverse masked the nose,tail,and 2 fuselage stripes with Tamiya tape and sprayed with Glosscote.While that was tacky, I worked Hawkeyes SnJ Aluminum polishing powders onto the body with a cotton swab. Then, I buffed on with a cotton rag, going in different directions on adjacent panels:
I then waited a while, and sprayed another 2 coats of Glosscote.Let that cure, then put on all the decals and fixed a few details.I think it turned out pretty well given it was my first effort and it was a cheap model:
Thanks for the invite to participate in the group.I enjoyed it a lot and will grab the badge soon if you approve.
Best regards,
Stenscience
