Red, white and YOU! any kit NOT produced in China or Japan
    January 2009
Posted by fermis on Tuesday, March 2, 2010 12:10 AM
 I was doing a terrible job on the rescribe, so I took a step back and CA'ed over all my lines, sanded her back to smooth and went back at it. This time using a needle in a pinvice instead of the knife I tried the first time. Needle is definetly the way to go!!!! I'm really into this project now, so much so, I decided to break out the rivet gun (needle) and rivet her one by one!!!
 Just needs a light sanding.
006-1.jpg picture by fermisb
007-1.jpg picture by fermisb
    July 2008
Posted by vetteman42 on Tuesday, March 2, 2010 12:35 AM
Fermis OMG all I can seem to do looking at your latest WIP pictures is shake my head in amazement. This is gonna be one awesome P-61. When are you going to start doing how-to videos ? BTW I went and got my mitts on a couple of 000 brushes to see if I can paint an IP half as well as you do.
Randy So many to build.......So little time
    January 2009
Posted by fermis on Tuesday, March 9, 2010 1:04 PM
 Thanks for another ego stoke Randy!!!!Bow Down
 I hate brand new brushes, I like em after the tip had flattened out a bit(about a millimeter wide), with a bit of a curl to em. Then the trick is to dip the tip in the lid of the paint, wipe of the majority on the lip of the lid, then just touch it to the part. Very tedious and time consuming, but the results are worth it!!!!
 This rescribe and rivet job has been a real test of patient, sanity and my overall well being!!! But I finally pretty much got that all wrapped up. Just needs a light sanding to knock down all the scribing ridges. If my order from Squadron feels like showing up anytime(ordered last tuesday) I can replace the mess on the bottom of the booms and in the wing intakes. Then I can proceed with getting thing together.
 Flaps up for this girl, I think it looks better that way, that or it's the reverse psychology from them being offered in the down position. So, I had to add a bit to the flaps to fill in the gaps.
001-3.jpg picture by fermisb
 I also removed the molded on cowling, to make it easier to deal with the big gap there. I cut a styrene disc to make up the difference.
004-1.jpg picture by fermisb
005.jpg picture by fermisb
The gap on the other side will be easy enough to deal with, with a bit of styrene.
006-2.jpg picture by fermisb
    September 2005
Posted by Sprue-ce Goose on Tuesday, March 9, 2010 1:17 PM
My compliments on your patience. Bow DownBow Down
That kind of kit is one reason I got out of the hobby in the early 90's.
Posted by Gamera on Wednesday, March 10, 2010 8:18 PM
Still looking plain out awesome Fermis!
Update: Maria is finished! I sprayed her with an overcoat of matte varnish tonight. Unfortunately by the time I finished I didn't have the light for good photos. I've try to get some taken and put up this weekend.
    September 2007
Posted by SuppressionFire on Sunday, March 14, 2010 8:37 AM
Heh fellas! Still alive and kicking...Started a j-o-b out of town and been without a computer for the last few weeks...anyhow have weekends off and looking forward to rain out days to get building again! Glad to see this GB is still active.
http://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
    January 2009
Posted by fermis on Sunday, March 14, 2010 10:59 PM
Thanks again guys!!!
 I'm gettin somewhere finally.
Got my mmesh in and replaced the detail on the forward bottom of the booms.
002-4.jpg picture by fermisb
Really poor fit of the boom to the wing was delt with by slipping in some strips of styrene in the larger gaps and stretched sprue in the smaller areas.
001-5.jpg picture by fermisb
003-2.jpg picture by fermisb
Attached the engines/cowling and replaced the louvers in the intakes. Completely forgot that I was going to put in the ductwork inside before closing up the wingsCrying  Too late now!!!
004-2.jpg picture by fermisb
 Those issue are quite minor compared to this canopy. Of the past 3 61s that I have built, not one of them came close to being this bad. I shimmed all the way around the front canopy and around the top(openning portion), and a few shims for the rear canopy as well. A lot of grinding with the dremel and a lot of sanding. Now , it looks like it was meant to be.
 Still got more sanding and polishing. I taped up the clear parts, inside and out so the CA wouldn't fog it up. Doesn't really matter on the outside, cause I'm sanding the hell out of it!!!
001-6.jpg picture by fermisb
009.jpg picture by fermisb
010.jpg picture by fermisb
011.jpg picture by fermisb
    July 2008
Posted by vetteman42 on Monday, March 15, 2010 12:34 AM
Fermis WOW the 61 is looking great, cant believe how good all that scribing looks and the new screens in the booms look really good. That canopy is a nightmare isn't it, with all the work you are putting into yours it will look as it should look me thinks. Ya know I will be remembering your tips and tricks for my next P-61.
I am finding out why no one makes a vacuformed canopy for these kits. I have done 2 pulls sense we talked and still have troubles with it. Might have to try making it a 2 piece deal but that will mean starting over with more molds.
    March 2006
Posted by simpilot34 on Monday, March 15, 2010 12:45 AM
WOW Fermis that is looking great!!!!! I have had two of those over the years and NEVER have I put the effort into them that you are!!! Of course my first one was when I was 10!Whistling the second I would have been about 19-20. Looked much better but still doesn't compare to yours!!!
Lots of great work here peoples!!! Been meaning to stop by but I get distracted by so many threads in the forums lol.Toast
Cheers, Lt. Cmdr. Richie "To be prepared for war, is one of the most effectual means of preserving the peace."-George Washington
    January 2009
Posted by fermis on Monday, March 15, 2010 9:51 PM
 Thanks SIM!!!  I think I was about the same ages for my first two!!! (give or take a year)
What gives....am I the only one building here????!!!!!!!
Anyway, I finally got this canopy whipped into shape. The bad news is, after all that grinding and sanding, the final polish revealed tons of crap and a finger print on the inside(have always had that problem)
001-7.jpg picture by fermisb
002-6.jpg picture by fermisb
So, I had to remove the boarding ladders and was able to squeeze in an angled dental tool with some poster-tac smashed on the end of it, and get almost all the poop out of there. For the finger print, I slid in a q-tip dipped in widex to take care of that....What a PITA!!!!
 I am the WINNER!!!!!!!
003-3.jpg picture by fermisb
004-3.jpg picture by fermisb
    July 2008
Posted by vetteman42 on Monday, March 15, 2010 11:29 PM
Fermis those canopys are amazing Bow Down Yours is gonna be one sweet P-61. How did you polish the canopys, I cant believe how clear they came out. If I aint careful you will have me starting another one soon, I have 2 more kits ya know.
    January 2009
Posted by fermis on Monday, March 15, 2010 11:36 PM
2 MORE!!!! E-gads man!!! I get a headache just thinking about ever doing another ONE!!!!
 After sanding, lighter and lighter grits, I went to a piece of plain old paper, then toothpaste with a rag from old sweatpants, followed up with a few squirts of Metallizer sealer.
Posted by Gamera on Tuesday, March 16, 2010 8:06 PM
Fermis- you're working so hard I feel I should do less to counterbalance you Big Smile
Good stuff man! Looking forward to seeing her done Yes
Sorry I promised pics this weekend but ended up getting busy and let them slide. Well here they are. Actually I wondered about posting these close-up pics since they show up every little brushmark and mistake. The actual figure base is about 3 inches/10 cm in length.
    January 2009
Posted by fermis on Tuesday, March 16, 2010 10:10 PM
Very nice!!!!!  Bright and colorful!!!
    January 2009
Posted by fermis on Tuesday, March 16, 2010 11:48 PM
 That huge milestone has finally been reached!!!!
I cemented the left wing, allowed to set, then dryfit the right side with the tail. NO GOOD!!!  My boom/wing joint is obviously off a bit.
Here's the fitSad
001-8.jpg picture by fermisb
I got so damn frustrated....I threw it against the wallBang HeadCensoredBang HeadCensoredDunceBlack EyeDead
 HAHA....NO WAY!!!!!! This is too easy!!!!
Something had to give. The tailplane being the only option, I broke out the razor saw and lopped off about 1/16", a little sanding and everything fit like a glove!!!
002-7.jpg picture by fermisb
003-4.jpg picture by fermisb
A bit of masking(gear bays and engines) and she'll be ready for paint!!!!!
WOOOOOOO HOOOOOOOOOOOOOOOOOOOOOOO!!!!!
    March 2006
Posted by simpilot34 on Wednesday, March 17, 2010 3:11 AM
HEHE you had me!! I will admit to thatWhistling I Just said' Ah no, you did......nt.. Big Smile Looking good mate!!! Can't wait to see her in paint!!
    July 2008
Posted by vetteman42 on Thursday, March 18, 2010 1:35 AM
Awwww man Fermis you got me big time on that one, got so upset I had to take a nitro. Angry Then I scrolled down geeze glad you wus messing with us. Smile Don't know if I will even try and do another P-61 after seeing your build. I too had to trim the elevator to get the booms to line up.
    January 2009
Posted by fermis on Thursday, March 18, 2010 10:14 AM
HEHE!!!  Sorry bout that!!!!  DevilPirate       ToastToastToast
    January 2009
Posted by fermis on Thursday, March 18, 2010 9:19 PM
Got her damn close now!!!  Finished up the painting and weathering today, now it's down to a few decals and fidly bits.
I brush painted the walk lines and a few dry(ish)brushings took care of the invasion stripes.
001-9.jpg picture by fermisb
002-8.jpg picture by fermisb
    March 2006
Posted by simpilot34 on Thursday, March 18, 2010 9:24 PM
Fermis that looks fantastic mate!!!!!! WowBow DownBow DownBow DownToast
Posted by Gamera on Friday, March 19, 2010 11:50 PM
Fermis- WOW are you some sort of modeling machine or what!?!?! I wish I could get that much done that fast. And not as a rush job - she looks spectacular! I picked up some replacement decals for a P-61 off ebay the other week, now I want to run out and pick one up. Just what I need is to start on another project!
    January 2009
Posted by fermis on Sunday, March 21, 2010 5:24 PM
Much thanks again guys!!!ToastToastToast
 All done!!!
 Finished her off by rebuilding the forward antennas with stretched sprue, along with the other antennas, masked and painted the tail #s, added a landing light and wiring to the nose gear. Unmasking the canopy revealed yet another mess. Had to strip and redo it. Didn't come out so great, but oh well! The nose art was a spare from a P-51 "pyn-ups" set.
012.jpg picture by fermisb
010-1.jpg picture by fermisb
009-1.jpg picture by fermisb
008-1.jpg picture by fermisb
007-2.jpg picture by fermisb
005-2.jpg picture by fermisb
004-4.jpg picture by fermisb
003-5.jpg picture by fermisb
002-9.jpg picture by fermisb
001-10.jpg picture by fermisb
And, that all folks!!!!
    September 2007
Posted by SuppressionFire on Sunday, March 21, 2010 6:30 PM
fermis, Excellent job on the aircraft! Too bad the canopy hides your outstanding control panel work. The weathering is very realistic and I reall like the scratch built details on the wheels like brake lines. Are you planning to enter this build in any contests? If so I am sure it will impress the judges. Thanks for shareing your techniques and skills.
Jason ~
    July 2008
Posted by vetteman42 on Monday, March 22, 2010 12:40 AM
Fermis ok dats it, mine are goin in the trashcan and I am starting all over Tongue Tied
That my friend is one VERY VERY nice P-61 Blackwidow.  Love the paint job, the weathering is just outta sight, I really like all your added detail, and the CANOPY, the canopy, actually looks like it belongs on her. YesYesBeerBow Down
    March 2006
Posted by simpilot34 on Monday, March 22, 2010 8:34 AM
YesYesYesBow DownBow DownBow DownToastToastToast
    September 2005
Posted by Sprue-ce Goose on Monday, March 22, 2010 10:43 AM
Fermis:
all I can say is "WOW" !!!
Bow DownCoolYes
    January 2009
Posted by fermis on Tuesday, March 23, 2010 11:54 PM
 Thanks guys!!!
Glad you enjoyed the show!!!CoolToastToastToast
    July 2008
Posted by Railfan 233 on Monday, June 7, 2010 4:10 PM
 I got a quick question (and a sort of argument to support it)
 How about a model railcar?
I know it's silly (and somewhat stupid) to mention anything like it here (after all, there are plenty of magazines and forums out there for the subject) but, the way I see it, model railroading is nothing more than scale model building in motion (you plac e it on the tracks, and it will go...most of the time)
          I know, there are some model railroad "Craftsman kits" out there that rival plastic models in detail, and most of them are resin kits made in the good old USA.  It's worth a thought...
http://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpgRed, White, and YOU! group build of 2010
    July 2008
Posted by Railfan 233 on Monday, June 7, 2010 4:18 PM
Railfan 233
\Never mind..... I jumped on the band wagen laght again, and didn't realize it was well underway.
N
    September 2007
Posted by SuppressionFire on Monday, June 7, 2010 5:16 PM
Railfan 233:
Yes a model RR car is acceptable!
For a change of pace I am building a 1949 Mercury Club Coupe by amt ERTL. made in the USA! All ready both motors are sawed in half, plans in a vignette during the motor swap. I want to exclude the after market and scratch build most of the extra details needed. The top will be chopped of course. Perhaps I will post WIP's in this thread.
Jason
Oh here are a few *finished shots of 'Freddie & the Fonz'
