Official Natural Metal Finish Group Build II
    July 2008
Posted by vetteman42 on Saturday, May 29, 2010 11:51 AM
Julez72
Stik, sounds like your approaching the finish line.....we want picsCamera
Well i started another Mustang, got her ready for paint and the P-38 is ready for an undercoat.....Pics soon...
Yeah Julez and Stik are both teasin us  wheres the pictures ?????????????? Devil
Gamera your Minicraft B-29 is in and most welcomed, really can't wait to see this build. Are you planning on using paint or foil ?
Randy So many to build.......So little time
Posted by Gamera on Saturday, May 29, 2010 12:50 PM
Thanks Vetteman and thanks again for hosting the GB.
Fantastic work going on here, congrads all around! Yes
I'll toss in a Minicraft 1/72 Boeing B-29. It's a big plane even in 1/72 - about 16 inches/ 40 cm long with a wingspan of about two feet / 60 cm. I'd thought about using foil since with the flat wings and cigar shaped body the only complex curves are on the engine nacelles. But I've a bunch of Alclad II and I've had good luck with it so I think I'll give it a go.
I'll try to get some photos of the box and the kit parts posted soonish.
    July 2004
Posted by stikpusher on Saturday, May 29, 2010 7:40 PM
Okay, okay...Wink Pics are inbound.... Well as said before all the major markings are on. But I still have about a half zillion tiny stencil decals to apply....Hmm And then touch up of colors, top coat, pro modeler wash... add final bits...Whistling But  nearing the finish line...
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    October 2007
Posted by jmabx on Saturday, May 29, 2010 8:08 PM
Lookin' good Stik!!! Yes  Looking forward to seeing her all finished up.
Jeremy    Propeller
    March 2006
Posted by simpilot34 on Saturday, May 29, 2010 11:21 PM
Stik she's looking good mate!!!!! You have done very well on those buzz numbers!!!! I'm loving that!!Toast
Gamera looking forward to seeing you B-29!!!
Cheers, Lt. Cmdr. Richie "To be prepared for war, is one of the most effectual means of preserving the peace."-George Washington
    March 2010
Posted by Julez72 on Sunday, May 30, 2010 12:38 AM
Stik, cool buildYes The contrasting NMF colours on certain panels really adds to the effect....Very niceToast
    March 2010
Posted by Julez72 on Sunday, May 30, 2010 1:10 AM
vetteman42
My host wants pics..............Bow Down
The P-38 all seamed up and with it's undercoat on....
Now the Mustang,anoher PTO, "Dirty Old Man" i put the future straight over the sanded plastic without undercoat and have done the tail feathers...
Now the spinner while i wait for everything else to dry...I use an automotive pin striping tape(6mm) because it bends really well...I cut strips of about 1.5mm and it justs wraps around......Luv that tapeYes
I just repeat the process when everything is dry and paint the blue on...
Sorry if you have dial up......JulesYes
    March 2006
Posted by simpilot34 on Sunday, May 30, 2010 2:29 AM
Julez that is raising the bar yet higher!!!!! They are both coming along great!!!! Love those tail feathers!!!!Toast
    September 2007
Posted by SuppressionFire on Sunday, May 30, 2010 8:40 AM
vetteman42
Maxfax not being one of the NMF paint experts here I have had the problem you are having with Tamiya paints. I found that the alcohol evaporates way too fast for the paint to self level. I have had much better luck thinning Tamiya paints with distilled or purified water in a 50/50 mix. I would guess if you buff or lightly sand the paint then future coat it that it would be fine, however I would suggest you wait on a few others to chime in before going to that trouble because I could be very wrong about that. I have stripped freshly painted parts that were painted with Tamiya acrylic paints with 91% alcohol and a bit of torn up t-shirt and q-tips with not much trouble at all.
Thanks vetteman42 for clarifying this problem I have had with Tamiya acrylics for washes. I am now keeping away from 70% alcohol to the 50% mix with better results. Also found alcohol over enamel flat clear is a bad combination as it tends to stain the clear. I now use tap water with a dab of dish soap for washes over enamel clear.
Hearing about a problem and different corrections helps a lot in understanding the issue. Once again a new kung-foo technique has been discovered in the forums!
http://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
    September 2006
Posted by raptordriver on Sunday, May 30, 2010 8:47 AM
Vetteman! Guess what! I picked up a kit yesterday that might qualify, it is a 1/48 Revell Spirit of St. Louis, so if that works put me down on the roster.
Andrew
Posted by IBuild148 on Sunday, May 30, 2010 12:35 PM
Julez,
That's what I am talking about....paint. Sweet job on the tail feathers and prop covers.
IBuildOne48
Teach modeling to youth!
Scalefinishes.com
http://i712.photobucket.com/albums/ww122/randysmodels/NMF%20Group%20build%20II/Group%20Badge/NMFIIGBbadgesmall.jpg
    January 2009
Posted by NiceFit on Sunday, May 30, 2010 1:18 PM
Hey Julez, nice progress on your P-38 and P-51. Automotive pinstriping tape, eh? I'll have to find some of that and try it. Auto parts store? I've been using 2mm Pactra masking tape for striping on my Mustang but have found it has a tendency to lift (un-seat) over night in areas where it is bent. Too low-tack, I suppose. Instead, I used standard household masking tape, cut to size. Also, what kind of tape did you use on your spinner? In a separate post, I will show a technique I used to paint a spinner.
Respectfully, Dobby
    January 2009
Posted by NiceFit on Sunday, May 30, 2010 1:59 PM
NiceFit
... In a separate post, I will show a technique I used to paint a spinner.
I got somewhat frustrated attempting to paint the spinners by either dipping them or using masking tape. I came up with this other technique and it worked well. The process is to: 1) paint the spinner the base color and let it cure, 2) insert the painted spinner into a hardware gauge, securing it on the backside with masking tape, and 3) paint the alternate color using light coats. [These photos were taken after the fact using a spinner from another kit.
This simply shows more of the hardware gauge.
Respectfully, Dobby
Posted by IBuild148 on Sunday, May 30, 2010 4:42 PM
Dobby,
That's a GREAT technique idea and one I will most definitely use next time! Thanks for the ideaYes and sharing with the GB.
IBuildOne48
Scalefinishes.com
    March 2010
Posted by Julez72 on Sunday, May 30, 2010 11:09 PM
IBuild148
Dobby,
DittoI would never have thought of that, not in a hundred years....
Dobby, I only use the pinstriping tape on things like spinners fueselage bands ect, anything that curves.....For everything else i use tamiya 6mm or 40mm....
    July 2008
Posted by vetteman42 on Monday, May 31, 2010 1:52 AM
Stikpusher now thats what I am talkin about ! A sweet build worth waiting for, and being teased with LOL. I love the way your panel shading worked out, and the decals really make it pop. Yes
Julez72 you handled those seams beautifully on a seam nightmare ! The nose on the P-38 kits are almost impossible to pull off and you have pulled it off perfectly Bow Down Cant wait to see her in NMF. And those stripes on your P-51 rudder are great, very well done. Maybe one day I will work up the courage to try that.
Raptordriver I can't think of a model that belongs in a NMF build than " The Spirit Of Saint Louis". You are in my friend and very welcomed.
Suppressionfire, Julez72, and Nicefit Tips like yours are what makes these group builds so much fun, and help us all to build better and better models. Thank you and all who take the time to post and share their " How I Done It " tips
    September 2008
Posted by maxfax on Monday, May 31, 2010 11:03 AM
Hey Vetteman
Have you used the Tamiya thinner for thinning the paints instead of water? I don't relish another mess up like last time- I'll try some distilled water next time.
I ended up selectively stripping a number of areas, sanding and repaintingwith black. I ended up have to do it again because of some other foul-up. Started to paint with Alclad last night, not realizing that there was a gob of it on my gloved finger from a dribble down the Alclad bottle, making nice raised splotches all over one side of the fuselage. Had to strip several areas again, repaint with black and hopefully I can get something to go right tonight! I'll post some WIP pics in a day or two.
Rob
On the bench:  Revell 1/72 HCMS Snowberry
Posted by IBuild148 on Monday, May 31, 2010 11:40 AM
Following is the first of my 2 builds and it is now finished.
Recap. This was my first Hasegawa kit and overall I was pleased with this build. The biggest "part" problem I had was B3 the Nose piece. This was to large and needed quite a bit of sanding to conform. As for the decals (approx. 70 total) they were great .... EXCEPT for #1 the Nose decal. Obviously someone at Hasegawa was not paying attention to their work that day for it is to big. I was left with 3 choices.
1. Cut and paste as best as possible
2. Remove all together and custom paint it on
3. Remove all the decals and do another scheme.
I opted for #1.
Here is the aircraft from 1957
Here is my build:
       5F-86F25222.jpg picture by xlt2002ms
      4F-86F25222.jpg picture by xlt2002ms
I have 2 other kits that I want to finish before I start my second build, the P-47D, Kansas Tornado.
IBuildOne48
Scalefinishes.com
Posted by IBuild148 on Monday, May 31, 2010 12:07 PM
stikpusher,
Your F-84E looks great. Looking forward to the finish.
IBuildOne48
Scalefinishes.com
    March 2006
Posted by simpilot34 on Monday, May 31, 2010 1:06 PM
148 that looks awesome!!!! Love the paintwork!!! The splice and stick looks very well!!!!! Cut and Paste???!!! Really now that is only on the puter!!!!Propeller
    September 2008
Posted by maxfax on Monday, May 31, 2010 1:33 PM
Great job on the Sabre!
Rob
    July 2008
Posted by vetteman42 on Monday, May 31, 2010 3:15 PM
maxfax
Hey Vetteman
Rob
Maxfax cant say I have tried the Tamiya thinner, as a matter of fact I have not even seen it at the LHS. Tamiya white is another color I have had trouble with and found if I add a few drops of future with the water to thin it, it levels much better. I saw that trick here on the forum, I guess the future acts as a retarder and its the only color I have had to use that trick with. But the down side of that is I found I had to toss the paint because if I let it sit for a few hours it tended to curttle kind of like cottage cheese.
Ibuild148 oh but thats a sweet Sabre I really like her, cant tell you even had troubles with the decals. I would say your cut & paste worked out quite well. Gotta love the colorful markings too Toast YesYes Your F-86 is on the front page right where she belongs and thank you for joining us.
Guys I cant believe the number of builds that are complete already, it hasn't even been a month yet. My hat is off to all of you.
Posted by Gamera on Monday, May 31, 2010 4:35 PM
Stikpusher and Julez great looking work! I'll have to give the pin-striping tape a try.
48- the F-86 is spectacular!!!
Anyway, box top:
Despite the thing's size the B-29 was a pretty sleek, clean aircraft. The fuselage is mostly just a long cigar shaped tube with a wing on it.
    September 2006
Posted by raptordriver on Monday, May 31, 2010 7:43 PM
Excellent work 148
Andrew
    March 2010
Posted by Julez72 on Monday, May 31, 2010 9:15 PM
48, Outstanding build buddy she looks great, well doneYesYesYes
Maxfax, Tamiya thinners are great, i use them almost exclusivly...They mix well with every paint i use...
    September 2008
Posted by maxfax on Tuesday, June 1, 2010 12:12 PM
I think I may give the Tamiya thinner a try.
Now, another problem. I seem to be running into them alot lately. I finally got the Alclad  Polished Aluminum on, and over all it looks reasonbly good, but not as smooth in areas I would like. I guess there were areas the black undercoating wasn't so smooth- perhaps slightly grainy, and many areas feel rough to the touch. I can easily live with this, but, I am wondering if I cover the plane in Future to smooth it out more, then add another layer of Alclad, if that would help.
Any suggestions?
Rob
    March 2010
Posted by Julez72 on Tuesday, June 1, 2010 5:32 PM
Rob, yeah buddy you can do that, give the alcad a light buff with a soft cloth then maybe lightly brush some future over the problem areas, give it an hour to dry and then give it a coat of future with your AB....It may help..Your rough areas might be alclad that dried midflight....
    March 2010
Posted by Scorpiomikey on Tuesday, June 1, 2010 5:59 PM
Ok well im gonna sorta get tentativly started on the planning stage while i finish off my mig.
Heres what im faced with.
Opened a sealed box and discovered half the stuffs off its sprues. stuff all detail. decals seem ok though. and 2 different colours of plastic. Has anyone else built this kit before? is this normal?
Im thinking of doing this with a mix of brush painting and BMF. any advice on BMF is greatly appreciated as ive never used it before. but hey, you gotta start somewhere and i may aswell start with a fairly cheap kit. Are there any quirks i need to know about it in terms of painting over it and decals?
"I am a leaf on the wind, watch how i soar"
Recite the litanies, fire up the Gellar field, a poo storm is coming Hmm
My signature
Check out my blog here.
    January 2009
Posted by NiceFit on Tuesday, June 1, 2010 7:33 PM
maxfax
MaxFax, I noticed the exact same thing. In my case, some of the Krylon was applied over Plastikote primer and some over enamel overspray. (I never got to the Alclad stage.) In my case, I think it was the primer underneath that was causing the gritty feel, because I didn't notice the problem in the overspray areas. At any rate, I decided to strip the plane and start over (for the umptenth time!). As someone else suggested, I re-started by applying a coat of Future directly over the plastic instead of using primer. I then painted my stripes and will soon mask them. I haven't gotten much further than that at this point. Krylon comes next.
Respectfully, Dobby
    March 2006
Posted by simpilot34 on Tuesday, June 1, 2010 8:16 PM
Scorp I saw the Testors mark on the box and immediately said 'Ohhhh lol no way!!!' Then I looked at the parts and saw the two parts in plain view for the turtle back. Where you can either build the razorback or the bubble top. If that is the true Testors kit, I built that one back in the late seventies!!! Don't remember a thing about it other than it racked up many many missions over the front and back yards.Propeller So have to say in all honesty that it will be a perfect cheap candidate to paractice a BMF finish with. One thing about a BMF finish is like all metallic colored finishes, the surface has to be SPOT ON!!!! BMF, even kitchen foil with a homebrew adhesive will show any spec of dust that may be on the surface and any surface imperfections. Aside from the things to look out for that might be a worry a BMF looks WAYYYY COOOOOL!!!!!! HTHYes
