Here's a look at the 1/72 Airfix Firefly Mk.5 kit
The decal sheet has yellowed a little and they look kinda thick , so I was thinking of masking and airbrushing the black and white strips anyway
I did some preliminary airbrushing on the fuselage insides with Gunze H-58 interior green and some chromate on the wing pieces , with a little silver on the landing gear struts and some flat black on the wheels and cockpit control stick
Next I glued up the wings and fitted the cockpit pieces inside one of the fuselage halves
There wasn't a cockpit instrument panel supplied so I just cut one from some sheet plastic
I must say for an ancient Airfix kit everything so far has fitted together quite nicely and I only needed a few bulldog clips to hold the fuselage halves together
The inner wings were a perfect fit into the fuselage lower sides
As were the rear stabilizers/tail planes
So far everything has gone really well with the build and in between coats of paint and glueing I've managed to get the decals onto the Airfix AD-3 Skyraider and the Mach 2 S-51 Dragonfly
Next I'll putty the seams on the Firefly fuselage and wing edges and start the decals on the F9F-2 Panther.
John .
