Well , I've made a start on the 1/72 scale Centurion Mk.3 kit bash and have spent most of Saturday and Sunday cutting sheet and strip plastic .
Firstly , I started work on the turret and made a new top piece where the two hatches are located ;
I scanned a copy of the scale drawings to use on the bench and that way I could lay the newly cut pieces on top of the drawings to check the size of everything as I went along .
The turret itself is molded in two halves , I cut the front and rear sections to have a total of 6 turret pieces ;
I then glued the 6 turret pieces to the new top piece and I made a new bottom disc for the turret as well ;
I may need to make new hatches for the left side of the turret top as the original one's look alittle undersze .
I filled all the gaps in the turret with plastic strips ;
Underside view ;
Next I started on the main hull , I layed the original hull top piece on top of the scale drawings and noticed that the rear panels are too long and the troughs are too short ;
I cut the rear grill from the hull top piece and filed the panels down to the correct length , I then extended the troughs by cutting 1mm x 1mm strips and glued those into position .
I replaced the center hull top piece so to bring everything to the overall correct length and re-glued the rear grill piece back in position .
I aslo made two cuts in the hull side pieces in between the bogie units and added some plastic strip to bring those pieces to the correct length as well .
Inside the hull I added plastic strips to act as stiffners ;
Next I sanded the turret to shape with all that added strip plastic and then I cut and lengthened the side skirts and track top cover pieces ;
Another view underneath ;
Everything seems to match up with the scale drawings ;
So that's about it so far , next I'll have a go at a new mantlet and I'll probably have to extend the size of those bins that fit on the side of the turret as well .
I'll have to search around for a new 20 pounder barrel to replace the kit supplied 105mm gun barrel .
I'm quite happy with what I have done so far , hopefully I can make a reasonable go at constructing a new mantlet ???
John .
