Falklands/Malvinas War 30th Anniversary GB
    July 2004
Posted by stikpusher on Sunday, June 10, 2012 3:49 PM
el_jere
I don´t know if you model in 1/48 too, but if you do a friend of mine (the guy who owns Aconcagua Resin Models) makes a wonderful Dagger convertion set for Eduard and Hobbyboss MIII.
I don´t know what particular EA plane are you going to represent but have in mind that only the last batch have the capability to use teh Magic missile, I don´t remember the numbers now, but are the last seven that arrived.
http://i63.photobucket.com/albums/h141/el_jere/mezccladito0262.jpg
el Jere, in aircraft I only build 1/48 and 1/32... I have not built a 1/72 aircraft for me in almost 30 years. The Mirage that I am building now is the old ESCI IIIE kit. but my chosen scales kinda makes me run out of display space quickly on modern jets though...Wink That would be quite an involved conversion to change a Mirage IIIC to a Dagger due to the numerous changes (lengthened fuselage with repositioned cockpit, new nose, shorter engine exhaust area/new afterburner...) between those aircraft. But I do appreciate the information. Right now I am looking at using a Mirage IIIR (which already have most of those changes) as my starting point and I just found Nesher/Dagger nose from PJ productions that may be the answer to my patience on this build. And it was the second batch of IIIEAs 013-019 that were wired to carry the Matra Magic R-550 Missile. I saw that the Aztec sheet was going to have markings for one of those and added the rails to my build.
Azorean, that Wessex looks sweet. Just what I would love for my collection.Heart
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    January 2003
Posted by el_jere on Sunday, June 10, 2012 6:06 PM
stikpusher
 el_jere:
That´s what I told you, the last batch was the second batch LOL.
Is not that dificult to convert and MIIIC into a Dagger. The R from Accademy is a poor kit, to say the least!
I did convert a MIIIC into a MIIIEB., is not THAT hard, the conversion (from Aconcagua too) fits great, and you will have a much more accurate Mirage, compared with others brands. (Heller is the most accurate in forms of all, but it has raisd  panels)
If you can, get the Aconcagua conversion, you will not regrat that.
You have the option to get just the nose, or the exterior parts without the interior, or whatever you want.
I just got a Mirage from Hobbyboss you convert it into a Dagger.
Be aware if you want to build one, that most of the aftermarket decals are wrong, because theu use a fount with angles in the corners and should be curves.
Cheers
Jeremias
PS: a moth ago, more or less a couple of Mirage Maras pased over my house, wow!! thos machines can roar!
Res non verba
    July 2004
Posted by stikpusher on Sunday, June 10, 2012 8:43 PM
Ah yes, the good old turbojet... a bit more of a roaring screech than a turbofan, even one in afterburner. I do miss the days when fast movers used to fly around my area all the time. Now it is only on a rare occasion... That conversion set does look very nice! It looks like it is made for the Heller kit as that one is already "cut" to make a IIIB or IIIC. Decisions decisions...HmmExternally the Academy IIIR does not look too bad- it even has recessed detail. And it actually is based off of the old Fujimi molds. But yes the interior is quite spartan. Very little in there, but a nice plain canvas for scratchbuilding. I also have a couple Heller IIICs along with a Hobbyboss and Eduard IIICJ (Yes I like MiragesWink) And if I do tackle the Mirage to Dagger conversion, it will be some time down the road. When I have that Aztec decal set!!! Big Smile I have way too many projects going now...
Todays update is nothing worth taking pictures of... I airbrushed on the base colors on the AAMs. Satin White for the R530 and Satin Light Ghost Gray for the R550s. And I also masked off and painted the mid tail fin leading edge antenna panel that I missed doing earlier. Plus more masking for the wheel wells and the radome, which I will try to get airbrushed aluminum and black (respectively) in the next few days. And I built the gear struts. Almost there!
       - Plankton
LSM
    April 2005
Posted by taxtp on Monday, June 11, 2012 6:05 AM
Hi Folks,
I'm running a few days behind on my HMS Sheffield. Had a bad couple of weeks with work, and have only just got back to the bench. I've now done all the masking to spray the deck and might even do it tonight.
Cheers
Tony
I'm just taking it one GB at a time.
Posted by VanceCrozier on Monday, June 11, 2012 10:33 AM
Bish
They have also released a 72nd kit.
http://media.hannants.co.uk/pics/IT1330.jpg
And a UH 5 with a Harrier
http://media.hannants.co.uk/pics/IT1329.jpg
Is it me, or have these companies slightly missed the boat.
I would like to have seen these anniversary editions out months ago as well, BUT I suppose it's easier to market them closer to the actual anniversary. All sorts of (mostly UK-based) publications have been running features recently, I think Scale Aviation Modeler(?) has a "mostly Falklands" issue coming up next.
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
Posted by VanceCrozier on Wednesday, June 13, 2012 6:58 AM
(why am i just thinking of this now?? Falklands timeline...)
13th June Battle for Tumbledown, Wireless Ridge and Mount William - 15 Britons and 40 Argentines die
Posted by Bish on Wednesday, June 13, 2012 7:12 AM
Yes, tomorrow is the 30th Anniversary of the Argentine surrender and the end of the war.
I should have thought of this earlier myself. But i am sure all have reflected while completing their builds.
Vance, i made a start of that second Chinook on Monday. But i won't include it as its exactly the same as my first build.
    April 2005
Posted by taxtp on Wednesday, June 13, 2012 9:12 AM
The main painting is done on the Sheffield, I've used the colors recommended in the instructions, but I think the deck is too pale. I am considering masking again and going for a darker colour. Oh well, it was a nice clean job.
Cheers
Tony
Posted by VanceCrozier on Wednesday, June 13, 2012 9:14 AM
taxtp
Cheers
Tony
http://i10.photobucket.com/albums/a102/tonymollica/001-23.jpg
How "off" do you think it is? Could you assemble it as-is, then give the entire topside a thin overspray??
    April 2005
Posted by taxtp on Thursday, June 14, 2012 3:07 AM
Thanks for the update Vance. I think it's quite a long way off, as the deck  is not too dissimilar to the hull sides. I'm going to mask and respray. Hopefully will get it done tonight if I have the right colour in house.
Cheers
Tony
    July 2004
Posted by stikpusher on Thursday, June 14, 2012 3:19 PM
Bish
And on the 30th anniversary of that day, my Mirage is now ready for decals.
All main painting done
close up of the tail work
radome
landing gear
missiles (the colors kind of washed out in this photo)
and everything all together
Tomorrow after the paint has had time to cure I will apply the Future gloss coat and keep my fingers crossed that the Aztec Decals come out real real soon...
Aztec! Aztec! Aztec!
       - Plankton
LSM
Posted by VanceCrozier on Thursday, June 14, 2012 3:25 PM
Looks good Stik! Now I'm getting anxious to see the Aztec decals!
Posted by Bish on Thursday, June 14, 2012 3:27 PM
O ye, thats very nice indeed.
    December 2009
Posted by Azorean on Thursday, June 14, 2012 3:53 PM
Great paint job on the Mirage, stikpusher.
I spoke yesterday with a member of the Aztec staff that told me they already are finalizing the release of the decals likely in the end of next week. Given the magnitude of the project they are taking some time to finalize everything and avoid fails. I believe the wait will be worth it.
    October 2008
Posted by bsyamato on Thursday, June 14, 2012 3:57 PM
Niceee Stik!! YesYes
    April 2005
Posted by taxtp on Thursday, June 14, 2012 9:05 PM
That Mirage is looking excellent Stik. Hopefully you will be able to finish soon.
I've resprayed the decks on the Sheffield. For the benefit of the assembled audience, the kit instructions call out for Gunze Sangyo H82 (not very) dark grey. For mine, it was just too light and difficult to distinguish from the superstructure. I've resprayed with Tamiya XF-54 which is a little darker and looks closer to what I can see in photos.
Photos tonight or tomorrow, for now it's some detail painting before assembling the superstructure.
Cheers
Tony
    July 2004
Posted by stikpusher on Friday, June 15, 2012 7:00 PM
Thanks guys. I am getting impatient about those decals.Tongue Tied
Tony, your HMS Sheffield is coming along very nicely. I really do with that Airfix would mold one in 1/350 scale.
       - Plankton
LSM
    April 2005
Posted by taxtp on Friday, June 15, 2012 7:40 PM
!/350 Sheffield is a great idea Stik. I would go for it too.
Actually I was at the Melbourne Model Expo last week, which isa great event and competition. There was a 1/350 HMS Sheffield there, but it was the WW2 vintage one. Great model though.
I've resprayed the decks and started the detail painting. Will do a little construction and post some pics tonight.
Cheers
Tony
    March 2007
Posted by bondoman on Friday, June 15, 2012 7:47 PM
stikpusher
Great paint job- it looks very real. I ordered my Aerocalcas 1/72 Neptune set. It also has a T-28 and a early '60s Gloster meteor aerobatic team, so if any of you are interested, I'll give them to you.
    April 2005
Posted by taxtp on Saturday, June 16, 2012 10:27 AM
Here are some progress pics, the superstructure is not glued on yet. Have a look at the stern deck, it's a separate piece, and it wider than the main deck. Can't find any evidence to support it.
Cheers
Tony
Posted by Bish on Saturday, June 16, 2012 11:01 AM
Looking good Tony. I think your right about the stern deck.. Does your kit have an over hang at the bck as well. I found this photo showing the stern.
    April 2005
Posted by taxtp on Saturday, June 16, 2012 6:26 PM
Thanks for the photo Bish, It answers a lot. The kit has some overhang, but it doesn't look like this. The supports for the deck are shaped differently. They also attach to the part of the deck that I nee to shave off, so there is a little bit of work in correcting this.
Has to be done though.
Cheers
Tony
    January 2003
Posted by el_jere on Saturday, June 16, 2012 7:49 PM
Grear paint job Stik!!! I love those deltas! I hope you get the Aztec decals on time.
I think I will start a Dagger in a couple of weeks.
taxpt, you are almost there too, a little more of work to correct that problem and you are done, looking forward to see her finished.
Cheers,
Jeremias
Res non verba
    September 2003
Posted by Helo H-34 on Saturday, June 16, 2012 7:59 PM
Hi Bish ;
My apologies for not being a good participant with you Falklands War GB . It's the second time I haven't finished a build for a group build you have been running , shame on me ...Embarrassed
I used to thrive on multiple builds at the one time but with a lot more family commitments this past 6 months , I've been struggling to finish anything .
I failed to do any WIP pic's for my Westland Wessex HU-5 build and this is where I'm am at the moment with the build ;
The Westland Wessex builds are part of a larger Sikorsky / Westland S-58 fleet I started a while back and I finally have some of the builds ready for masking and then painting
Anyway the Falklands HU-5 is close to masking , I'm dry fitting the canopies but leaving them off to paint seperatly as I've been having issue's with helicopter canopies of late showing smudge marks and the like from the inside , which is very frustrating .
My apologies again Bish for missing out on all the awesome WIP pic's and finished builds everyone has done ;
I guess when i finish my build and the others , I'll post them in the helicopter section .
John .
Posted by Bish on Sunday, June 17, 2012 2:27 AM
Hiya Helo, no worries, i know things can get in the way. Vance can confirm, but i think we are letting the GB run for builds to finish. Theres still a couple on going. So you can still keep it in the GB if you want. Would be nice to have that in the line up.
    October 2008
Posted by bsyamato on Sunday, June 17, 2012 5:32 AM
Helo i think you build more wessex / s-58 than the real production Big Smile
even a pleasure to see your builds Toast
    September 2003
Posted by Helo H-34 on Sunday, June 17, 2012 7:27 AM
bsyamato
Thank's bsyamato Wink ; The current on-going Sikorsky/Westland builds I dubbed series 2 , there are lot's more in the stash for series 3 ...
Thank's also Bish for allowing me to continue in the GB Yes
For reference I've taken the same approach with the wessex and Sikorsky builds through out and here a several WIP pic's of what I usually do .
First up airbrush the interior pieces FS.36231 (H-317)
Italeri mold everything in blue with the HU-5 wessex and with the cabin seating blue in colour anyway I only had to paint the seat legs and frame with some silver
The only addition to the cabin section is a ceiling piece cut from sheet plastic which I scribed some lines on at 45 degree angles and painted it light gray . The scribe lines are to simulate soundproofing material along with a couple of small pieces of resin block to represent the rotor drive shaft covering . You can see how it looks on this next reference pic
I do the same on each build .
The only other minor issue with the Wessex is the removal of the molded on lugs directly above the top of the landing gear strut ;
You need to do this so the cable ducting piece can fit under the cockpit windows ;
I also filled in the lower step recess as the Wessex has protruding footstep pieces and the lower one is directly below the upper step ..
Everything else fits quite well with no issue's , so it's on to masking and painting .
John .
    April 2005
Posted by taxtp on Monday, June 18, 2012 9:16 AM
Thanks for extending the deadline fellas. I'm pushing on with the Sheffield. Some more superstructure completed, again just placed for the photo, and a host of small parts all painted and ready to fit. I've also reshaped the rear deck, and attached it, although obviously the join needs to be made good.
Cheers
Tony
Before:
After:
Posted by VanceCrozier on Monday, June 18, 2012 10:13 AM
Help H-34 …. yep, the gates to the GB are open until started kits are finished up. And HOLY STASH BATMAN!!! That's the round-three cupboard?? I have one of the Italeri HU-5 kits in my stash - apparently you are the go-to guy if I have any questions!
Sheffield is coming along nicely Tony.
Posted by Bish on Monday, June 18, 2012 11:33 AM
Helo H-34
http://i1082.photobucket.com/albums/j362/Helicopternut/E.jpg
Bloody hell. I guess that answers the question as to whether you buy multiple kits. I thought i was bad with my 251 stash. You have me beat there.
