Monogram Mafia Group Build
    January 2003
Posted by p38jl on Wednesday, May 4, 2011 12:34 PM
ok,, here we go.. latest update Don...
first a few pics of the overall bird after sanding the color to reveal the raised panel lines.. someone requested them..
 then pics of my "distressed skin" attempt...[View:/themes/fsm/utility/Photobucket:550:0][View:/themes/fsm/utility/Photobucket:550:0][View:/themes/fsm/utility/Photobucket:550:0][View:/themes/fsm/utility/Photobucket:550:0][View:http://cs.finescale.[View:/themes/fsm/utility/Photobucket:550:0][View:/themes/fsm/utility/Photobucket:550:0]
i used gloss black first, and sprayed the area, with just wisping the front edge. then applied titanium, magnesium, another dark metalic that name escapes me.. Boyd's Mango, and a purple metalic that I made from aluminum+British racing green metalic, Testors red( square bottle) and Testors Dk Blue from square bottle ).. all colors applied top to bottom/bottom to top in a stripping manner...
comments? critiques ?..
[Photobucket]
    July 2007
Posted by troublemaker66 on Wednesday, May 4, 2011 12:43 PM
Looks great! I`m stealing your technique when I do mine...lol!
Len Pytlewski
    February 2011
Posted by Reasoned on Wednesday, May 4, 2011 12:53 PM
troublemaker66
Don't you mean "borrowing" his technique?
Er... I guess this is the "Mafia" GB. Cool
BTW, she looks great p38. Yes
Science is the pursiut of knowledge, faith is the pursuit of wisdom.  Peace be with you.
On the Tarmac: 1/48 Revell P-38
In the Hanger: A bunch of kits
    July 2008
Posted by vetteman42 on Wednesday, May 4, 2011 12:55 PM
Hans I copyed the fixed pistures of the Streak Eagle, they look great !! What did you do to them ? And yes feel free to post the pictures where you wish. Oh an do you mind if I swap the ones I posted with these ?
P38  the heat staining looks perfect man I really like it. YesYes
Randy So many to build.......So little time
    August 2009
Posted by Sparrowhyperion on Wednesday, May 4, 2011 1:00 PM
I am not sure what Hans did, but I use Paint Shop Pro Photo X3 from Corel.  It will do anything that Photoshop will, at about 1/4 the price, and it has built in filters.  One of them is an automatic one click fix for Digital Photos that automatically fixes things like too low brightness or contrast.  You can find OEM copies of the software on eBay for $20-$30 or less sometimes.
Rich
vetteman42
In the Hangar: 1/48 Hobby Boss F/A-18D RAAF Hornet,
On the Tarmac:  F4U-1D RNZAF Corsair 1/48 Scale.
Posted by VanceCrozier on Wednesday, May 4, 2011 1:00 PM
p38jl
http://i736.photobucket.com/albums/xx7/pthrtyeghtpic/camo26.jpg
... comments? critiques ?..
That's purdy! OK, remember I'm not a jet guy - I'm familiar with the effect but haven't looked into it too much. Is the striping too defined or does it really show like that? I'd be tempted to overcoat the whole thing with a thin blending coat of the main metallic colour. 2 cents
(And remember - those are Canadian pennies I'm throwing at you! Whistling)
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    July 2007
Posted by troublemaker66 on Wednesday, May 4, 2011 1:01 PM
Reasoned
 troublemaker66:
Reasoned
 troublemaker66:
Nope...borrowing means you have to give it back....dat  dere technique fell off da back a da truck! Fuhgeddaboutit!
Len Pytlewski
    January 2003
Posted by p38jl on Wednesday, May 4, 2011 1:53 PM
VanceCrozier
 p38jl:
It may be a bit to defined... but ,,, its close to the example i used. Scale Aviation modeller mag, July 2008.. tryin to find a pic from it now.
[Photobucket]
    September 2009
Posted by satch_ip on Wednesday, May 4, 2011 2:52 PM
Go ahead Hans.  I've already put the Hellcat in two other GBs.
Satch
    June 2008
Posted by Hans von Hammer on Wednesday, May 4, 2011 10:45 PM
Nah, go ahead, they're yours... I just used the photo-fix program that comes with the Vista OS.. It allows you to use either the "Autofix" function, or to manually adjust lighting, contrast, tint, color saturation, and cropping.. I use the crop feature quite a bit, as it not only crops the picture, but enlarges the cropped area as well, thus allowing me to get better close-up shots..
For yours, I just used the "Autofix" and it lightened them up nicely...  If you don't have that program on your Vista OS, just send me any photos you need fixed, and I'll try and make 'em look a bit better.. Only takes a minute or so to do each one.. I can also do some cropping if you want the close-ups larger..
    October 2010
Posted by The Navigator on Friday, May 6, 2011 10:21 AM
Uh-oh page 2! For an update, the mottling is finished and the pilots are being fitted out. She should be done this weekend. Pics to follow---
I have many books and my Lair smells of rich mahogany!!! Stay thirsty my fellow MOJOs!
    July 2004
Posted by stikpusher on Friday, May 6, 2011 11:45 AM
Hey boss, I started a Monogram ship kit in early April for another GB (ASW II), mind if I add it and show its' progress here as well?
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    June 2008
Posted by Hans von Hammer on Saturday, May 7, 2011 12:31 PM
Ya, go for it, Stikker..
    July 2004
Posted by stikpusher on Saturday, May 7, 2011 1:17 PM
OK, I have been working on this for a few weeks, so here is all my work up to this point:
Here is the orginal kit and box, a 1970s issue of USS Ramsey, a DEG later reclassified as a FFG. Roughly 1/300 scale. I am adding ssome PE from Gold Medal Models. It is 1/350, but it works on this kit!
Construction began with the bow sonar dome. I had to add a sheet styrene shim becuase of a gap in the fit.
and I began painting the main components- Neutral Gray for Haze Gray, Gunship Gray for Deck Gray, and Black and Anti Fouling Red on the lower hull.
I also assembled most of the sub assemblies before painting and adding on PE and scratch built details. I put them in place without glue for these shots...
The kits' air search radar was the incorrect type, so I made a new one from sheet styene and tea bag mesh
And I made some modifications and added PE ladders, railings and surface search radar to the Mack (Mast/Stack) assembly
basic Mack with PE ladders
and completed modified Mack
I also removed molded on stairs and added PE vertical and inclined ladders to the superstructure
I have scribed on detail to the ASROC launcher
Hollowed out the dishes of the gun and missile fire control radars (gonna add some scratchbuilt fine details soon)
built and cleaned up the kits' SH-2 Sea Sprite
and yesterday after getting to this point put everything built so far on the painted hull for a current status shot
       - Plankton
LSM
    July 2008
Posted by vetteman42 on Monday, May 9, 2011 1:11 AM
Wow still cant get over all the nice work going on here, proof that Monogram kits can steal the show from those shake & bake kits.
Stikpusher I am diggin the work on your boat........ errrrr ship man. That PE really adds to the detail and really isn't all that hard to work with, that is unless you have huge fumbling fingers like I do. Keep up the good work Yes
Hans von Hammer
Hans thank you sir I have swapped the pictures .......finally. I am using Windows 7 which didn't come with much of any other software, well none that you don't have to pay extra for that is. I guess I will have to improve my photography skills or find a program that will correct them for me. I do have Paintshop Pro but it doesn't seem to correct pictures very well, its great for designing and printing decals though.
    September 2006
Posted by the Baron on Monday, May 9, 2011 12:27 PM
Finally got back to the Zero over the weekend, putting the finishing touches on the pilot, whom I've dubbed Yoshi, and installing him in the fuselage:
I wanted to keep the AMS to a minimum, so, though I wrestled with adding a cockpit floor and side panel details, I decided not to, but to keep the kit as close to its original state as possible.  I did try to paint on some of the specific uniform details, though, like using grey for Yoshi's flying helmet's rabbit fur lining.  I will also hit him with a little thin brown wash, to pick up the facial sculpt.  But I was so eager to get him into the cockpit.
OK, so I caved on the instrument panel.  I drilled out holes to represent the instrument bezels, backed the panel with a piece of styrene, then put a drop of white acrylic into the holes.  Not superdetailed, but with the closed canopy, it'll give the impression of instrument dials (the kit is second-hand and decals lost long before I got it).
I glued up the fuselage, too, which had a really good fit, despite a little bit of a curvature to the one piece.  I'll put up a pic of that tonight.
Best regards,
Brad
    November 2006
Posted by dupes on Tuesday, May 10, 2011 10:00 PM
I know I haven't been the best about posting pics...but I need to either get a new camera, or find a new way to read my memory card in the current one. Stuck with emailing pics to myself from my phone, downloading to my laptop, editing with Photoshop, uploading to Photobucket, and then putting them on here. Not the simplest solution!
So this is one of my 2 current Monogram builds. Straight out of the box, added some tape seatbelts which you might get to see when the masks are lifted. Going with some ancient Microscale decals to model an NMF bird in the Phillippines AF. Should look pretty neat if the metalizersi work out! Down in the paint booth right now with the first coat drying.
The other build is an F-102 - pics to come when it makes a return to my bench.
    March 2007
Posted by bondoman on Wednesday, May 11, 2011 12:51 AM
F-5 looks great, Dupes. Kodak sells a neat little memory card reader at CVS etc for abt. $ 12 that accepts all manner of input devices, kind of like Flora down at the corner...
I use it a lot (oh never mind) because it saves me from keeping track of my cables, just leave it plugged into the PC.
    November 2006
Posted by dupes on Wednesday, May 11, 2011 7:45 AM
Bondo - is that card reader compatible with Windows Vista? That's where my real issue lies - my card reader came out with my aging Sony, and is no longer supported by them (I couldn't believe that they wouldn't provide a generic windows driver update).
Definitely going to go look for that. Thanks man!
    August 2009
Posted by Sparrowhyperion on Wednesday, May 11, 2011 9:30 AM
If you look on eBay, you will find hundreds of little card readers.  Most for under $10, and generally they are universally compatible.  Vista is relatively new OS and has very good driver support, so you should be all set.  I've been building, repairing and upgrading systems for about 20 years now so I have seen it all.  :)  And don't worry about spending more for a "name brand" reader.  They are all pretty much all the same inside and newer USB ones are literally plug and play.  I have a generic multi-card reader that is USB 2.0 and can handle like 10 different kinds of memory cards, sticks etc..  Works great and it was $6.99 with shipping.
Rich
dupes
    November 2006
Posted by dupes on Wednesday, May 11, 2011 9:51 AM
7 bucks shipped? Imagine my interest!
Any chance you have a link to something similar?
    August 2009
Posted by Sparrowhyperion on Wednesday, May 11, 2011 10:46 AM
Here are a few.  Some of these are ending soon, so if you want to snag one, hurry as they are mostly BIN items (Buy It Now)
http://cgi.ebay.com/23-in-1-USB-2-0-Memory-Card-Reader-SD-SDHC-MS-CF-MMC-XD-/290564516663?pt=PCC_Drives_Storage_Internal&hash=item43a6feab37
http://cgi.ebay.com/MEMORY-CARD-READER-ALL-ONE-MICRO-MINI-SDHC-CF-MMS-XD-/260782506143?pt=PCC_Drives_Storage_Internal&hash=item3cb7d9409f
http://cgi.ebay.com/All-1-Card-Memory-Digital-Reader-Black-/230616628616?pt=PCC_Drives_Storage_Internal&hash=item35b1d27d88
http://cgi.ebay.com/USB-2-0-Memory-Card-Flash-Reader-Blue-/230616628639?pt=Digital_Camera_Memory_Cards&hash=item35b1d27d9f
http://cgi.ebay.com/Card-Reader-Writer-Hi-Speed-USB-2-0-Ext-63-1-/320694895041?pt=PCC_Drives_Storage_Internal&hash=item4aaae7c1c1
http://cgi.ebay.com/Gear-Head-CR4200-23-1-All-In-One-Card-Reader-USB-cable-/250756695701?pt=PCC_Drives_Storage_Internal&hash=item3a62438695
http://cgi.ebay.com/56-1-Hi-Speed-USB-2-0-Card-Reader-Writer-SD-CF-TF-MS-/140376011025?pt=PCC_Drives_Storage_Internal&hash=item20af0ff111
http://cgi.ebay.com/USB-All-in-One-Card-Reader-SD-MMC-Mini-SD-TF-M2-RS-MMC-/310208749828?pt=PCC_Drives_Storage_Internal&hash=item4839e1e104
This one is an internal unit that plugs into the board and sits in a drive bay.  I didn't know if you need an internal or external.
http://cgi.ebay.com/3-5-ALL-1-INTERNAL-MEMORY-CARD-READER-MICRO-SD-/310311196683?pt=PCC_Drives_Storage_Internal&hash=item483ffd180b
dupes
    November 2006
Posted by dupes on Thursday, May 12, 2011 11:08 AM
Whoah! I need to double check what type of cards I have, and I'll get something today!
Good thing, too, because I need to post some pics. The F-5 is all NMF'ed up and polished, black anti-glare has been sprayed, with the exhaust section to go tonight. Hoooooping to start in on the decals too if I'm lucky.
    August 2009
Posted by Sparrowhyperion on Thursday, May 12, 2011 11:26 AM
The ones I sent you will handle any kind of card on the market.  Most cameras use either SD or Memory Stick Duo types. That includes all of the variants like SDHC and Memory Stick Duo Pro.  So I wouldn't worry about compatibility.
    June 2008
Posted by Hans von Hammer on Thursday, May 12, 2011 3:39 PM
I've almost got the War Room ready, the bench is up, paints and tools unpacked and in place, gonna start putting glue to styrene real soon..
    July 2008
Posted by vetteman42 on Thursday, May 12, 2011 4:46 PM
Hans von Hammer
EatsYeah
    January 2003
Posted by p38jl on Thursday, May 12, 2011 8:46 PM
vetteman42
 Hans von Hammer:
EatsYeah
Dittosweeet!
[Photobucket]
    October 2010
Posted by The Navigator on Friday, May 13, 2011 7:40 PM
Remember, there is no fighting in the War Room!
    July 2009
Posted by 40.mm on Friday, May 13, 2011 9:10 PM
A well earned badge !
http://www.vairhead.net/forum/dhg.jpg
    June 2008
Posted by Hans von Hammer on Friday, May 13, 2011 11:13 PM
Ok, I got the front page updated, I think...  Sound off if I missed you or you need percentage changed...
Gonna start that thread in the aircraft section for youse mugs, and the others as they become available.. Only completed builds will be posted...
THEN.. I'll be returning to the bench.. THE WAR ROOM IS REDCON ONE!*
*That means it's ready for me to build in, for you people in Rio Linda, CA...)
