MiG Alley Group Build
    July 2003
Posted by KJ200 on Monday, June 20, 2011 2:33 PM
I'm quite impressed with the Eduard Zoom set for the little Mig's cockpit.
I'm not sure it would work so well in 1/48, but in 1/72 the PE parts look great, and there is no way I could paint a 1/72 IP!Tongue Tied
Managed to prime the Mig yesterday, which showed a few small glitches.
Just spent some time re-scribing the front equipment bay cover, and giving the undercarriage & bays a coat of light blue.
Karl
    October 2010
Posted by Casper the Chihuahua on Monday, June 20, 2011 8:21 PM
KJ200
Karl
Cool, can't wait to see some WIP! Wink
Cheers
On the bench: A-4F 1/32 Hasegawa
Just deployed: F6F-5N Hellcat Nightfighter 1/48 Eduard
Up next: A6-E Intruder 1/48 Revell
    July 2003
Posted by KJ200 on Saturday, June 25, 2011 4:08 PM
Made some progress on the Airfix Mig.
I ended re-scribing the nose avionics bay hatch again, as it came out a little crooked, so filled, and re-scribed.
In order to get the curve consistent, I made a scribing template out of plastic sheet, having first used a piece of tape over the kit scribing to get the correct pattern.
This was held in place with Tamiya tape, and first a line was drawn around it to determine how accurate my template was.
Good enough for me, so I re-scribed.
The Mig was then re-primed, and several coats of gloss black applied to show up any faults which the primer had not made obvious.
It was at this point I realised that I was almost out of gloss black, hence the highly thinned paint.
The wheel bays had previously been painted with a pale blue, along with the undercarriage components, then masked with Blu Tack.
I'll let that harden over night, then give it a polish in the morning before applying the NMF tomorrow.
Must admit is is tempting to just leave it gloss black and out the red stars on, for that evil Hollywood Mig look.
Karl
    October 2010
Posted by Casper the Chihuahua on Saturday, June 25, 2011 5:55 PM
KJ200
That looks great Karl! Are you using Alclad lacquer?
Cheers
    July 2003
Posted by KJ200 on Saturday, July 2, 2011 8:13 AM
Casper, I always use Tamiya or Gunze acrylics as I share the craft room with my wife.
I have made some progress on the Mig this week, spending most of my evenings tinkering with the NMF to get something interesting.
The Mig 15s were painted with a clear varnish, so that the variations in the metal were still visible. I've noticed this in a lot of pictures of Korean war Migs. Even the camo'd machines appear to have been varnished as they exhibit a high sheen.
I
I started off with a base coat of Tamiya Chrome Silver, which was left to dry for an hour before being buffed with a cotton wool pad. This helps remove the slightly rough finish you sometimes get with Tamiya acrylics, before applying a coat of Future.
I then masked off various access panels, as well as the flight surfaces and sprayed Tamiya Metallic Grey, by way of some variation.
The red intake is just tacked in place, but adds a welcome splash of colour.
Next stop decals.
Karl
    October 2010
Posted by Casper the Chihuahua on Saturday, July 2, 2011 8:41 PM
Hi Karl, I do like the panel variation. Once the decals are on it should look even better. It's that sudden leap from plastic plane to realistic stencils and colour that I like at this stage.
Cheers
    October 2008
Posted by bsyamato on Sunday, July 3, 2011 5:02 AM
great metal finish Karl ! Yes
    July 2003
Posted by KJ200 on Sunday, July 10, 2011 9:26 AM
Thanks for the comments guys, I'm quite pleased with how the NMF turned out considering it's just Tamiya acrylic.
Got the decals on my Mig 15.
I was nervous about using the Airfix decals, as previous experience has not been good, however these went on beautifully with Mr Mark Softener & Setter snuggling them down nicely.
I've since applied the was and am sorting out the little additions.
I'll be replacing the guns, pitot, which isn't supplied, and aerial mast with items made from brass, should make them look a bit better than the kit items.
So almost finished.
Karl
    October 2008
Posted by bsyamato on Sunday, July 10, 2011 12:14 PM
recently used aiffix decals and was a bad experience, probably newest work better.
nice progress Karl Yes
    July 2003
Posted by KJ200 on Monday, July 11, 2011 3:40 PM
Bysamato, I've had similar problems in the past with Airfix.
Well I'm calling this one done, having added brass pitot, guns and antenna mast.
The obligatory underside view.
Here's some shots of a couple of builds I completed earlier in the year.
Has' venerable Mig27.
I first built this when I was about 14, and had fond memories of this kit.
...and now the even older Mig 25, my first attempt at a postwar Russian jet.
I ended up re-scribing chunks of this due to the amount of filling and sanding it took to sort the fuselage seams out.
Karl
    October 2008
Posted by bsyamato on Monday, July 11, 2011 4:29 PM
Bow Down
Great finished piece Karl
asap i'll get my own fagot, you convinced me Yes
me too build when was teenager the older two migs
the foxbat from hasegawa and the 27 from academy (hasegawa improved molds with engraved panels)
    January 2010
Posted by CallSignOWL on Monday, July 11, 2011 4:53 PM
I've only got two MiG on the shelf....Monogram's MiG-29, and a MiG-21 from a company called OEZ. Both 1/48. The -29 was my introduction back into modeling after a few years break, and the -21 was my first foiling attempt:
OWL
Now that I'm here, where am I??
    October 2010
Posted by Casper the Chihuahua on Monday, July 11, 2011 5:21 PM
Great job, Karl! Fantastic to see a finished bird and especially with a NMF!
Can't wait to see more. Post to front page coming soon!
Cheers
    June 2009
Posted by STFD637 on Wednesday, August 3, 2011 6:48 PM
Hey all. Well I got started on my Mig-17. I figured after the last couple builds I recently finished this might be a a good "easy" brake. The DML kit is pretty good with the detail you would expect. There are some seam issues, including the main fusilage that is just giving me major issues. It just seems to reappear on it's on. I initially started out thinking I was going to do a Jian of the PRC, but have decided to use the Egyptian AF marking provided. I figure with all the other Mig and Su kits I have there will be plenty of "red" stars. here are some pics.
[View:/themes/fsm/utility/Photobucket:550:0]
"If a lie is told often, and long enough, it becomes reality!"
Travis/STFD637
make an avatar
    October 2010
Posted by Casper the Chihuahua on Wednesday, August 3, 2011 7:07 PM
Hey Travis, that's a tiny bird, almost a mosquito! Big Smile
Good work can't wait to see build nno.2 completed!
Cheers
    June 2009
Posted by STFD637 on Saturday, August 13, 2011 8:35 AM
Well.....she is finished. I was very thankful for this build. Nice break. Also allowed me to work on my NMF....still need some fine tuning. It was my first time working with Testors Metalizer AB paints. Here are the pics.
[View:/themes/fsm/utility/Photobucket:550:0][View:/themes/fsm/utility/Photobucket:550:0][View:/themes/fsm/utility/Photobucket:550:0][View:/themes/fsm/utility/Photobucket:550:0]
Some of the issues I ran into: The canopy does not fit together and must be left open. The decals for the fusalage and wing bands were too short....I ended up painting them....lucky for me the Tamiya colors I used worked out ok and matched the Egyptian AF markings. All feedback is welcome.
Travis/STFD637
make an avatar
    October 2008
Posted by bsyamato on Saturday, August 13, 2011 9:43 AM
nice finish STFD637 Yes
just some imperfection i see, about the wire antenna and nose alignment
need me too to improve nmf finish Tongue Tied
    June 2009
Posted by STFD637 on Saturday, August 13, 2011 12:31 PM
bsyamato: Thanks. I noticed the nose after I had painted it. I was really suprised because there were notches to help line them up and I still had issues. I really thought  the fit on this kit would have been better being a Dragon kit. Overall it was a great kit to at least learn some things on.
As far as the antenna I had trouble finding some good pics showing the wire. I will probably tweek it if I com across some new info.
Travis/STFD637
make an avatar
    October 2008
Posted by bsyamato on Saturday, August 13, 2011 1:23 PM
it's too late but here some link
http://www.airwar.ru/other/draw/mig15.html
http://www.airwar.ru/other/draw/mig15_4+.html
And the main link with some picture, the wire seem only attacked near the cockpit to the tail, not in the middle.
http://www.airwar.ru/enc/fighter/mig15.html
Strange that dragon not put the nose pins Hmm i can expect this from amodel or other shortrun factory..
    October 2010
Posted by Casper the Chihuahua on Saturday, August 13, 2011 6:38 PM
Antennas aside, it's still good to see another finished entry! Big Smile Good to have a NMF as well. Good work and it's on the front page!
Cheers
    January 2010
Posted by CallSignOWL on Wednesday, September 7, 2011 2:08 PM
whoa, where did everybody go? its so quiet!!! Surprise
This labor day weekend allowed me to take some time off from my studies and give my brain a break. I started construction on the little Zvezda MiG-3. There was no cockpit detail whatsoever. I scratch built some simple details to busy it up, but didnt go crazy because the canopy could not be posed open to show anything off.
    October 2008
Posted by bsyamato on Wednesday, September 7, 2011 3:06 PM
CallSignOWL
http://i1024.photobucket.com/albums/y309/callsignOWL/MiG%20Alley%20GB/DSCN4554.jpg
when canopy are in a single piece , a chainsaw can really resolve needed cuts Super Angry
nice work on the cockpit Yes
By me returned from vacacy and back to computer works, just the time to complete some of oldest gb and return on the foxhound Paradise
    October 2010
Posted by Casper the Chihuahua on Wednesday, September 7, 2011 4:53 PM
Good work Owl, should be just the right level of detail for this scale. I like revealing just the hint of detail and this should work well.
Cheers
    January 2010
Posted by CallSignOWL on Sunday, September 11, 2011 7:37 PM
I went trucking on and forgot to take pics of the finished cockpit detail! oops Dunce ....nothing much, just the sidewall detail shown earlier and seat belts. I completed the construction stage and had a bit of puttying to do!! The fit of wing join on this kit wasn't that good.
after that was finished, I painted the summer camo in preparation for decaling and the white wash. I'll be doing this similar to how the original planes were painted, quickly and by hand!  Wink
    July 2008
Posted by vetteman42 on Sunday, September 11, 2011 7:41 PM
CallSignOwl nice looking lil MiG-3 you have build, well done young lady !!!!!!!!!
Randy So many to build.......So little time
    January 2010
Posted by CallSignOWL on Wednesday, September 14, 2011 11:06 AM
and, the little MiG is finished! I applied white acrylic paints with a brush over the enamel base camo, making sure to not paint over the markings. After it was dry, I smoothed/scuffed it up with some steel wool. Then the exhaust stains were applied by first dry brushing grey along the stain trail. Then using black, I dry brushed the darkest stains closer to the exhaust.
The wheel wells were too shallow, but I felt too lazy to carve them out; so I just added some basic ribbing detail instead. The antenna was made from invisible thread super glued in position and colored black with a permanent marker. I really like how everything turned out! Propeller
as always comments/critiques are appreciated!
OWL
    July 2008
Posted by vetteman42 on Wednesday, September 14, 2011 12:16 PM
CallSignOwl sweet !!!!!!!!!!!!!!!!!!!!!!!!!!!! Beautiful job on the whitewash too, sure looks battered and used   Bow Down
Theres just something about a MiG-3 ya just gotta love
    February 2011
Posted by the real red baron on Wednesday, September 14, 2011 5:02 PM
Yes Yes Yes Yes Yes 5 thumbs out of 5!!!!!!
i only wish my mig 3 will turn out as good as that!!! Bow Down Toast
    October 2010
Posted by Casper the Chihuahua on Wednesday, September 14, 2011 10:23 PM
Alright! Another completion! and a prop as to boot! YesCool
Front page updated!
Cheers
    October 2008
Posted by bsyamato on Thursday, September 15, 2011 4:40 AM
Nice MiG Owl!!! the winter camo is great, if yo allow , just try to improve the 1/72 weathering on wheels don't seems so good, the washing created a srange effect YesYes
