Japanese GB 2011-2012
    August 2011
Posted by NeedBeer on Monday, February 27, 2012 1:27 AM
Finally some progress - here are latest pics of Type O Pete
Still need to shape some form of cockpit canopy for gunner (kit didnt come with clear parts), the pilot's one was relatively easy the flat sides done with clear packaging plasticf. The rear one is meant to be rounded & covering the cockpit so not so straight forward - havent tried vac forming yet, hoping to find some packaging material in the right shape?
The wing struts were tricky, the lengths & angles were'nt correct - used the ones provided for the wing ends but they still arent seated properly & scratch built the ones fitting to the fuselage. Its quite a strong fit now
Painting & weathering - the base coat is silver, applied salt  - then coat IJN Green. Scraped off the salt then applied second coat IJN Green mixed with flat white lightly covering the metal exposed by the salt,
At this point applied gloss coat & then decals which were very good quality for such an old kit - in fact I was hoping they would crumble or flake for weathering purposes but after applying the softner & setting they were indestructable so mnimal weathering done on decals
Then used fine & rough sandpaper to expose the ribs & rivets. Finally an oily wash applied to the deeper recesses & lines
I didnt spend much time on the crew figures, not up to standard of newer kits
I'm quite happy with end result
Since taking these pics have done the rigging & some small finishing touches. Will send final pics later
WiP
1/24 Hawker Hurricane Mk I
1/48 F-22 Raptor; F-22 Idolmaster,  DH Vampire, Saab Gripen
1/72 C-130 Hercules; Vulcan
1/350 Bismarck
    October 2008
Posted by bsyamato on Monday, February 27, 2012 5:14 AM
Guys awesome updates there YesYes
Potchip another first class battleship, save some money and get a good camera, it's a sin that you cannot get good pictures of your works and some macro.
NeedBeer hat off for the pete Bow Down
I'm leaving the green another day to cure for safety
    February 2011
Posted by Reasoned on Monday, February 27, 2012 6:48 AM
Thanks tigerman.
Needbeer, looks great.  I really enjoy looking at those well weathered Jap planes.
Science is the pursiut of knowledge, faith is the pursuit of wisdom.  Peace be with you.
On the Tarmac: 1/48 Revell P-38
In the Hanger: A bunch of kits
Posted by Gamera on Monday, February 27, 2012 7:33 AM
Reasoned: My thoughts and prayers are with your wife for a swift recovery. Hopefully she'll be better and you'll be back soon. And nice job on the Val, you're halfway there.
NB: Really sharp work there! Waiting for your finished photos- not much left to do.  After the problems you had with the struts they look perfect to me.
    February 2011
Posted by Reasoned on Monday, February 27, 2012 9:42 AM
That means a lot Gamera, she'll need them.  Yeah, I keep telling myself the Val's about half way there, a break is needed.
BTW, Needbeer it is kind of nice seeing pilots in a build, gives it some added life!
    October 2008
Posted by bsyamato on Monday, February 27, 2012 9:53 AM
Reasoned i miss your situation before, good luck for your wife surgery .
    October 2008
Posted by bsyamato on Tuesday, February 28, 2012 7:53 PM
here with the zero:
After the old mixed green i used a simpler mix to apply another two green coats, this time used MM medium green and humbrol flat green
first layer
and after second
i notice a little differences between whay i see in the real kit in my hand and the pictures ,so i take the follows withouth flash (you know, the red super hero)
even if not completely convinced from the color will just start the weathering asap with lighter tones.
Posted by Gamera on Wednesday, February 29, 2012 9:16 AM
Bsyamato: Looks like you've recovered from your problems, sharp job Yes
    June 2010
Posted by DoogsATX on Wednesday, February 29, 2012 9:36 AM
Not too much to share on the Ki-84 at the moment. Been focusing on getting the Fiat into paint. But man...the cockpit on this old kit is a travesty. The floor hooks into the starboard side with two pegs, and leaves a massive gap on both sides (guess I have to spray more cockpit green...was too targeted the first time) and the rear bulkhead doesn't cover either. The seat and less-jacked instrument panel will help, but this isn't going to be one were I'll be going too crazy inside, I guess. May as well save that for the two Hasegawas I've managed to bring into the stash...
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    October 2008
Posted by bsyamato on Wednesday, February 29, 2012 9:51 AM
Thanx Cliff, just today weathered the green but no time to upload pictures Sad next problem to resolse is the aotake mix
    October 2008
Posted by bsyamato on Thursday, March 1, 2012 9:43 AM
here
Posted by Gamera on Thursday, March 1, 2012 10:20 AM
Bsyamato: Ohhhh, very nice! Really like how she's coming.
Doogs: As little as you've be able to see inside the cockpit with her closed up I'm not sure it's too much an issue. Suppose you could be a little creative and just throw something in there to give an impression of a more busy cockpit.
    June 2010
Posted by DoogsATX on Friday, March 2, 2012 9:33 AM
Gamera
Suppose I could, but I know once I started I wouldn't be able to stop, and I've been eying this Frank as something more of a quick build. Save the craziness for the big Tony and Tojo kits I've got (or the Hasegawa Frank, which is substantially more complete).
Put some work into the Ki-84 last night. Not quite ready to close her up yet, but I'm close. Still have to finish dirtying things up, but needed the glue holding the seat in place to set first.
Here's the cockpit floor and seat. Not much to it, really, but the opening is small so the seat and IP should probably be the main focus when it's built up.
Speaking of the IP, here we go:
Again, not amazing, but a heck of a lot better than what the kit suggests of cutting the decal in half, placing one on each side, and just hoping they align.
Posted by Gamera on Friday, March 2, 2012 11:19 AM
Doogs: Yeah as you said I don't think much will be visible other than the seat and instument panel. Both of those look really good Yes
    October 2008
Posted by bsyamato on Friday, March 2, 2012 7:23 PM
Glossy on, home made aotake! drybrushed the aluminiun and mixed blue, green and clear :
tomorrow probably decals and second layer of aotake
    September 2010
Posted by potchip on Friday, March 2, 2012 8:06 PM
bsyamato, that's mighty impressive result using a brush!
    June 2010
Posted by DoogsATX on Sunday, March 4, 2012 8:31 AM
A few pics. This one is just so far off the mark from usual (even usual older) Tamiya that I'm kinda stunned. Feels like a totally different manufacturer.
Here's the overall plane. When I was closing the fuselage last night, I had a total brain fart and installed the machine gun cover backward. Bang Head The fit was really poor, so I flooded it with Tenax from the inside...we'll see if I can even get it out. If not...we'll see.
The instrument panel:
The seat:
Is it just me, or does the engine seem to sit low? That's where the kit locates it, but still?
    July 2007
Posted by troublemaker66 on Sunday, March 4, 2012 9:16 AM
DoogsATX
http://i780.photobucket.com/albums/yy86/doogsatx/Aircraft/Tamiya%20Ki-84/file-28.jpg
http://i780.photobucket.com/albums/yy86/doogsatx/Aircraft/Tamiya%20Ki-84/file-29.jpg
The seat:
http://i780.photobucket.com/albums/yy86/doogsatx/Aircraft/Tamiya%20Ki-84/file-30.jpg
http://i780.photobucket.com/albums/yy86/doogsatx/Aircraft/Tamiya%20Ki-84/file-31.jpg
First the gun cover, now you went and installed the engine upside down...Stick out tongue  I`ve come across some `ify` Tamiya kits too...seems like the older ones. Although the engine looks low it could be in the correct position...references are the only way to be sure. I`m so impressed with your IP I spent alot of time this weekend trying to hunt down a punch set. Saw one from Micro-mark for around $50. Now I just have to get it passed the wifey....
Len Pytlewski
    June 2010
Posted by DoogsATX on Sunday, March 4, 2012 11:00 AM
Ok so the cowl was upside down...good thing I hadn't gotten to the point of gluing it yet.
Gun deck will still pose problems:
Posted by Gamera on Sunday, March 4, 2012 6:32 PM
Bsyamato: Very cool, never tried pre-shading with a brush but what you've got going there looks really good.
Doogs: Great job on the cockpit, with the eye drawn to the grat looking IP and seat I doubt anyone will notice how sparse the rest is. Not sure how you can get the MG cover out without sawing or cutting. Tenax is such strong stuff... Good luck - at least the engine shouldn't be too hard to fix.
    August 2009
Posted by TREYZX10R on Sunday, March 4, 2012 7:06 PM
Bsyamato great looking preshade and brush painted to boot !
Doogs looking sharp,too bad about the gun cowl. I hope its an easy
Cliff can you put me down for a Tamiya 1/48 N1K1 Kyofu type 11 please
    June 2010
Posted by DoogsATX on Sunday, March 4, 2012 9:57 PM
Well, I guess it's time to say "dammit Jim, I'm a modeler, not a surgeon!". The gun deck is well and truly screwed. I could get it out, but it'd come at the price of jacking up the entire cowl. Think I'll salvage the Ultracast seat and use the shell as a paint mule.
On the bright side, I've got two Hasegawa -84s in the stash (how'd those get there?), so the weird blue and black markings can live to see another day!
In the meantime, put me down for this guy, Hasegawa's N1K1-Ja Shiden. Should be a good candidate to mess with my new AK Chipping Fluids.
Snagged this one from Sprue Bros last week for $20:
Soaked it this afternoon, just in case. Parts looks crisp and very nice. Some reviews moan about a skimpy cockpit, but after the Tamiya Ki-84, yeah, this isn't skimpy.
Posted by tigerman on Monday, March 5, 2012 1:45 AM
Yay, Trey is going to build yet another.
Bsyamato, nice distressed look.
Doogs: whoops! Hope there's a cure.
 Eric
    October 2008
Posted by bsyamato on Monday, March 5, 2012 9:54 AM
Thanx guys Toast
Trey nice to see another startirg from you Yes
This last week really had few time for the workbench but here some zrero decals picture. Engine and propeller just put on withouth glue
During the decals stage was thinkin about the wings yellow stripes when i relize airfix put them on the decals sheet Tongue Tied
    December 2009
Posted by Vincent Price on Monday, March 5, 2012 12:51 PM
That's a beautifully detailed and weathered 'Zeke' ! I particulary love the engine detail and cockpit, great work :-)
Posted by Gamera on Monday, March 5, 2012 12:53 PM
Trey & Doogs: Ok, updated the roster page. Looking forward to seeing you guys tear into those.
Doogs: Well I guess you could do say a dio and have a tarp pulled off the canopy forward to hide the cowling.
Bsyamato: Wow, great job there!
    June 2010
Posted by DoogsATX on Monday, March 5, 2012 1:05 PM
Gamera
Could be interesting to do it as one of the US evaluators...but for now I'll be using it to test chipping techniques.
I was hoping to get a start on the George last night. Alas, work called. Tonight, after I get the flaps and insignia backing done on the Fiat, it'll be prime time for the George and Ventura interior bits.
    October 2008
tokyo raid !!!!
Posted by bsyamato on Monday, March 5, 2012 5:14 PM
Thanx guys ,just sealed decals with another clear layer and painted more minor details, tomorow will wash panel lines...
..but most important ,tonight performed an ebay raid on tokyo and bought five ww2 jap planes Embarrassed
the Val, tenzan, judy (radial version), and the claude from fujimi, and a jack from hasegawa Angel all in 1/72
Price of kits was low (judy at 5€ ) and hope to repeat the raid if all go right with the first one.
    September 2011
Posted by David Maddog on Monday, March 5, 2012 6:51 PM
I hope I didn't miss the party, I've started my first plane, a Hasegawa Val, that I'd like to contribute.
Posted by tigerman on Monday, March 5, 2012 7:21 PM
I've seen it Dave and yes you should be admitted. Big Smile
This coming from the number one cheerleader of the Japanese GB. Cool
 Eric
