I've been lurking here long enough, so I decided to start the Tamiya Panzer II. I have been really impressed with the colorful camo of those French tanks, but have not seen any white flags on them yet???
I picked up the Tamiya French Campaign Panzer II and will be doing the A/B model. I picked this model, because it has a smoke dispenser on the muffler and I think that looks cool. This is basicly Tamiya's Polish Campaign Panzer II, but with the added on armor the German put on to give this tank a little longer combat life. I am planning on doing the brown over gray camo that wbill posted on about page 3.
I am not sure if I will do the figure. It's kind of small and the Verlinden heads I have are way too big for it.
Care needs to be taken on the suspension becasue the rear (far right) leaf spring assembly is different the other four. It has a shallower angle and the upper mount is lower on the hull. I almost messed this up.
In step 6 there is some Haji-speak that confused me for a minute. It says "Remove the design"
I was hesitant to start cutting details off without figuring out why, then I remembered this tank was upgraded with armor. So I did some dry fitting and then it all became clear.
You have to cut off the original driver's visor mounts off so the add-on armor lays flush.
This kit is building up really quick. After spending months on a Dragon M7 Priest, it's nice to have this much done in only 2 nights.
Cheers,
