Big Beautiful Jugs - OFFICIAL P-47 GROUP BUILD
    August 2007
Posted by some assembly required on Sunday, February 19, 2012 7:17 PM
cool, thanks guys
    January 2003
Posted by p38jl on Sunday, February 19, 2012 7:29 PM
Nice Job Doogs !Yes
[Photobucket]
    February 2010
Posted by Bockscar on Sunday, February 19, 2012 8:44 PM
Doogs;
Congratulations, I wouldn't mind seeing that in an upcoming FSM feature.
Toast
    January 2012
Posted by Von Sisco on Monday, February 20, 2012 6:54 AM
Great work Doogs, congrats on your class win! MC looks incredible, what a unique paint job.
Ed Sisco
On the bench: 1/48 Hobby Boss F3H-2 Demon & 1/48 Trumpeter F9F-2 Panther
On deck: 1/48 Grand Phoenix FJ-4 Fury double build
Posted by Gamera on Monday, February 20, 2012 7:37 AM
DOOGS! BIG CONGRADS on your well deserved win!!! Bow Down
Beautiful model, and I think you're allowed a short nap before you start on your second jug Stick out tongue
Tom: Yeah, that's what I need is a monster paint booth though it would help not to paint in my dusty basement. Still yeah Alclad is pretty easy to sand trash out and repaint.
Joe: Very nice, you're humming right along.
    August 2009
Posted by JOE RIX on Monday, February 20, 2012 7:47 AM
 I also recommend Tamiya XF-69 NATO Black for tires. Looks quite nice.
                                                Joe
"Not only do I not know what's going on, I wouldn't know what to do about it if I did". George Carlin
    June 2010
Posted by DoogsATX on Monday, February 20, 2012 11:32 AM
So I know I said I didn't want to just work on "The Bug", but, well, I hate leaving a task unattended to...
Masked off the cowl (protecting decals with paper covers):
Masked and sprayed red triangles with Tamiya Flat Red with some Hull Red and Red Brown added to more-or-less match the decals:
Because of the way they line up, had to mask every other one, spray, then go back and mask the ones I'd missed.
End result:
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    December 2004
Posted by panzerpilot on Monday, February 20, 2012 12:21 PM
Nice Doogs! Worthy of another plaque, no less!
I got the MM OD enamel on...
-Tom
    June 2010
Posted by DoogsATX on Monday, February 20, 2012 5:12 PM
Looking great Tom!
Got a rare bit of daylight modeling in today since the wife took longer leaving Houston than she'd planned. Sprayed a filter of OD over the markings to fade them a bit. Unmasked the canopy. It's gettin' there...
    December 2004
Posted by panzerpilot on Monday, February 20, 2012 5:32 PM
Awesome! You're there. Looks like some weathering and the gear, then done? You gonna build anymore jugs, or are you on to Gamera's build?
Thanks! On a side note, I think it was Gamera that brought up flaking and alclad? I will very lightly sand my next NMF build's primer a bit, for adhesion reasons. For the most part, I have only had an issue with flaking on the leading edges, where I was handling it. I did have a tiny fleck come off around the taped areas for the OD, which caused me a bit of trouble. It probably wouldn't be a bad idea to "seal" the alclad asap, before taping, etc.
I just got my alclad gloss in, so overcoat tonight, followed hopefully with the decals tomorrow, then light sheen, gear and bombs. She'll be done...er, almost. Carpet monster, or otherwise, ate my tailwheel gear strut. A call to Hasegawa today for a replacement part remedied that,...as well as an identical kit ordered, for an encore 1/32 Jug, "Wee Speck", soon.
-Tom
    September 2009
Posted by satch_ip on Monday, February 20, 2012 6:36 PM
Did some work on Lucky today.  Knee surgery tomorrow so I should be able to model without interruption!
I tried the Doogs method of preshading.
Life Color OD with some Faded OD 1 postshading.  My OD is significantly lighter than Doogs'
More to follow...
satch
    June 2010
Posted by DoogsATX on Monday, February 20, 2012 9:09 PM
Tom - yeah, still need to do ordnance (bombs and bazooka rockets) too, and the bombs are still on the sprue tree. But definitely home stretch!
Once this one's wrapped I'll be doing some non Jugs, but I'm planning to do Trumpy's big P-47N before too long. Too many things up in the air for me to put a time to it though...
    December 2004
Posted by panzerpilot on Monday, February 20, 2012 9:15 PM
Good deal. That Trumpy P-47N looks like a great kit.
Did the gear and bombs tonight. Ready for the clear coat! I'll be on to my 109 next, then the Tony.
-Tom
    November 2008
Posted by Wabashwheels on Monday, February 20, 2012 9:52 PM
Well, I'll humbly slip in here with a couple photos of the start up of my Academy P-47N.
I have heard some disparaging remarks about this kit, so I had to find out for myself.  It's been setting in the stash for several years, and I just happened to have a Eduard interior zoom detail set for it.  I wanted to show the sidewalls of the cockpit.  The interior details are not all that bad for a cheap kit.
The IP painted up very well.  I used the painted toothpick rolled across the raised details to paint the panel.  It proved to be a very effective method.  The panel looked so good that I saved the Eduard panel for another day.  The cockpit worked nicely.  A combination of Eduard placards and handles, with some scratchbuilt stuff busied up the office.  Sorry, no photo.
The kit engine provides some nice detail also.  I added the ignition harness using 26 gauge speaker wire.  It's not real noticeable on the finished model, but it gives a lot of depth if you're looking close.
I've plugged along a little further, wings are all in place.  Cowl, gun barrel inserts, wing pylons are all in place.  I think I'm about ready to prime.  I'll be eventually finishing with an Alclad NMF.  Rick.
Posted by oortiz10 on Monday, February 20, 2012 11:13 PM
Alright ladies and germs,
I’m calling the “Mystery Jug” done!  Getting the windscreen masked, painted, and reinstalled after I accidentally knocked it off took forever!  (It wasn’t for lack of trying, but rather lack of time.)
Anyway, here are some pix of the final product.  Feel free to share your comments and criticisms.
Thanks for lookin’!
Cheers,
-O
-It's Omar, but they call me "O".
    December 2004
Posted by panzerpilot on Monday, February 20, 2012 11:43 PM
O, Bang up job. Very Nice.
What did you use for the panel lines and overall weathering? Is that a bottle of Flory black, about halfway down? I really like those tail stripes. Congrats on finishing!
-Tom
Posted by Gamera on Tuesday, February 21, 2012 7:33 AM
O- I think the 'O' stands for 'outstanding'! Great job, esp love the tail stripes- I have problems with stuff like that.
Satch & WW: Great work there too!
Tom & Doogs: Gee, you guys are almost done. Great work.
Guys, I think I've hit one of those modeling slumps here, sprayed white on the tail surfaces of '2 Big & 2 Heavy' as a undercoat since they're painted bright yellow and the paint cracked like crazy once it dried. Guess I'll have to sand the whole thing down and hope it doesn't happen again. I think it's the low humidity and the paint is drying too fast or some such. Kinda peeved and don't want to look at the model right now, I just feel a need to walk away for awhile.
    June 2010
Posted by DoogsATX on Tuesday, February 21, 2012 7:44 AM
O - GORGEOUS! Great job on the NMF, and I absolutely love the tail striping! I'll get it up on the front page!
Gamera - sorry to hear about the cracking - that's awful! My biggest environmental issue right now is moths. Friggin' things.
    June 2010
Posted by DoogsATX on Tuesday, February 21, 2012 7:53 AM
Satch - man you weren't kidding, that Lifecolor OD is definitely lighter than either OD I'm using! Looking forward to seeing it come through paint!
    June 2010
Posted by DoogsATX on Tuesday, February 21, 2012 7:59 AM
Bit more done on "The Bug" last night. Wash. Chipping. Guns added. Gear struts glued in. Still have to fix tires, tailwheel, canopy, inner gear doors, and paint and mount the bombs.
This one's the product of some fun with filters on the iPhone, but hey, looks nice and mean!
Posted by VanceCrozier on Tuesday, February 21, 2012 8:01 AM
Gamera
... and the paint cracked like crazy once it dried. Guess I'll have to sand the whole thing down and hope it doesn't happen again. I think it's the low humidity and the paint is drying too fast or some such....
If your conditions remain similar, you may be able to use the same paint mix, but build up the colour in several mist coats to avoid the cracking....
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
Posted by Gamera on Tuesday, February 21, 2012 8:37 AM
VanceCrozier
 Gamera:
Vance- thanks!
Sounds like a good idea, I only have the cracking on light colours- I'm thinking it may be a result of spraying them heavier than I would a dark paint. I was thinking of mixing a little retarder into the paint hoping that if it dries slower I won't get the cracking. Still I don't think I can go wrong with a few extra mist coats either.
Doogs: I am going to start called you- The Jugmaster.... Wink
Posted by oortiz10 on Tuesday, February 21, 2012 9:13 AM
Thanks for the kudos everyone.  I'm glad you like 'er.  She provided some good overall skills practice.
panzerpilot
Tom, the weathering started out as an experiment.  I first sprayed the whole airframe with Alclad's micofiller white primer, then followed that with Alclad's White Aluminum.  Next, I used gloss black from Testors' little square bottles and shaded some panel lines.  Then I used various shades of White Aluminum mixed with different amounts of Alclad Steel to cover the panel lines and fill in the panels.  And talk about eagle eyed, yes, that's Promodeller...er...Flory's wash on my desk.  I mixed up a dark grey for the panel lines.  Streaking and staining were done with pastels and ink.
Again, thanks for lookin'!
-O
    January 2012
Posted by Von Sisco on Tuesday, February 21, 2012 9:41 AM
O-Fantastic work, I really like your paint and detail work.
satch-Coming along very nice!
Doogs-"The Bug" looks awesome! Your pic taken with your phone looks great!
Ed Sisco
    December 2004
Posted by panzerpilot on Tuesday, February 21, 2012 10:19 PM
Bombs..
I painted them with MM OD, misted with MM "faded OD", then brushed with Burnt Umber oil.
-Tom
Posted by jeaton01 on Tuesday, February 21, 2012 11:27 PM
Omar and Doogs, you are both definitely building to high standards!
John
Posted by Gamera on Wednesday, February 22, 2012 7:49 AM
Tom,
Those bombs look sharp, I have to admit I tend just to paint them OD green and that's pretty much it. I suppose if you're going to detail up the plane you need to do the stuff hanging off the wing too. Good show!
Vance,
Seems to have taken care of the problem, didn't sand down enough to get rid of all the cracking so I'm going to have to repaint them yet again but at least I'm now on the right track.
Cliff
    January 2012
Posted by Von Sisco on Wednesday, February 22, 2012 1:05 PM
Tom-The bombs look VERY realistic, I'm gonna steal, I mean, liberate that idea for mine! I "chipped" mine the last time, but looking back I don't feel it is very realistic. Maybe on the fins where they banged around on the cart. Anyway, great work.
I finally got a new laptop and should be posting progress this weekend. As I said before, Some Punkins is done and I have moved on to Patsy. I'm lovin' the Tamiya kit! See y'all soon-
Ed Sisco
    December 2004
Posted by panzerpilot on Wednesday, February 22, 2012 1:21 PM
Thanks guys..
I 'almost' didn't use the decals, as many of the pics I've seen didn't have any yellow stripes, except for around the nose.
Looking forward to your pics, Ed!
-Tom
    June 2010
Posted by DoogsATX on Wednesday, February 22, 2012 1:30 PM
panzerpilot
Thanks guys..
I'm going to try painting the splodey-things yellow, the masking the stripes on my Revellogram. We'll see. Still wish someone made the clusterbomb setup. Ton of work, but how awesome would this look?
