DIRT CAR GROUP BUILD, Cause we like em dirty
    July 2008
Posted by vetteman42 on Thursday, November 29, 2012 12:37 PM
Wildchild yes that would be the Revell B-29 in 1/48 scale, lotsa plastic to play with on this one.
Dog ate my Stuka so that's no longer, and real life has kept me from the bench for sometime now both mentally and physically.
The 77x car is looking great man !!!! The foil you used on the fenders really worked out well, looks real ! The tears are an over the top touch too as they really make it look convincing. Bow DownBow Down
Randy So many to build.......So little time
    December 2010
Posted by TheWildChild on Tuesday, December 25, 2012 7:45 PM
Ahhh that 29 is a big kit! Can build up great too!
havent touched the 77x car lately, but I have started a 65%+ rebuild of my first re-entry into demo derby modeling, this is what I got so far:
This is the starter, 64 impala with non-stock low rider suspension (2-link rear end instead of leaf springs)
1/35 XM77  "Sledgehammer", 1964 Chevy Impala Derby Car
Whats next? Aircraft for Ground Attack Group Build
"I dont just tackle to make a play, I tackle to break your will." -Ray Lewis
"In the end, we're all just chalk lines on the concrete, drawn only to be washed away"- 5 Finger Death Punch
"Ahh, my old enemy.......STAIRS"- Po, Kung Fu Panda
    December 2010
Posted by TheWildChild on Tuesday, December 25, 2012 8:13 PM
    December 2010
Posted by TheWildChild on Tuesday, December 25, 2012 8:18 PM
Sorry for the double pictures. I leafed the rear suspension, this was a low rider kit, so it had a 2-link rear suspension. I hacked off the front clip, and made the fenders out of popcan aluminum (just like the 77x car) and added a brass hood (3 hours to cut, bend to "stock", trim to fit, smash and mangle, and add the angle iron "locks"). I angled the subframe up more to really give this car the used and abused look. I also took out the 426 HEMI I was going to use, it was too big to fit in the engine compartment with stacks because of the reinforcement beams. I am going to make th whole rear end (possibly the frame and everything) out of aluminum and brass as well.
    December 2010
Posted by TheWildChild on Thursday, December 27, 2012 9:24 AM
Also, forgot to mention because I was in a hurry, I will be weathering this car (and the 77x car) with the mud method I used on a Tiger I. Basically just make mud out of water, tamiya smoke, and brown/tan weathering powders. Smoke makes it dry looking like wet mud, but also darkens the pigments, so it takes some trial and error to get it right. I also have to add/build new bumpers, window cage on the drivers side, roof bar, interior door panels (just the metal that would be exposed after the door panels were removed), I already added the "radi-barrel" by putting te brass sleeve around the radiator and denting/scratching it. The ones on our real cars are just a welded 1/2" plate sleeve that goes all the way around the radiator and is welded to the core support... Really helps tie the car together. Also have to add new "threaded rod" through the hood and trunk, new bumper mounts (made from cut square tube), wire the motor and battery, and make "my shark".
    July 2008
Posted by vetteman42 on Saturday, January 5, 2013 11:58 PM
That looks over the top great Wildchild !!!!!!!!!!!!!!! You are an artist with soda pop cans, brass and plastic. Those chains in the windshield are an interesting touch too.
    December 2010
Posted by TheWildChild on Monday, January 7, 2013 6:52 PM
I will be adding more pictures in about an hour, maybe sooner. It now has a 410 cu in sprint car motor, fully re-plumbed and wired to fit tighter confines, a NASCAR transmission, and staggered 4-in-a-row stacks. Be back soon!!
    December 2010
Posted by TheWildChild on Monday, January 7, 2013 6:54 PM
As well as both rear quarters and trunk being popcan too.
    December 2010
Posted by TheWildChild on Monday, January 7, 2013 7:12 PM
    December 2010
Posted by TheWildChild on Monday, January 7, 2013 7:21 PM
That's what I have so far.
Regards, Logan
    July 2008
Posted by vetteman42 on Friday, January 18, 2013 11:53 PM
Oh yes I like those soda pop can quarter panels much much better !!!!!!!!
I am thinking I might start an Edmunds Super Modified in the next week or so.
    December 2010
Posted by TheWildChild on Saturday, January 19, 2013 11:50 AM
    December 2010
Posted by TheWildChild on Saturday, January 19, 2013 11:54 AM
Looks even better with paint.
    December 2010
Posted by TheWildChild on Saturday, January 19, 2013 12:01 PM
    December 2010
Posted by TheWildChild on Saturday, January 19, 2013 12:06 PM
 Red car rebuild start...
    December 2010
Posted by TheWildChild on Saturday, January 19, 2013 12:12 PM
I added the 3/4" to 1 1/4" (scale-ish) threaded rod made with tailoring pins
    December 2010
Posted by TheWildChild on Saturday, January 19, 2013 12:19 PM
Sorry for all the posts lol, my phone is having some issues working with the full site formatting. I put a 410 mopar sprint car motor in the black and blue car, after I added a starter, modified oil pan, stacks, cut/removed/changed some of the wires and hoses, and filed down the injectors to let the air filter sit lower. The car that is red at the moment, will be painted in the same black and blue with white trim, but with a ford power plant(Chevy guys are going to put a bounty on my head lol)
I was recently offered 300bucks for my black car, but I don't foresee myself selling it. I hope amt rereleases the kits of their 60s Chrysler Imperials, I have had so many requests for them from other drivers on Facebook I'm going nuts lol. I can't wait to see your modified! Especially if you pull it off as well as the sprint!
    July 2008
Posted by vetteman42 on Friday, February 8, 2013 8:22 PM
Not to worry about the posts Smile Man I gotta try the pop can trick one day. AMT may rerelease them again I have been seeing a bunch of the older kits being repopped lately.
If I can get real life to settle down I can get back to the bench again havent worked on anything in way too long.
    December 2010
Posted by TheWildChild on Sunday, February 10, 2013 11:42 AM
They are rereleasing the Christine Plymouth fury soon(57 or 58?), and I will have at least 2 of them (pre order at the local hobby shop lol). The imperials have always been my favorite: near me in pine city Minnesota, it's one of very few places that still allow them to run because they are so strong (I believe they are the only post-1960 car without crumple zones or crush holes cut in the frame... As it's as big as a full size dodge truck frame), and they are unlimited modified: no rules on reinforcent as long as it doesent stick out from the car. They all run stroker motors or modern modified/dir late model engines.... I. Can't. Wait. To get my hands on one.
Both cars are painted now, as well as the tractor, custom flatbed trailer, and started on yet another dirt project: 1950 Chevy pick up(with a 426 HEMI, heavy leafs, and some old Goodyear racing tires with NASCAR rims), that will have a scratched 5th wheel trailer, and 1957 Chevy derby car on the trailer.
I'll put new pics up ASAP.
    July 2008
Posted by vetteman42 on Sunday, March 17, 2013 12:41 AM
Got pictures yet Wildchild ????? dyin to see them.
    October 2010
Posted by Dogfish_7 on Wednesday, March 20, 2013 4:46 PM
Is this Build over? Is there a Badge for this Build?
Bruce
    July 2008
Posted by vetteman42 on Thursday, March 21, 2013 12:05 AM
Dogfish_7 the build ended on Jan 1 2013 but seems that it has unoffically been extended some, and yes there is a group badge on the front page. What do you have in mind ?
    October 2010
Posted by Dogfish_7 on Monday, April 8, 2013 7:52 AM
Never mind, maybe next time.
Bruce
