I realize I missed posting up yesterday (I've been aiming for every Sunday), but it was a busy day with dogs. It was a slow week, overall, as I was hung up on my wheel bay. That got sorted this morning as I received a couple of sets of Aires machine guns (151's and 131's) which will allow me to place them in the wheel bay and paint and prime the wheel bay. Then, with the wheel bay mounted in the lower wing, I should be able to begin mounting wings. This week, I joined my fuselage halves, mounted stabilizers and elevators, and the rudder. I'm using a mix of Aires and CMK control surfaces (the CMK rudder was a little 'fatter' and fit better). I got the windscreen masked, painted and mounted, ensuring I had the gun sight fit and mounted first. I also got a bit of work done on the propeller hub (again, a CMK offering) and started work on Scale Model Conversions' main landing gear. I did not like their 'scissor spring' (not sure what it's actually called, but that's how I think of it) so I carefully removed the white metal and added in Eduard's etched parts.
I'd also started painting around the wheel bay on the lower wing, this way I can put the pre - painted resin insert in, just do a rough mask around the area, and not have to worry about doing a tight mask on those akward curves. I tried this recently on my Typhoon (which is just about done, just working on a display base and surround) and it worked out beatifuly. I'm hoping to have the same success here. I had a big stumbling block when I tried painting Vallejo's 'RLM 76', which is no where near the right color to my eye. It's a very pale grey, with almost none of the blue to it. One evening of patiently mixing paints in a few mixing bottles, trying a dab against my color chart, and I found I had a blue that looked quite passable, and even more so when weathered. Luckily, I was smart enough to write down my mix ratios as I went, so I can reproduce it. As much as I hate mixing my own colors, I knew I couldn't put that light grey down and call it good enough. A few attempts (and in between, stripping and re-priming) at the lower wing and I had what I was happy with.
And that's my progress so far.
