THE OFFICIAL IN THE BUFF B52 GROUP BUILD
    April 2012
Posted by Striker8241 on Tuesday, July 2, 2013 7:08 AM
Good source of information, Jim. Thanks!
Russ
    February 2010
Posted by Bockscar on Wednesday, July 3, 2013 7:02 PM
Buffirn
Just in case you didn't know about this site.
www.joebaugher.com/.../usafserials.html
You can find some basic history about any aircraft from the USAF based on year and serial number.  Kind of neat!
Jim,
Thanks for that link, very neat alright, as in yikes, they are all there, it's like a parade
of ghosts, and they've brought along their pasts!
Dom
    February 2010
Posted by Bockscar on Tuesday, July 9, 2013 1:17 PM
Many thanks to Russ for getting those Mk 82's together for me!Bow DownYes
I must also say that Russ' technical skills really shone through, the tails are aligned perfectly!Geeked
Now I need to find a way to get the fuses in. I am thinking that because
they are so small, use the brass-coloured paint and just paint them in.
Suggestions welcome!
Dom
    April 2012
Posted by Striker8241 on Tuesday, July 9, 2013 2:18 PM
Dom,
If you ream the hole out a bit you can insert the stem of the fuse and any type of glue should hold it in. White glue or carpenter's glue, or even rubber cement. The paint will help seal them in.
Glad the bombs arrived ok.
Russ
    February 2010
Posted by Bockscar on Tuesday, July 9, 2013 4:13 PM
Yeah Russ, I'll give that a try.
I was tempted to try the paint hood to put in the fuses with CA, but if it goes wrong,
I am pooched.
still need a way to glue them to the panels, I will try white glue or gator grip.
Dom
    April 2012
Posted by Striker8241 on Tuesday, July 9, 2013 5:43 PM
Hey, Dom,
Some type of flexible glue might be better for that - like a good rubber cement or fabric glue. How about RTV?
Russ
    June 2003
Posted by Duke Maddog on Tuesday, July 9, 2013 6:54 PM
Gator Grip glue is quite flexible and holds very well. That should work perfectly. Looking forward to seeing pics.
    March 2009
Posted by Buffirn on Wednesday, July 10, 2013 5:11 AM
For complete accuracy, you need to tap and drill both parts and screw the fuzes in just like the real thing!
Jim Williams
    March 2009
Don't forget the arming wires and fahnestock!
Jim Williams
    February 2010
Posted by Bockscar on Wednesday, July 10, 2013 2:18 PM
Guys,
Thanks for the suggestions,
Russ, what is RTV? is that a silicone compound, is there a brand I should look for?
Jim; yeah, I think i found a set at MicoMark....lol.......just looked up 'fahnestock'.......could have used that
around for the last 50 years.....
Now my desk is buried again.......I recently got in some Japanese sharpening stones to hone my sharpening skills...ha ha...and the BUFF stuff is buried under old hunting knives and stones of various grit....
it's sick what a 50 year old folding trout knife can do when it is honed to 10,000 grit......
Dom
    February 2010
Posted by Bockscar on Wednesday, July 10, 2013 2:21 PM
Duke Maddog
Duke,
I have Gator Grip, and I've been trying to find its ideal application. I'll give it a try as well. It's easy to use, and water/wipe clean up, which is great.
Dom
    April 2012
Posted by Striker8241 on Wednesday, July 10, 2013 3:17 PM
Dom,
Go with the Gator Glue first like Duke says. If that doesn't work, the RTV might. It's a silicone cement. Comes in large as well as small tubes. There are many kinds but probably any type would do. You'll only be using a tiny amount anyway. We used it working on aircraft and I use it sometimes on my car.
Russ
    February 2010
Posted by Bockscar on Wednesday, July 10, 2013 5:19 PM
Yeah Russ;
I realized that because the stacked bombs can only be seen from the bottom,
I can probably put a good fillet of glue on the top seam and no one will see it.
I will look for the RTV up here, i had to throw away the lepage's expoxy,
they forgot how to make glue over there, so I need an alternate.
Dom
    February 2010
Posted by Bockscar on Saturday, July 13, 2013 8:15 PM
Big Bomber fans;
The Sanger 1/48 B-47 arrived, it cost me about $75, which is well worth it.
very close attention to outline.
I can't load the photos as my server is being 'maintained' but will get
them here prawley two more uh.
I'm going to get the 1/48 BUFF for sure, hold me back!
dom
    April 2012
Posted by Striker8241 on Saturday, July 13, 2013 10:37 PM
Ouch, Dom!
Where are you going to park that thing...those things? They'll be nearly twice as big as the 1/72 scale versions. Plus, the larger scale cries out for more detail in just about every area, unless the kit is really detailed. Can you imagine the price of the aftermarket kits???
Warm up your scratch building skills Big Smile.
Russ
    February 2010
Posted by Bockscar on Sunday, July 14, 2013 1:28 AM
Yeah Russ;
Big alright.
i still can't load the photos,
but the B-47's wings in 1/48 are about 2 inches shorter than our
beloved 1/72 Mono-Rev BUFFs.
And the fuselage is actually just a wee bit longer than the 1/72 BUFF.
It is, However, like a civilian plane in diameter, about 0.5 inch wider than
the 1/72 BUFF.
it's a bit of a moot point right now, i have been so preoccupied, i haven't
had a chance to get to my bench for recreation.
I did clean it up yesterday, but Russ, I'll never get all these kits built.
The 1/48 BUFF, if Sanger finishes it, and i get it, will be about three feet long,
and I'm guessing over 40 inches for the wingspan, but those are not calculated,
'cause I am tired.
Sanger is great for photos:
"hey I caught this with a 10 lb test line......."
Copyright: Sanger: http://www.rbogash.com/b52photo.htm
Many thanks to Sanger for the photos, spectacular!
Dom
    March 2009
Posted by Buffirn on Sunday, July 14, 2013 11:14 PM
I contacted Sanger a few weeks back and got this response.
Hello Jim,
Thank you for you email which was sent some while ago, regarding the forthcoming 1/48th B-52 Stratofortress kit.
Firstly I apologise for the delay in replying to you valued email.
I have been unable to complete the kit to date because of severe work commitments. However, I have now given up my full time employment and will now be working full time on the modelling business.
Currently I am finishing off the 'masters' for a 1/48th Sunderland Flying Boat and as soon as this is completed and released, I will complete the B-52 kit.
The B-52 'masters' are all made, except for the upper wings. It will not take long to complete these, after which I can complete the moulds - do test runs and release the kit in it advertised variants.
I really do appreciate your thoughts and expression of interest in the kit, it had just become impossible to work full time and run the model business.
Your interest in the kit has been filed and I will be pleased to advise you just as soon as the kit is ready for despatch, should you still be interested.
Thank you for you time and interest.
Regards,
Gerald
So, there is something to look forward to. Yes
Jim Williams
    February 2010
Posted by Bockscar on Friday, July 19, 2013 6:04 PM
Yeah Jim;
I'll have to clean out a room to fit it!
Well, a bit of bad news; I got home early today, and with
the bench top cleaned off again, I started working.
But not for long, my right thumb gripped reak hard
on the edge of a new X-Acto blade, and I got a 1/2 inch slice for not
paying attention. Why do dogs lick your blood up off
the floor? Well, at least I didn't have to go on bio-haz
duty to clean it up.
Good news is that it is shallow, but fairly long. Dang......
Dom
    April 2012
Posted by Striker8241 on Friday, July 19, 2013 6:19 PM
We have met the enemy, and he is us... Big Smile
I have two deep gashes in my left forefinger just from this past week. We should get a medal for our efforts - we could call it the "Purple Finger Award" Toast  lol.
Hope ye heal sooner,
Russ
    February 2010
Posted by Bockscar on Friday, July 19, 2013 7:22 PM
Hey, that's right, Walt Big Smile
Pain's gone, but every time I go to do something,
I think I need a stitch.....where's the
sewing kit....lol
Dom
    April 2012
Posted by Striker8241 on Friday, July 19, 2013 10:08 PM
Now this would be a good time for super glue....
    February 2010
Posted by Bockscar on Sunday, July 21, 2013 3:58 PM
Russ:
Almost wish I had. It stopped bleeding last night, and i got some work done today,
a few more Mk-117's.
Wounds are all relative; if you were standing around, minding your own SAM site,
and a 117 hatched nearby, just imagine all the band-aids it would take to
fix that owee!
As I've been working on them, I've noticed that the completed bomb is far from round in
cross section. i don't suppose anyone will get close enough to notice, but it means
a fairly large seam line.
The scratch cut out units, oddly enough, are perfectly round. just more fun at
Ye Olde Bhombe Shoppe.
Then there's the fuses, i.e. they look more like little grease nipples.
I'll have to cut down the long fuses from the Verlinden, if that is OK.
Dom
    April 2012
Posted by Striker8241 on Sunday, July 21, 2013 5:43 PM
Hey, Dom,
Yeah, for the amount of money they charge for a little bit of resin you'd think they could do a better job. Many of the bombs I built for my clips are slightly flattened or out of round. And the fins look like the mold is out of alignment. Fortunately, they won't be viewed up close.
As for the fuses, why do you need to cut down the long fuses? I sent all the fuses back with the completed bombs. However, if you need extra ones, you're right - you can just cut the tip off the long fuses. They're the same as for the MK-182s.
Cheers,
Russ
    February 2010
Posted by Bockscar on Sunday, July 21, 2013 6:12 PM
Hey Russ:
I was working on the kit supplied styrene bombs in the Revell kit. Looks like I messed a few of
them up real good, so i spent a few hours trying to make them look better.
The Verlinden bombs look pretty good by comparison, mind you that huge access panel
at the back of the Mk-182's is big enough for me open up and set the fuse pins myself!
Thanks for the info about the fuses being the same, I forgot to ask, so I think I may have enough
and if not I'll just use the Verlinden fuse shafts anyways.
Thanks,
Dom
    March 2009
Posted by Buffirn on Monday, July 22, 2013 12:57 AM
Some motivation.
K. I. Sawyer BUFF in the Big Bear MOA playing with the Boys from Selfridge.   Low level fighter intercept training.  Loads of fun and a bit of nausea.  I could be on that plane, but who knows for sure?
Doors open,  FCI centered
Airshow bomb run.
There ya go!  Now back to building!
Jim Williams
    February 2010
Posted by Bockscar on Monday, July 22, 2013 7:41 PM
Jim:
Thanks for the great photos! -Added to my
BUFFology sectionBig Smile
I never knew F-4's and BUFFs flew in 'formation'Whistling
Seeing a B-52 with its bomb bay doors open is like
haiku - your brain automatically knows what the next
sentence in the 'poem' is.....LOL.......
Dom
    March 2009
Posted by Buffirn on Friday, August 9, 2013 5:00 PM
Well, these have taken much too long.  Stupid job!  Anyway, this is still a WIP and I am no Russ, but I am enjoying this.  The green is just construction paper but will end up as flocking.  The next step is to mount this to something like hardboard.  I should finish this soon.  I still need  a Crew Truck and a generator.  Those will be fun to build.
Jim Williams
    February 2010
Posted by Bockscar on Friday, August 9, 2013 6:36 PM
Hey Jim,
this isn't a contest, it's always great to see another BUFF born!
The smaller scales are pretty hard to build, but on the other hand,
they do get built!
My BUFF is still half done hanging from the ceiling, I have to
admit I've pretty much taken the summer off, so much to do
outside while the weather is nice.
Dom
    April 2012
Posted by Striker8241 on Friday, August 9, 2013 8:47 PM
Hey, that's cool, Jim! Did you scratchbuild the van or is it a kit? What scale?
Rock on!
Russ
    March 2009
Posted by Buffirn on Friday, August 9, 2013 8:59 PM
Striker8241
Rock on!
Russ
This is the 1/700 Skywave kit.  It has B-1s  and some AGE along with the van.  The "tarmac" is construction paper and card stock.  The lines are colored pencil.  I've had fun so far.  I still need a Crewdog truck and a generator.  I'll have to scribble some plans down tonight.  Scratchbuilding at that scale might be easier than one would think.  Detail is not much of a factor.
If I could get about 10 more of those vans, I'd make a B-1 diorama of them getting readyt for a mission.  One plane, 10 stepvans, Mtc Super Pickup, crew bus, a big puddle.  Just my somewhat rude dig at the BONE.
Jim Williams
