WT??? Tony, it would take me two weeks to do what you did in two days!! LOL! The GB is off to a good start!
So here's what I'm working on: Italeri 1/35 Jagdpanzer IV. Its an older kit that lacks the detail of the newer releases, but perhaps a bit more detail than the older Tamiya kit. I started building this for the orginal Hunter's GB about five years ago, but never finished. The lower hull is done, but has problems. I also worked on the upper hull, removing some molded details and installing the intake housings. The photos below just show how it looked before this GB started. I estimate its about 40% assembled, but I'm going to rework some of it as mentioned below.
A couple of bogie housings on both sides of the lower hull have sink marks that I never noticed so I'll have to fill those in.
The worst area is the rear engine plate. Its littered with pin marks. When I first assembled it I didn't care, but now I feel it needs to be replaced. I'll look in the spares box to see if I have an extra set that will work, or I may order a resin replacement from TMD (Tiger Model Designs). If neither is an option I may just scratchbuild a entire new rear plate!
BTW Clemens, I noticed that we might still need a Soviet badge. I took the liberty of putting one together. Let me know if you're interested in using it. I used Cyrillic for "HUNTERS", but I'm not really sure if that's accurate!
Ernest
Last Armor Build - 1/35 Dragon M-26A1, 1/35 Emhar Mk.IV Female
Last Aircraft Builds - Hobby Boss 1/72 F4F Wildcat & FW-190A8
