1944 Group Build
    September 2003
Posted by checkmateking02 on Saturday, November 8, 2014 6:26 PM
What trouble are you having with the masking, Doug?  Is it trying to determine what parts should be what color--or the masking itself?  Both can be a headache! Sad
Since the camouflage specifics aren't always clear on photos of the real ship, I googled some BB-55's built by other modelers (mostly in 1/350), and that helped; although no two modelers seem to interpret the camouflage the same way in places. Surprise
As for masking, I found I had to use a combination of masking tape, sometimes sliced into pretty thin strips--as well as filling in the blanks with poster tack.  It looks like a mess, but it's usually been working.
Here are a couple of photos of a particularly complicated piece--it belongs on the top of the aft island.
The wall and the pedestal on the left of the part will be painted 5-0 Ocean Gray;
Then this side will get painted black after the other side sets up.
After that, all the vertical parts will have to be masked, so the deck can be painted.
Keep plugging away, Nomad, and it will start to fall into place! Yes
I've got some more parts to finish up painting, and will post more photos later, but I think I'm beginning to visualize getting this thing completed.
    September 2003
Posted by checkmateking02 on Saturday, November 8, 2014 6:58 PM
A few more photos I took tonight.
The 20mm's; I airbrushed the bases, which are supposed to be the same color as the surrounding camouflage, then I hand-painted the guns themselves with black acrylic.
Next up are some of the black-painted pieces, with parts for some of the 40mm's.
Then some of the painted-up superstructure parts.
Last up, a look at the forward superstructure.  I was test-fitting the parts, so the layers aren't permanently glued down yet.  Should have put that penny on the right closer in, for scaling.
    February 2010
Posted by EBergerud on Tuesday, November 11, 2014 4:55 AM
Looks like we've got some more good things inbound.
As for me, I've finished Hobson. I tempted to lose my common sense and make a water-base for the model, something I've never tried. If it works, I'll do a full build log and put it in the ship section.
It's been a while since I've posted concerning this model so let me bring you up to date. I'm building the 1/350 Cyber-Hobby (Dragon) USS Buchanan 1945 Tokyo Bay. I wanted to do an Atlantic Fleet DD and USS Hobson had a configuration very close to that of the model. And I also had good photos. The only real modification I had to make was to alter the number a little to turn "484" into "464." Here's the the original kit, Hobson, and a couple of pics showing where we ended up.
At the last post I had finished the ship minus tidying up, railing, rigging and weathering. Tidying up proved to be a little more than I had in mind. I scratch built the main mast from brass and found out it wasn't anchored quite well enough for rigging. So, off goes the rigging and the mast is installed with cast iron and concrete. And back goes the rigging.
As earlier noted this edition of Buchanan came with a bonus PE set which was good news and bad. The bad news is that it isn't as delicate as WEM or Tom's and the railings ended up a little clunky. The problem that I haven't solved is to get a decent paint job over PE (which does take some paint) and yet keep the paint off the PE because it inevitably coarsens the effect. Next time I'll use some very good burnishing compound and paint the PE with more coats of thinner paint. The SC radar comes from WEM. The frame, which looked tricky, assembled very well. However, the piece had twelve dipoles each requiring CA and paint. The parts in question have a very delicate look in photos. I did see an Empire version of the same radar and it dispensed with the dipoles altogether - that would have been a much better idea. The problem with WEM PE, however, is that once a card is laid, it's pretty much played. If I had tried to remove all the small parts, I'm sure the frames would have been wrecked. So it too looks clunky. It is, however, much better than the strangely bad plastic radar provided by DML. Some of the detail on this kit is amazing, but the radar provided reminded of something out of Eastern Europe in the 1980s.
Unless you were going to put up a load of signal flags, the ship required a pretty spare rigging arrangement. Finding the right line for this job has vexed me since I first rigged a ship. I'm very pleased with what I tried this time. It's 12/0 Veevus fly tying line. The line is polyester so it doesn't have the incredible fineness of 20 Denier Uni Caenis. Caenis is made of nylon which is inherently thinner than the polyester thread of the Veevus. It is also, for me, a nightmare to work with. And the stuff is so thin that five feet away it's hard to see the rigging. The Veevus (a fine Danish company: be surprised how many fly fishermen are in Europe) sports a .047mm diameter and that's fine. But polyester is much easier to hold on tweezers and it's easier to see. The one disadvantage it has is that using burning incense to tighten the line (which works with nylon, sprue or waxed tying line) doesn't work. Of course at that diameter, it doesn't take much incense to fry your rigging. Instead I found that with a solid base (there are 15 lines coming out of the mast alone) it was very easy to simply tie taught knots. I think it worked out very well. I've bought some 16/0 Veevus for my next ship project (1/700 Derfflinger - a WWI German Battlecruiser from Flyhawk) which will be thinner yet. Stretched sprue has fans but I can't get the stuff to hold on brass with plastic cement. ( My next project will be a Morane Saulnier a WWI monoplane which requires rigging also - but most people use 2 lb fishing line - that'll feel like using a chain compared to my ship lines.)
The weathering worked out about the way I wanted - so blame my eye if you don't think it worked. What I was looking for was a well used ship which I think would show fading, wear and general untidiness as opposed to chipping rust etc. (I decided not to use rust at all - I might put on just a bit if I get a proper base.) The illustrator for Dave McComb's nice Osprey book on prewar class US DDs must have been thinking along the same lines. Here's a linedrawing for Landsdowne which best shows the effect.
As noted earlier the weathering process began at the outset when I used a variety of shades of acrylics and employed Mike Rinaldi's "reverse dry brushing" technique to create dark blotches. As I always do when weathering, I'm very interested in breaking the visual plane. Although I'm at best a grade B- ship builder, I think builders in this genre are usually too light on weathering. Maybe their kits, which take a long time to make, are too pretty to mess with. I want to make the eye work for its living and avoid a "clean" look to a warship coming back from extended operations. Others may think differently.
I used my Iwata Com.Art for panel washes - I absolutely love the stuff. It's a snap to remove and the grainy texture it leaves is really good for indistinct wear. I also put on some filters with oils and applied some streaking with AK Interactive enamel "streaking grime" for gray ships. I tip my hat to whatever admiral decided to use Measure 22 on Atlantic warships. It is much my favorite scheme, having more visual interest than 22 and more graceful than the ultra-camo favored by the RN and some USN PTO warships. Also saved a lot of time.
Would like to plug the history on this kit. Understandably people equate the Pacific War with the USN in WWII. The DDs in the Atlantic, however, earned their supper in a very different way. They never faced the nightmare suffered by the USN off Guadalcanal and later off Okinawa. That said, the stakes in the ETO were immensely high and the USN played a crucial role there. Obviously there were the U-boats, not a role our DDs really excelled (DEs were far better) unless put into the lethal "hunter killer groups" in cooperation with CVEs and a small fleet. Hobson was attached to one voyage with "U-boat killer in chief" USS Bogue in early 44 and helped sink a sub forced to the surface with gunfire. Earlier Hobson and CV4 Ranger had joined a little known but daring RN (including BBs Anson, and Duke of York) for a raid on German merchant shipping in central Norway. All things considered, the raid was very well done and the Ranger's SBDs, Wildcats and Avengers did some serious damage at the cost of three Wildcats lost to flak. As I understand it, heads were rolling in KM HQ after that operation.
But where Hobson and other US DDs saw history was in artillery support of the great landings in the Med and at Normandy. Despite the awesome power of the USN in the Pacific by 1944 it faced a very frustrating task of trying to blow out Japanese island defenses with simple firepower. It was always better than nothing, but there was a limit to what could be done as long the Japanese kept their heads down. Landing support in the Med and at Normandy was a very different kettle of fish and arguably played a more important role in history's greatest war. Allied warships naturally blew the devil out of the areas around the various beachheads. However, unlike the Japanese that fought with fanatical courage and little else, the Wehrmacht was a very sharp and nimble sword led by good officers that understood firepower, mobility and the counterattack. At Salerno and Anzio it is very likely that the allied landings would have failed had the RN and the USN not had their superb gunfire at the ready. Let's not forget that even a small naval gun, say a 5"-38, would have been a big gun on the ground. In any case furious German counter attacks in Italy were thwarted by naval gunfire far more than by airpower. And it was dangerous duty. The Luftwaffe was losing their war, but in mid43-mid44 still had some excellent units including some trained for anti-shipping attack. It says much about the two theaters that Japanese air power after the November 43 Rabaul raids provided completely ineffective against USN shipping - until the Kamikazes arrived. The Luftwaffe, however, was a very dangerous foe for ships and planes alike.
Naval preparation at Normandy was - in the consideration of some good historians - mostly botched in the initial stages, as were the first air attacks. But German resistance existed on every Normandy beachhead and as the day went on allied warships were doing serious damage: the one German armored counterattack on D-Day was stopped by naval gunfire. And until breakout there were countless targets for allied capital ships. Even the 5" guns had value for the first couple of weeks.
And then there was Omaha. During the afternoon of June 6 Bradley commented "thank God for the US Navy." Because of an inherently difficult objective and errors too numerous to quickly count, US assault forces did, briefly, stare at doom at Omaha. It was at this time that US DDs came up to the shoreline and began an all-out assault over open sights (including 20mm and 40mm flak) against German positions of all kinds behind the beach wall. So many defensive points were obliterated that when the US forces pierced the German lines, by day's end it was the powerful Wehrmacht 352d Division that faced envelopment and destruction.
Hobson was at Utah. They bombarded German positions and, unfortunately, spent much time rescuing the survivors of the USS Cory that had been sunk. Further bombardment followed on June 8. A couple of weeks later Hobson supported the USN in that not always glorious but ultimately effective bombardment of Cherbourg and helping win a battle crucial for the allied offensive in France.
Rest of the war was quiet for Hobson and it missed calamity when sent to the Pacific. But just to prove that sailors are always in harm's way, Hobson collided with the USS Wasp in 1952 and lost half of its crew. A sad ending to a fine career.
Anyway, my kit is a wrap. Pics Below:
Eric
A model boat is much cheaper than a real one and won't sink with you in it.
Posted by Bish on Tuesday, November 11, 2014 7:21 AM
Great work there Eric. I really like the look of that. Thanks for brining it to the GB.
Posted by Bish on Tuesday, November 11, 2014 7:23 AM
Thanks Doug. I would have no idea where to start on one of those ship builds, but one of these days I must get round to building one.
Nice progress there check.
    September 2003
Posted by checkmateking02 on Tuesday, November 11, 2014 2:47 PM
Great looking ship, Eric.  You packed a lot of detail into it.  The paint and weathering are outstanding.  Nice work!
    September 2003
Posted by checkmateking02 on Tuesday, November 11, 2014 2:52 PM
Looking back over the postings and I saw I didn't post the forward superstructure assembly I mentioned, so here it is:
I plan to get some more work done tonight on the secondary batteries and other smaller parts.  After today, the rest of the week, I have to work late, and probably won't accomplish anything till the weekend.
Posted by Bish on Tuesday, November 11, 2014 3:47 PM
Shame on you check for missing that bit out. I am really impressed with the way your able to mask and paint that.
I have started fitting the interior items to the 251 and wiring the radio. I am taking pics as I go and will do another update at the weekend.
    August 2013
Posted by Jsmyth on Tuesday, November 11, 2014 4:47 PM
Eric
That ship came out awesome! I can't wait to start my Indy for another GB
Bish
Your 251 is looking good. I need to get cracking on my Panther
CMK
You have done some great work on that build thus far. I can't wait to see the finished product
    January 2014
Posted by Rob S. on Tuesday, November 11, 2014 7:31 PM
CMK..I love the 'modular' build you have going. I'm going to employ that technique on my next ship.
______________________________________________________________________________
On the Bench: Nothing on the go ATM
    August 2009
Posted by JOE RIX on Tuesday, November 11, 2014 8:27 PM
Ho Boy! There is definitely some sweet action going on here from you all.
Bish: That is some masterful PE work. Very clean and sharp. Your radio is definitely impressive.
CMK: Your masking efforts continue to amaze me. It just looks great and it will be awesome when you get all the sub assemblies put on. Fantastic work.
Eric: WOW! Your DD Hobson is really astounding. You have some really excellent skills when it comes to ship modeling. I am very impressed. I especially like your weathering. It is really nicely done and quite convincing. I also want to thank you for the detailed history. I personally enjoy reading it. I thank you very much for sharing your exceptional skills and talents with us. Like Bish, I too am itching to get around to trying my hands at a ship model and you and Checkmate are certainly getting me there rather quickly.
Thanks everyone for all the posts and updates. I hope to have some progress pics up soon myself.
"Not only do I not know what's going on, I wouldn't know what to do about it if I did". George Carlin
    September 2003
Posted by checkmateking02 on Tuesday, November 11, 2014 9:39 PM
Thanks, Bish.  Yeah, the little grey cells weren't working that night.  Either that, or my wife kicked me off the computer.  It belongs to her.
Thanks, too, Jsmyth.  I'm getting antsy to finish it up too.  Doing some figuring, it's been taking about four months to finish a ship--and I'm not planning any PE for this one.
Thanks, Rob.  Once the sub-assemblies are done, it's a lot like stacking pancakes to put it all together.
Thank you, too, Joe.  All the little protrusions  and parts have kind of forced "inventive masking" on me.  It's a lot of trial and error--with the emphasis on the error; then, do it again.
    September 2003
Posted by checkmateking02 on Tuesday, November 11, 2014 10:09 PM
Did a little more masking and painting tonight--the secondary battery of 5 inch guns.  Three of the turrets were painted with two colours--a narrow band around the bottom.  I used masking tape to mark this, then just stuck some poster tack on top.
Any similarity to the inhabitants of Talos IV, living or dead, is purely coincidental.
    August 2009
Posted by JOE RIX on Tuesday, November 11, 2014 10:31 PM
LOL! LOL! Oh Man, that's funny.
    January 2014
Posted by Rob S. on Wednesday, November 12, 2014 4:52 AM
Stick out tongue
    April 2014
Posted by lostagain on Wednesday, November 12, 2014 6:15 AM
Is that what happens to your head after making one too many ship models ?
CMK, that masking is amazing, I 'm sure it would do my head in. Can't wait to see the pancake stack complete.  mmm pancakes...
Eric, the Dobson has come up really well, looks like it has had a hard life out there.
Bish, the 251 is looking good, and congrats on getting Darth into FSM
    September 2003
Posted by checkmateking02 on Wednesday, November 12, 2014 10:02 AM
Thanks, guys.
And, no Talosians have been harmed (so far) in the production of this battleship.
    August 2009
Posted by JOE RIX on Wednesday, November 12, 2014 11:18 AM
Umm..Checkmate, Have you been painting with enamel paints in an unventilated room lately?Wink
    September 2003
Posted by checkmateking02 on Wednesday, November 12, 2014 1:04 PM
Nah, just the zenite gas.
Posted by Bish on Wednesday, November 12, 2014 1:11 PM
Joe, thanks. I do like my PE, I would be lost without it.
Lost, thanks, on both accounts.
Check, be careful your starting to show your dark side Wink
    September 2003
Posted by checkmateking02 on Wednesday, November 12, 2014 1:50 PM
It's always been there!
    September 2003
Posted by checkmateking02 on Wednesday, November 12, 2014 2:00 PM
But, I digress. . .
Here's a little progress I made last night.
three of the fifteen 40mm's:
Added some of the tiny little detail parts to the foredeck, before they get (inevitably) lost:
To the left of the one-cent piece, is one of the 20mm's installed.  I had to do this, since, when I glued down the deck, some of the CA oozed up through the locating holes.  Now, I have something new to fix (again):
Last, something I found interesting--the unusual paint scheme on the aft 16-inch turret.  The top of the thing should be Deck Blue (20-B, in US Navy designation); it's obviously not, according to the photo; looks to be Light Gray (5-L), with the black stripe from the side extending over the roof slightly.  Anyway, that's my interpretation.  The photo of the model also shows the 40mm installed in the gun tub.  It doesn't show well, since the camera flash bleached it out, but I applied some dry-brush highlights to the 40mm and then ran a dark blue pin wash over it.
That's all for the next couple of days.  Unless there's a distortion in the temporal matrix, I've got work late tonight and tomorrow.
Posted by Bish on Wednesday, November 12, 2014 2:44 PM
checkmateking02
I don't know what you mean. Wink
Posted by Bish on Wednesday, November 12, 2014 2:45 PM
Looking nice check, and good find with the photo. Certainly doesn't look blue to me.
    August 2009
Posted by JOE RIX on Wednesday, November 12, 2014 3:19 PM
Me neither.
(That's just for you Bish)
Posted by Bish on Wednesday, November 12, 2014 3:47 PM
JOE RIX
Me neither.
AWWWWWWWWWWWWWWW, thank you.
    September 2003
Posted by checkmateking02 on Wednesday, November 12, 2014 4:35 PM
Bish
Then, it's time to learn, young apprentice:
http://www.youtube.com/watch?v=hEcjgJSqSRU
    April 2013
Posted by SchattenSpartan on Thursday, November 13, 2014 5:04 PM
checkmateking02
Bish
Now this is just great! Big Smile
    January 2014
Posted by Rob S. on Thursday, November 13, 2014 8:29 PM
checkmateking02
Bish
Ha!! Never saw that before! Sent that vid to my SW buddies!! Thanks for that!!
    September 2003
Posted by checkmateking02 on Thursday, November 13, 2014 9:20 PM
Live long and prosper!
