Hi all,
Yes, PE is madness, I have just built the lower hull and idlers from original kit which is all I will use from the plastic kit. Yes, I have already looked into some PE, and there is no possibility of using them all, why?, some of the parts are way to small. Im using a 10x lens and the pliers look like too big Shrek sausage fingers trying to bend and insert a handle in a hole smaller than human hair diameter. This would require surgical instruments to do.
On the other side, this tank has been strip off from a lot of parts, either lost on war, used as spares, stolen, etc..eg, all the front tracks at the lower hull are not there, also the spare idlers on the top of the hull, etc.
Im a little behind my personal work schedule, since Im mouting some wall shelves to make more room for paints, pigments, washes, etc. But, phew....in Mexico we build homes with concrete, so after 3 holes in the wall (I was hitting a steel beam) I installed one and one more to go. Then I need to clean my desk (again) and continue.
I like all your progress even from start, it really shows how each one deals with problems with the kits, the building process, etc.
