Well here is the latest work on my Gemini Spacecraft project
Now where was I? I hit a speed bump due to trying some new weathering techniques and had to go back and fix those up. And I have been doing bits and pieces of detail painting over the past week. Today it was time to get it all assembled.
I used oil paints to apply a pin wash on the Equipment and Retrograde Sections. . It worked good enough on the Retrograde section, but did not react well with the Floquil paint on the sidewalls of the Equipment section, my first time using that medium. Next time I know to use a dissimilar layer in between. So I touched up the paint there and then used Promodeler Wash to take care of that section.
Equipment Section
Retrograde Section
After getting that work fine tuned I added the equipment that goes in those sections
Equipment Section
Retrograde Section
I also applied the Promodeler Wash to the Astronaut figures
Then I applied their uniform decals- I still need to do a little more work on their faces and then add their helmet faceshields
And I have been working on the red edging and mettalic red detail work for the capsule itself, all based off of photos of Gemini 3. Today I finally glued the capsule exterior to the heat shield so now all that needs to be added are the hatch windows. Which I will do after the decals are on and the final Flat coat on the exterior.
then a test fit of the Adapter Section to the Crew Section
and a test fitting of the Astronauts
Keep looking, more to come soon...
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
- Plankton
LSM
