Its that time of the week again. And my first time adding pics in the new format, so lets hope this works ok. After the oils had dried, i added some shadow with Flory black wash. I then added all the pre coloured PE, seatbelts and painted in anything that wasn't RLM 66. I must say i am really pleased with the end look, slighly worn but not to much so.
I found the HGW belts to be awkward to put together but they look really nice. My only dissapointment was that they are only coloured on one side. I understand newer sets are coloured on both sides, but with these ones i still have to be careful how i position them.
I also found my first problem with the kit. This is how the cowling MG's are supposed to fit.
And this is how they look from the outside.
Just not right at all. So i have sanded down the raised bits which hold them in place, but going topaint them before fitting.
With the pit done, i got it fitted and the fuselage together.
The wings are just about done. But i am going to paint the wheel wells and radiator flaps before attaching. I'll also leave off the leading edge flaps to paint those areas.
So next up, i will get to the bit i like lest, sanding. But the seams look quite nice so that should not be to much work.
As i said to Mustang yesterday, i am really enjoying this. Its nice to be able to see the detail clearly.
