Star Trek 50th Anniversary Group Build
    September 2011
Posted by falconmod on Friday, February 24, 2017 10:04 AM
Ok only a little update.  Got the engine supports glued in and the wires routed.  Now I have to make room for the center post and solder wires together and run them down the post.  Yaa! Hoo!
On the Bench: 1/72 Ki-67, 1/48 T-38
1/144 AC-130, 1/72 AV-8A Harrier
Posted by Gamera on Friday, February 24, 2017 12:39 PM
Ohhhhhhhhh, I've been trying to cram three LEDs into a Bandai A-Wing and you're working with something waaaaaaaaayyyyyyyyyyyyy smaller so I guess I should stop cussing and complaining now!
Looks awesome, I think even Scotty would approve.
    September 2011
Posted by falconmod on Friday, February 24, 2017 12:50 PM
Oooooo!  I also have to use a Optivisor with a 10x lense on it.Sad  Capn' I've got to have more room!!!
    September 2003
Posted by checkmateking02 on Friday, February 24, 2017 1:42 PM
Intriguing and fascinating!
    September 2011
Posted by falconmod on Tuesday, February 28, 2017 7:26 AM
She's assembled and lit up!
John
Posted by Gamera on Tuesday, February 28, 2017 7:51 AM
Ohhhhhhhhhhh, cool!!!!!!!!!!!!!
    June 2010
Posted by Beans on Tuesday, February 28, 2017 9:55 AM
falconmod
John
Outstanding!
    March 2010
Posted by mach71 on Tuesday, February 28, 2017 3:46 PM
Very well done!
Very well done indeed!
    September 2003
Posted by checkmateking02 on Tuesday, February 28, 2017 5:00 PM
Excellent!
    March 2010
Posted by mach71 on Wednesday, March 1, 2017 12:28 PM
I've been very busy last week, Not much got done.
I managed to get an hour today to do a little bit.
Last week I painted the tail cone of the F-104.
I got a few things in the mail.
And I started decaling the Enterprise.
    September 2003
Posted by checkmateking02 on Wednesday, March 1, 2017 10:56 PM
Everything is turning out really well!  Good job!
Posted by Gamera on Thursday, March 2, 2017 7:32 AM
The Big-E looks great! And dematerizing Capt. Christopher looks cool in the cockpit of the F-104.
    March 2010
Posted by mach71 on Monday, March 13, 2017 2:50 PM
Not much new. I've been trying to get gome lights to light Capt. Christopher.
I ordered some on ebay. when they came they didn't work. The seller sent replacments
but they were 14V bulbs. I finally found some 3V bulbs and they came a few days ago.
I mounted the light in the seat.
I've been cleaning up a few things on the F-104. Final assembly on the F-104 is almost done. I've drilled a mounting hole on the side for a plastic rod.
I've been cleaning up Capt Christopher a bit also.
    September 2003
Posted by checkmateking02 on Monday, March 13, 2017 9:53 PM
Really creative, mach!
    March 2010
Posted by mach71 on Wednesday, March 15, 2017 1:00 PM
Slow progress.
I've almost finished decaling the Enterprise and Final construction on the
F-104 is basically done.
I started decaling the F-104. I think I'll go with FG-926 and TAC shield/lightning bolts
on the tail.
    September 2003
Posted by checkmateking02 on Wednesday, March 15, 2017 2:15 PM
Both are looking really good!
Posted by Gamera on Thursday, March 16, 2017 11:17 AM
Yeah, that's some sharp work on both!
    September 2011
Posted by falconmod on Friday, March 17, 2017 10:08 AM
Some small updates,   the enterprise is on a wired post and I'm getting ready to put LED's in the doomsday machines to get that swirlling effect
John
    September 2003
Posted by checkmateking02 on Friday, March 17, 2017 4:25 PM
Looking sinister! Nice work.
Posted by Gamera on Saturday, March 18, 2017 12:48 PM
Awesome Falcon, looks ready to blow up and eat your workbench!!
    March 2010
Posted by mach71 on Tuesday, March 21, 2017 1:40 PM
Looking very good Falconmod!
I'm still blown away that you've managed to get lights into
that tiny 1701.
    March 2010
Posted by mach71 on Friday, March 24, 2017 7:56 AM
I need some help guys.
I want to subtlety warp the F-104 to look like the tractor beam is bending
the aircraft.
The model is all decaled and today I will seal it in Tamiya semi gloss clear.
I was thinking about using a heat gun, but I don't want to burn the decals.
I was also thinking of setting the oven at 220F and setting the aircraft on 3 bricks
and letting it "sag". But again I don't want to scorch anything.
Any other Ideas?
Thanks
Posted by Gamera on Friday, March 24, 2017 9:16 AM
Mach71: No idea how to do it without ruining the paint etc. I have seen a few warped from sitting in a hot car for too long. No idea how to replicate this safely without taking a chance of ruining your model.
Only advice I'll give you is a to grab a few cheap poor quality kits and use them as guinea pigs before you take a chance on your finished F-104.
    March 2010
Posted by mach71 on Friday, March 24, 2017 1:07 PM
I have other, better, F-104 kits in my stash. I'll experiment with this one.
I'll either go with boiling water or a warm (200F) oven. Unfortunately I changed my plan after I sealed the fuselage and primed it.
I've sealed it with a few coats of Tamiya clear coat. I hope thats enough to keep the decals safe.
Posted by Gamera on Friday, March 24, 2017 2:40 PM
You might try starting the oven maybe around 120F or so and carefully bump it up until you see some reaction. Not sure I'd shove her in there 200F right away.
Just my two bits though!
    March 2010
Posted by mach71 on Friday, March 24, 2017 3:10 PM
Good idea! 200 might be a bit much to start.
Here is where I am now. All model construction, decaling, and sealing is done.
I have a small canvas that I painted sky blue/white.
I have to mount a strip of wood to the back of the canvas to hold the F-104
in place.
    September 2003
Posted by checkmateking02 on Saturday, March 25, 2017 9:52 AM
Very good, mach!  I'm sure I wouldn't have enough nerve to put anything looking that nice into the oven.  Good luck with it!
    March 2010
Posted by mach71 on Sunday, March 26, 2017 8:21 PM
I baked my F-104 in the oven today!
180F for about 12 min. I then twisted the wings and tail a bit and let it cool.
I put everything together tonight.
I'm thinking it done!
Unless I can figure out anything else to dress it up.
The background is a small canvas painted sky blue and flat white.
I had to epoxy wood strips to the back to attach the mounts for the 2 models.
looking back, I would have done many things different but It looks nice as it is.
    June 2010
Posted by Beans on Monday, March 27, 2017 9:44 AM
Very creative mach71.
Do you have a picture preference for the Wall of Fame?
    March 2010
Posted by mach71 on Monday, March 27, 2017 11:15 AM
Thanks.
Probably the 1st.
