RAF 100th Anniversay GB
    July 2014
Posted by modelcrazy on Thursday, June 1, 2017 3:35 PM
Nice save Check
Steve
    September 2003
Posted by checkmateking02 on Thursday, June 1, 2017 4:13 PM
Thanks, Steve!  It was a little labor intensive.
Posted by Bish on Thursday, June 1, 2017 4:21 PM
Great recovery check.
    September 2003
Posted by checkmateking02 on Thursday, June 1, 2017 4:22 PM
Thanks, Bish.
    March 2015
Posted by Toshi on Thursday, June 1, 2017 6:36 PM
checkmateking02
Greg:  isn't PE fun?  Well done!
Steve:  progress is coming along nicely; looking good
damouav:  remarkble cockpit!  Nice work!
Toshi:  slick looking paint work on the props
More on the Hampden landing gear.  These have to be assembled and dropped into the lower wing before closing up with the upper wing.
Unfortunately, with the wheels installed, a gap is created in that bar that surrounds the rear of the tires.
You can see even without the wheel that there's a slight refusal of the parts to match.
So I masked that part with blue tack.
Inserted some styrene rod, and sanded things down.
But you'll notice I got some unwanted black marring on the nice gray tire when I stuffed them into the landing gear.  So I re-masked with tacky stuff and touched up.
Finally got them done, and painted the repaired area by hand with black acrylic paint.
Thank you sir.  It was all brush work.
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    May 2013
Posted by Greg on Thursday, June 1, 2017 7:12 PM
Nice fix, CMK.
I'm always interested to see how folk correct various issues, it's fun to read about. Even more so when there is a nice, layout-style step-by-step like yours here to follow. Yes
Were those the OOB kit tires?
    January 2017
Posted by damouav on Thursday, June 1, 2017 7:33 PM
tempestjohnny
Damian I'm going to be watching your Mossie build. I have the,same kit half built for the last two years. Maybe watching you will motivate me to finish it
You humble me.
The Tamiya 1/48 Mossie is a really great build, I haven't had any significant issues to date to sort out. When you get back to it you will enjoy the build.
In Progress
1/48 Tamiya P47-D Bubbletop
1/48 Hobby Boss TBF-1C Avenger (on hold)
Pending
1/48 Roden S.E.5a
1/48 Airfix Walrus
    January 2017
Posted by damouav on Thursday, June 1, 2017 7:51 PM
Hey Gamera,
The fact that the Mossie was built mainly from laminated ply, glued and screwed together shows how innovative  De Haviland really was. As metal availability was limited the use of wood, and the manner in which the airframe was constructed is just amazing for the period.
I know there where many great aircraft during WW2, but the Mossie is in the top 5 IMPO.
I really want to build the 1/32 Tamiya to pay homage to this remarkable aircraft.
When you get a chance, add one to your collection.
And, Thank You.
In Progress
Pending
1/48 Roden S.E.5a
1/48 Airfix Walrus
    January 2017
Posted by damouav on Thursday, June 1, 2017 7:56 PM
Thanks checkmateking02.
Very nice work on the main gear, excellent save.
Thanks Toshi.
Excellent work on the prop, there are almost as many parts to that prop than im my entire build...
In Progress
Pending
1/48 Roden S.E.5a
1/48 Airfix Walrus
    November 2008
Posted by Justinryan215 on Thursday, June 1, 2017 8:47 PM
My grandmother,  during the war, ferried pilots to the planes and moved aircraft around on the tarmacs.  The used to tell me of the Mossies coming in to land for the first time, and how wonderful they were!  Those were her favorite ones!
"...failure to do anything because someone else can do better makes us rather dull and lazy..."
Mortal as I am,I know that I am born for a day.  But when I follow at my pleasure the serried multitude of the stars in their circular course, my feet no longer touch the Earth...
Posted by Gamera on Thursday, June 1, 2017 9:35 PM
CMK02: Nice recovery there! I wouldn't have even noticed if you hadn't pointed it out.
Damouav: Yeah, the Mosquito was truly an amazing aircraft. And a very sleek attractive machine. I don't have any excuse for not having one, for some reason I have about a half dozen Spits in the stash and not one Mossie. Embarrassed
    January 2017
Posted by damouav on Friday, June 2, 2017 1:54 AM
I have some updates on sundry build elements like main gear, undercarriage doors, props etc.
Undercoated all parts with black primer, AB Tamiya AS12 (Bare Metal Silver) were applicable. Used Ultracast tyres all round which provide far better detail than OOB. Used a heavily diluted black oil paint for weathering. I was going to use PE mud guards, but they didnt fit properly, so I used the kit versions and drilled holes in the upper gusset to match photos I have on hand. Both landing gear will get some minor weathering before I coat them MRP Matt varnish.
I removed the molded hinges and bent these really small PE ones, I have some touch up painting to do which can wait till I install them at the end of the build. I attempted to remove the injector pin holes, poorly. But when the Mossie is on it legs you will never see the inner doors, so no real problem.
The props painted and ready to mount, i couldnt sight any livery to place on the props unlikely US props of the same era. Minor wear to be added to the leading edge, then done.
In Progress
Pending
1/48 Roden S.E.5a
1/48 Airfix Walrus
    March 2015
Posted by Toshi on Friday, June 2, 2017 3:21 AM
checkmateking02
Very nice fix, just excellent!
Posted by Bish on Friday, June 2, 2017 4:06 AM
Coming along nicely there Damian. I usually go for resin wheels, especially when the kit ones are 2 piece, but never tried Ultracaste. They look nice.
    January 2017
Posted by damouav on Friday, June 2, 2017 4:58 AM
Yes, Ultracast do very nice resin work from my limited experience and certainly worth a look if your after AM items.
In Progress
Pending
1/48 Roden S.E.5a
1/48 Airfix Walrus
Posted by Bish on Friday, June 2, 2017 5:40 AM
Don't seem to see them much here. I tend to mainly use Aires and True Details for wheels. Will have to have a better look for them.
Posted by Gamera on Friday, June 2, 2017 7:45 AM
Gee, I have to pick up a Mosquito before much longer- Toshi and Damouav you're tempting me so much!!!
Again really nice work on the two Mossies.
    November 2003
Posted by tempestjohnny on Friday, June 2, 2017 7:50 AM
Had an accident with the Tornado. Mistakenly stepped on three or four timesBang Head
So I'm changing my build to the Italeri Jaguar T.2. Which I've heard is a beautiful kit
    January 2017
Posted by damouav on Friday, June 2, 2017 8:14 AM
Rolling around laughing so hard the dog thinks I'm having a fit.
Accidental you say, three or four times you say...
It would have been so much more cathartic to hit it with a big hammer.
In Progress
Pending
1/48 Roden S.E.5a
1/48 Airfix Walrus
    July 2014
Posted by modelcrazy on Friday, June 2, 2017 8:28 AM
tempestjohnny
Ooops. I've had a few that accidently fell into the trash.
Steve
    June 2014
Posted by BrandonK on Friday, June 2, 2017 9:22 AM
I've used Ultracast many times and if I had to compare them to Aires or True Details, I would say they are superior, IMPO. They tend to offer a great many items you simply can't get anywhere else. They are all nice though.
Damian, wow, super nice work there.
TJ, well, accidents happen. If you had said 5 times I would be suspicious of your true motive.
Greg, sorry to have missed yours. That is some great detail on the framework. Super nice.
CM, nice fix on the landing gear. I'm not sure that would have come to my mind. Well done.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    September 2003
Posted by checkmateking02 on Friday, June 2, 2017 9:43 AM
Thanks for the generous comments on the Hampden's landing gear fix.
Greg:  yes, the tires and wheels are the kit components.  A little sparse, detail wise.
tj:  a tragedy with the Tornado; hope it receives a decent burial.
    May 2013
Posted by Greg on Friday, June 2, 2017 9:59 AM
Justinryan215
Now there's a good story. Yes
Johnny, I'd mentioned you would prevail through your kit difficulties. You did, proving there is more than one way to skin a cat.
Damian, those landing gear assy's look great. But so do the props and I see you have your own fiddly PE parts to deal with (PE hinges).
    November 2003
Posted by tempestjohnny on Friday, June 2, 2017 11:24 AM
I couldn't understand why this kit was so bad until I went on Scalemates and saw it was a 1977 mold. Horrible. But I only paid $10 so it was worth it for the markings which I will use on a better kit
Posted by Gamera on Friday, June 2, 2017 11:25 AM
Ouch TJ! I know how you feel though. I probably would have turned the thing into a British Kamikaze by launching her at the wall on the other side of the room...
Note to self, when I buy a Tornado don't chose the Italeri kit.
Posted by Bish on Friday, June 2, 2017 12:08 PM
tempestjohnny
Crash and burn. From the 1970's, i reckon they must have built it before seeing the real thing.
You weren't doing John Nichol aircraft were you. Be very fitting if you were.
O well, a jag it is. I am happy with that. And nice to see a twin seater. Are you doing the 54 Sqn aircraft on the box.
    November 2003
Posted by tempestjohnny on Friday, June 2, 2017 12:15 PM
Bish
tempestjohnny
yes i believe i am. Like the look of the all gray scheme
    October 2016
Posted by DasBeav on Friday, June 2, 2017 2:10 PM
tempestjohnny
Sir, that just made my weekend!! (and I'm taking a week off for some fun and sun) I built the Testors Tornado...I'm guessing it's the Italeri rebox. Didn't get "accidently" stepped on, but is in "The Tote of Mediocrity"
 Sooner Born...Buckeye Bred.
    October 2016
Posted by DasBeav on Friday, June 2, 2017 2:17 PM
http://imgur.com/0LeDgctAlmost ready for primer. Got some sanding and touch-up to do. Have used a lot of tape and time to get this "turd" of a model to look right. Having fit issues would be an understatement. I think the technical term is "cattywompis"....Now for a little vacation!Cool
Posted by Bish on Friday, June 2, 2017 2:19 PM
tempestjohnny
Bish
tempestjohnny
I am looking forward to that. I have not seen one in all grey before, i have markings for 3 Coltishall based Jags from 1991 and they are in the wrap around camo. So i will be keen to see a grey one.
