Greg
CMK, I have a request if you remember. Could you show how you mask those installed landing gear (and wheel wells) when it's time to paint the wings?
Wings installed.
The visible line down the center fuselage is filled with superglue and sanded. The wing/fuselage joints are gaps that will have to be addressed.
I fixed the gaps in the ailerons by drilling the locating holes larger, so I could "push" them closer to the wings.
I added the tail section, but forgot to take a photo of it assembled
Greg: I'm sorry that I didn't take photos of masking the landing gear--or any of the masking. I didn't think it would be of interest.
I can describe what I did, if it'll help.
I started out by putting masking tape sticky side outward, inside and all around the perimeter of the landing gear well. Then I stuffed the wheel well with wet table napkins.
I let the napkins dry out for a day, since tape is notorious for not sticking to wet things.
Then I went back and wrapped masking tape around the gear, sticky side inward--but inside the first application of masking tape, to cover it up to, over and around the wheels. Sort of like wrapping a mummy.
When I painted the undersides, I kept the airbrush at a low angle, so as not to direct the spray too far up the gear legs or into the wheel wells. Since there isn't much for tape to hold onto around the inside perimeter of the well, some of the tape did pull loose, and shooting at a low angle prevented much (if any) paint from sneaking inside. At least, I couldn't spot any overspray.
I did have to go back and touch up the inside perimeter of the landing gear wells with black acrylic paint, with a brush. I used Colourcoats black for the underside, but the acrylic black blended in fine, since there doesn't seem to be much difference between black paints.
I had to make my own masks by enlarging the painting diagram that came with the kit. Couldn't find any after-market, pre-cut masks.
The type of masking tape I used was "Duck" brand from Walmart. Seems to have a fairly low tack.
I did finish the painting and applying a gloss coat with Humbrol gloss, but then I had to leave on vacation, and the Hampden is sitting at home waiting for me to return to it.
Again, I'm sorry now I didn't take photos, but I hope the description was somewhat helpful.
