RAF 100th Anniversay GB
    April 2005
Posted by taxtp on Friday, November 17, 2017 10:00 PM
Like the SE5a Scott, and that's a great choice of markings. It's come up well. Cheers Tony
I'm just taking it one GB at a time.
    April 2006
Posted by jgeratic on Friday, November 17, 2017 10:53 PM
Scott, looks like a fine good build from here.  Yes
Hope I can get that Camel of mine started soon to join your SE5.
regards,
Jack
    December 2003
Posted by scottrc on Sunday, November 19, 2017 8:26 AM
Thanks everyone for the fine coments.  I was happy to be able to use the Aussie markings.  The roo gives it character.
Jack, hope to see that camel soon!
Bish, a story behind me putting on the decals, I was watching the "Good Neighbors, aka "Good Life" on Youtube and could not stop giggling while postioning the decals.  British humor that was worth acquiring.Big Smile
Posted by Bish on Monday, November 20, 2017 1:56 AM
scottrc
Now thats a blast from the past. Thats comes from the days of the proper British sit coms. My taste in humour has grown slightly darker and more sarcatic sincei used to watch those, but satill classic stuff.
    January 2017
Posted by mawright20 on Monday, November 20, 2017 8:39 AM
Question for anyone with the experience using Humbrol paints.  This is the first kit I’ve built using Humbrol products. It seems like it’s thicker than MM paints for brush use, as well as I’ve been unable to thin it out well enough to use in my Iwata CN airbrush. The other MAJOR problem I’m having is that the paint isn’t sticking well and often coming off under the tape. I did normal prep: wash, dry, prime witjh MM grey primer, etc. I ended up free-hand painting it with a brush. Any thoughts or advice are appreciated.   Mike
No automatic alt text available.
Image may contain: shoes
Image may contain: airplane
    December 2003
Posted by scottrc on Monday, November 20, 2017 1:16 PM
Is your primer peeling as it looks in the picture?  Is is also an acrylic?  You washed the parts, did you use a dish deteregent known to remove greese in order to pull off the mold release oils off the plastic?
When using acrylics, some of us have learned to give the model a topcoat of clear to help with reducing the risk of the tape pulling off the paint.
To thin thick acrylics for the airbrush, I have been using a saline/distilled water mix. About 70/30.
    January 2017
Posted by mawright20 on Monday, November 20, 2017 2:35 PM
Yeah, the primer peeled off too. I used whatever dish soap My wife had in the kitchen, haven’t had this problem in a hole. When do you use a clear coat? Prior to priming, or after painting base layers of paint? I usually use a gloss coat prior to decals followed by a flat coat to finish.
Posted by Bish on Monday, November 20, 2017 2:57 PM
I used to use Humbrol all the time and now use Xtracolour, which are apparently made in the same factory. never seen anything like this, and i only recently started useing primer and never wash my parts. I would guess there was either something wrong with the primer or siomthign really nasty on the plastic.
    December 2003
Posted by scottrc on Monday, November 20, 2017 3:20 PM
I noticed that was the old Monogram kit.  I recall I did not prime it, just sprayed my top colors right on the plastic and also could not get paint to sitck to it.  In fact, my paint crazed when I applied my clearcoat.  I stripped it and then appllied a coat of Rustoleum primer and my acylics seemed to worked after that.
Sounds like you have the right idea on clear coating.  I usually apply it before any masking is required.
Posted by Gamera on Monday, November 20, 2017 4:24 PM
Oh wow, I've had chipping and peeling before but nothing to that extent. Good luck with dealing with it. Sorry, I don't think I have anything to add to what the guys already pointing out though.
    June 2008
Posted by lewbud on Monday, November 20, 2017 8:01 PM
Scott,
That kit may have been a sow's ear, but you definitely made a silk purse out of it.
Got back to the bench last night.  Canopy is on the Tempest, landing gear is attached, and all that's left is to attach the landing gear doors and she'll be done. Pics soon.
Buddy- Those who say there are no stupid questions have never worked in customer service.
    January 2017
Posted by mawright20 on Tuesday, November 21, 2017 1:52 AM
Stuff happens. I’m already working on the next set...one of Airfix’s two plane set of RAF Defiant and Donier 17. Starting with the D17
    January 2016
Posted by iSteve on Wednesday, November 22, 2017 2:18 PM
By the way Bish, what's with the little happy crab on the badges?
Posted by Bish on Wednesday, November 22, 2017 2:21 PM
iSteve
The knickname for RAF personel is Crabs and the RAF is known as Crab Air. Just a bt of inter service banter Big Smile
    June 2008
Posted by lewbud on Friday, November 24, 2017 12:11 AM
mawright,
You might try wiping it down with rubbing alcohol before painting. It gets rid of the oils leftover from handling the model during construction. Also helps by picking up any sanding residue you might have missed.
Bish,
I'm sticking a fork in the Tempest and calling it done.  Finished her up yesterday after a double feature of Zulu, followed by Zulu Dawn.  Here are the pics.
For the front page, I like the third pic best. I've got a couple of other builds to knock out, but I'll be back.
Posted by Bish on Friday, November 24, 2017 2:06 AM
Nicely fin9ished lewbud, really like the look of that. Great job on the scheme and i like the look of the invasion strips.
Will update front page as requested.
Can't beat a good Zulu double bill, but i always watch them the other way round.
    January 2017
Posted by mawright20 on Friday, November 24, 2017 5:39 AM
Lewbud, thanks for the advice. I’ll put it to use. Great job on the Tempest, awesome invasion stripes.
Posted by Gamera on Friday, November 24, 2017 7:45 AM
That's some sharp work LB, and yeah the invasion stripes came out great.
    April 2006
Posted by jgeratic on Friday, November 24, 2017 9:43 AM
Helllo lewbud, very nice build of the Tempest.  Yes
I like the yellow nose, not too often you see that.
regards,
Jack
    June 2008
Posted by lewbud on Saturday, November 25, 2017 2:18 AM
Thanks for the comments gents.
Jack,
The yellow spinner was one of the reasons I chose it, adds a bit of color.  Had the kit decals been usable, one of the options was a red spinnered a/c with a big Free French cross on the nose.
    July 2004
Posted by stikpusher on Sunday, November 26, 2017 11:13 AM
Wow! What a great GB and thread! I don’t know how I missed this earlier.... But there sure does appear to be a shortage of early jets here...
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by Bish on Sunday, November 26, 2017 11:25 AM
Well, glad you found it now Stik, and there sure does. If you want to help plug the gap between WW2 and modern subjects, please feel free.
    July 2004
Posted by stikpusher on Sunday, November 26, 2017 5:28 PM
Bish, i sure am thinking of jumping in with something appropriate. It would probably be after Christmas at the soonest when I can start. I’m thinking either a DeHavilland Vampire F.1 or Hawker Hunter F.6. Both are 1/48, of course...
       - Plankton
LSM
Posted by Bish on Monday, November 27, 2017 3:01 AM
Will be great to have you on board. I have been thinking that 2 aircraft this GB could really do with are a Hunter and a Lightning. So it would be great to get at least one of them.
    July 2004
Posted by stikpusher on Monday, November 27, 2017 11:26 AM
Bish
Well if that is the case, I still need to find at least a bang seat for my Academy Hunter. The kit seat is undersized. The Airfix Lightning in my stash is the late version. For some reason I’m all into early jets right now in my head.
       - Plankton
LSM
Posted by Bish on Monday, November 27, 2017 2:19 PM
Sounds good to me. Hopfully someone wil jump in with the Lightning.
    April 2005
Posted by taxtp on Monday, November 27, 2017 6:42 PM
Really nice work on the Tempest Lewbud. It's an aircraft that I like a lot. Cheers Tony
    June 2010
Posted by rocker286 on Tuesday, November 28, 2017 9:21 PM
Scott - Awesome job on that SE5!
Lewbud - That Tempest looks fantastic - and you've got great taste in films!
I had a few days off after Thanksgiving to work on my Defiant. The masking kit I ordered arrived in the mail, and I've since primed and painted the model. Rather than use black paint out of a jar, I opted for the cheap alternative. I grabbed a can of testors flat black spray paint and went to town. My Defiant is all one color, so I figured why not use a rattle can?
Things went great until I got a finger print on one of the wings. I ended up taking thinner to the WHOLE wing and started over from scratch.Super Angry
I've since attached the prop, antennas, landing gear, and exhaust tubes. I'll be ready to give this thing a clear coat tomorrow night. The exhaust tubes were painted with testors rust, and then dry brushed with flat black.
20171126_201342
2017-11-28_09-17-45
4badges
    April 2005
Posted by taxtp on Tuesday, November 28, 2017 11:19 PM
Nice progress Rocker, you can't tell from your photo so well done. Cheers Tony
Posted by Bish on Wednesday, November 29, 2017 1:45 AM
That looks nice with the paint on rocker.
