SCOTTRC, this will be the first time I use them so I defer to MODELCRAZY for his take on the Lifecolor paints.
As promised, here are some photos of my WIP....
Check out the anchor chain area with the model chain removed and holes drilled and shaped for the replacement chain.
I also finished the Type-89 127mm 40cal Guns. I'm not too sure of their accuracy. I may look at getting some after-market replacements.
While working on the gun systems, I began working on the 15.5 cm turrets. They are the ones that are mounted just behind the fore and aft main guns. The first thing I had to do was remove the molded in details and clean up the seams or mold inconsistencies. Next was removing the plastic barrels and replacing them with turned brass. The kit did not supply any blast bags so I will have to make them, but there is still plenty of PE detail to be added as well.
And as previously discussed about the rear scallops, here is a photo of them assembled to the hull and the PE stairs replacing the molded in junk. I also discussed in an earlier message that this is the area I am going to add the bracing after the main deck is attached to the hull.
A couple posts ago I showed the errors with the walkway around the front of the funnel. My solution was to attempt to cut the over scaled PE so it would conform to the plastic walkway while simultaneously closing the large gaps left with only the kits plastic part. After many little measurements, some trimming and cutting of both the PE and the kits search light platforms (for the width of the PE) I was finally satisfied with the results, here it is:
During my research I talked about the various access doors that are missing on the kit but shown in the 3D research data. I decided to add several of them to the lower superstructure:
The front structure that stored the paravanes is fully enclosed on the kit. Luckily, the Lions Roar PE has numerous pieces that needed very little shaping and filled the area well:
Lets talk about the forward Fire Control and main radar builds. I have three options for the radar arrays; the kit part, and two PE configurations. You already saw that I removed the kit arrays in an earlier photo. The first PE array is a simple five fold into a boxed array:
The next is a multi-piece affair that requires four folds and 8 PE parts. This leads to an open area to the front of the array box:
Here they are all together, .....I chose the five folded box array (the ones on top):
The PE and instructions provide much more detail to the fire control and radar area then anything available in the kit, here are the PE instructions:
And here is the assembled results:
As you can tell, there are still some antenna lengths not on yet assembled on the kit (both array and superstructure). I am going to wait until the model is assembled to add those small or very delicate antenna masts to avoid breaking, bending, or loosing them to oblivion.
Being the busy man that I was yesterday, I also worked on correcting the rear fire control towers details. Those corrections included drilling four portals, adding some access doors and hatches (all PE), fixing the central walkway that attached the tower to the main superstructure as the kit had a 1/16+ gap between them, and adding other details from scratch, here is the completed work. I still need to add details to the range finder area and numerous handrails.
Here it is sitting on the deck; you can see where the walkway attaches:
And now, one of my favorite parts of the build, the countless numbers of small guns assembled from multiple parts of PE (not really my favorite). In the Lions Roar instructions they want you to fold PE parts flat together to make the proper width for the guns. The problem is the barrels are very difficult to align and even harder to pass through the small holes of another PE part (check out the instructions for the Type-96 25mm Triple Machine Guns):
After several unsuccessful attempts to fold the barrels and have them go through the second PE part, I decided on another option. I am going to use the kits part for the barrels and mount them on the remaining two PE assemblies:
After some careful trimming of the kits plastic to accommodate the PE, I them folded and assembled them into one triple gun assembly complete with seats, cranks, wheels, and gun sights:
Now I only have to do that 15 more times
I think I kind of have you up to speed with my progress, so until bedtime,.... build something! Also comments are not only welcome but encouraged.
Ben
