The X-Files Group Build
    November 2003
Posted by bobbaily on Sunday, June 16, 2024 5:03 PM
John-nice build!
Been fighting the time out messages like everyone else and hesitant to try to post pics-however, I have massaged the ductwork in the Aerotech to a level I can live with, repainted and put decals on today.
Decaling could have been much worse but still had some of the longer pin stripe sections 'come apart'-able to recover, again to my standards-not perfect but I'm good with it.  This kit is origin 1989-I tested on a section that would not be used and it worked-again, only problem was the longer pinstripe sections. The adhesive was interesting-I gave the decals a 'double dip' and unidentified film came off on the second dip but no harm.  Some of the decals gave off a 'discolored' water upon application-dunno if previous owner coated the decals before selling (kit was from the Kitlinx Collections section-fair price so no complaints).
Added Solveset and will do a light cleanup before applying Tamiya coat.
Any way, were are the pre- and post decaling:
Hopefully get this one finished before the end of the month.....
Bob
Posted by jeaton01 on Sunday, June 16, 2024 5:26 PM
Looking good, Bob.  Old decals are not fun to work with.
John
    November 2003
Posted by bobbaily on Sunday, June 16, 2024 6:15 PM
Thank you John.  I did scan a copy in case it was a total disaster-fortunatly it wasn't-I'm not ready to learn the fine art of making decals....
Bob
GAF
    June 2012
Posted by GAF on Sunday, June 16, 2024 9:17 PM
That looks great, Bob!  I haven't been too active on here for the same reason.
Gary
Posted by Gamera on Monday, June 17, 2024 6:41 PM
Bob: She's lookin' good! And yeah, I too hate dealing with old decals.
GAF
    June 2012
Posted by GAF on Friday, June 21, 2024 6:00 PM
Nakajima G8N1 Renzan ("Rita")
The Nakajima G8N Renzan ("Mountain Range") was a four-engined long-range bomber designed for use by the Imperial Japanese Navy. The Navy designation was "Type 18 land-based attack aircraft"; the Allied code name was "Rita".
In February 1943 the Imperial Navy staff asked Nakajima Aircraft Company to design a four-engined bomber, capable of meeting an earlier specification set for a long-range land-based attack plane. The final specification, issued on 14 September 1943, called for a plane with a maximum speed of 320 knots (590 km/h; 370 mph) able to carry a 4,000 kg (8,800 lb) bomb-load 2,000 nmi (3,700 km; 2,300 mi) or a reduced bomb-load 4,000 nmi (7,400 km; 4,600 mi).
Nakajima's design featured a mid-mounted wing of small area and high aspect ratio, a tricycle landing gear and a large single-fin rudder. Power came from four 2,000 hp Nakajima NK9K-L "Homare" 24 radial engines with Hitachi 92 turbosuperchargers driving four-bladed propellers. The engines were cooled by counter-rotating fans positioned just inside the engine cowlings. Defensive armament included power-operated nose, dorsal, ventral and tail turrets along with two free-swiveling machine guns at the beam positions.
The initial prototype was completed in October 1944 and delivered to the Navy for testing in January 1945, a year after the Navy ordered development to start. Three further examples were completed by June 1945, with the third prototype being destroyed on the ground by US carrier aircraft.
Other than minor problems with the turbosuperchargers, the Renzan performed satisfactorily and the Navy hoped to have a total of 16 prototypes and 48 production-version G8N1s assembled by September 1945. But the worsening war situation and a critical shortage of light aluminium alloys led to the project's cancellation in June.
One proposed variant was the G8N2 Renzan-Kai Model 22, powered by four 2,200 hp Mitsubishi MK9A radial engines and modified to accept attachment of the air-launched Ohka Type 33 Special Attack Bomber.
Just before Japan's surrender in August 1945 consideration was also briefly given to producing an all-steel version of the aircraft, to be designated G8N3 Renzan-Kai Model 23, but the cessation of hostilities precluded any further development.
After the war, one prototype was taken to the United States and scrapped after testing. None are in existence today.
    November 2003
Posted by bobbaily on Sunday, June 23, 2024 5:32 PM
Gary-another interesting subject-looking forward to your build (noticed it on the Japanese GB also).
Oldsmobile Aerotech is done.  Could use some more 'Fit & Finish' work but this is a kit that would be best build and then doing the body paint work.  I will probably end up gluing the rear body work (leaving the hood scoop unglued so the engine could be viewed) but I fought with body alighment issues but afraid damaging the paint work.
Body fit issues-nothing a little CA won't cure Confused
All in all, a great subject of an automaker with a rich history (Oldsmobile) in an attempt to change their image to focus on their engineering history.  Kit has a great deal of engine detail & options, suspension detail is ok and body fit has room for improvement but it is an old kit.  Decals went on with little issue but left a film that showed up when the gloss coat was sprayed-decided I could live with it.
Thanks all for all of your encouragement during this build and to you Gary for running this GB and posting subject information.
I have another one in the stash so if there's a v2.0 X-Files, I'll build the long tail version.
Having said that, I would like to submit the following kit for v1.0 X-Files
This is the 1/48 version-just need to find some picks so I can paint it orange....
Cheers
Bob
Posted by Gamera on Monday, June 24, 2024 7:36 PM
She looks great to me Bob! I can't do gloss finishes to save my life so I'm always in awe of a good smooth gloss paint job!
GAF
    June 2012
Posted by GAF on Monday, June 24, 2024 10:00 PM
Bob> That turned out great!  Sorry for the troubles, but even so you made a nice model.  Gloss finishes are hard to do!
I'll get you up on the front page along with the Shinden.  And thank you!
Gary
Posted by jeaton01 on Monday, June 24, 2024 10:11 PM
The Aerotech looks mighty fine, Bob!
John
GAF
    June 2012
Posted by GAF on Monday, June 24, 2024 10:14 PM
Guess I better post this here, thought I've already posted it in the Japanese XIII GB. A G8N1 Rita four engine bomber.  I managed to find a copy in my local antique mall where I've picked up a few models before.  The original run on this model was 1967, though the version I have is 1991. It seems to be in good shape, though I'm wary about the decals.
The G8N1 was a prototype, four engined bomber produced towards the end of the war, but was canceled due to lack of materials.
Not sure what version I'm going to do yet: Orange prototype, operational bomber, or American captured version.
Gary
    November 2003
Posted by bobbaily on Tuesday, June 25, 2024 2:10 PM
Gamera, Gary & John-again, thank you & for the encouragement along the way.
Bob
GAF
    June 2012
Posted by GAF on Tuesday, July 2, 2024 9:28 AM
Starting work on the Rita.  Like many of Hasegawa's kits (though not all), this one appears to fit rather well.  At least the main parts.
I've started the cockpit.  It's pretty bare-bones, and only three pilot figures to liven it up.  I have no pictures of the interior, so I'll base it off a Betty and try to add a few things.
Also, there's an unusual raised ridge along the fuselage where the two halves meet.  It's not a mismatch, but as if the edges were raised.  I'll sand it off, but it's a bit unusual so I thought I would mention it.
Gary
GAF
    June 2012
Posted by GAF on Thursday, July 4, 2024 10:51 AM
Gamera,
Thought you might enjoy this video about the FV4005.  Big Smile
https://www.youtube.com/watch?v=EHEvEr_aEeA
Gary
Posted by Gamera on Friday, July 5, 2024 9:03 PM
Oh cool!!!
The Tank Museum at Bovington posted a video about the vehicle I watched just today!
https://www.youtube.com/watch?v=GINmlDX401Q
I need to finish mine, just need to get the tracks on and a little detail work. But it's so friggin' hot now I don't want to work on anything. Just come home from work and collapse in the A/C... Devil
