Hi all, I'm back again.
John, we're sorry that you won't be participating anymore, but enjoy your other builds.
I've started rigging the control lines to the tail and the tail itself (which is now installed). There are two control horns, one on each side, just behind the cockpit. The control lines need to go from there to the control horns on the tail, and they cross so that the lower end of the cockpit control horn attaches to the upper elevator control horn.
Taking a cue from a Scale Models magazine build-up of this kit, I used a staple that I closed (stapled without paper being in the stapler) as the raw material for an eye bolt. I clipped the ends off the closed staple, drilled small holes on each side of the fuselage partway between the control horn and the tail, and glued the eye bolts in.
I'm using very thin, silver-colored wire (that I salvaged from a pull-clain switch) to rig the control lines and smoke-colored invisible thread for the standing rigging. So I thread the wire through the eyebolt, and then carefully, and patiently superglue the ends to the appropriate control horns.
It's a lot of work, but the results look pretty good.
Regards,
