Well, my roommate crashed out early, so I didn't get a chance to use his digicam to take some pics of my KW. At this point, I'm adding the verticals for the skids using brass rod. Getting them all to line up correctly is a pain in the butt. Lots of test fitting, sanding, reshaping, etc on the crosstubes to make them sit right.
Other than that, the airframe is basically done. One Issue I did come in contact with is the fit of the windscreen. On my kit it was VERY tight, which is great. Problem is, if you're using the Cutting Edge update set, you need to cut a notch 1/4" wide by 1/8" deep in the overhead portion of the windscreen part in order to make it fit properly between the overhead control panel and the new cowl. Once I did that, the test fitting was flawless.
I'm in the process of putting all the extra junk into the cockpit. The pics I have of this particular bird show two M-4 Carbines with M68 sights attached to the dashboard with velcro straps. Between the coaming and the windscreen are spare 30 round magazines and OH-58D Operator checklists. So, I've taken two M-16A2 carbines from my AR-15/M-16 weapons set and have suitably modified them (with the exception of the notched barrel, but at that scale, who's gonna see it?!) with collapsed stocks and the proper optics. They're ready to install now. Extra magazines are simple, since the weapons set has six of them. The operator manual was made by laminating two thin pieces of sheet styrene together, cutting to fit, and painting the covers emerald green. I figured I may try to put the proper titling on the front cover, but that's gonna take a lot of patience, a magnifying glass and a really sharp xacto blade!
I think I may order the Legends Helo crew, even though they're wearing SPH-4B helmets and not HGU-56s. I'll see what I can do to modify them.
Another word of caution if you're building this kit. Make sure you know exactly which bird you're building! I don't think I've seen two identical birds yet. I finally settled on one from the 1-4 Cav, 1st ID in OIF II, which I had the most detailed shots of. The Cutting Edge update gives you great antennae and doodads, but even that isn't complete. For the bird I'm modeling, I had to scratchbuild a new SATCOM antenna for it.
Overall, its a great kit, and the CE update allows you to make a really nice OIF OH-58D. Lookin forward to painting and decaling this baby so she can sit on the shelf next to her bigger attack brothers!
