QUOTE: Originally posted by nathaniel
@Zen_Builder - I did end up finding a local source. I made sure I found the grind of mica powder that can go through an airbrush-- as I don't really fancy getting clogs. I should have no problem producing the bright red candy for Lunamaria Hawke's Zaku Gunner Warrior. I also found a local source of Createx liquid pure pigments so I can make any transparent colour I want (or I guess any opaque colour if I were to pick up an opaque medium).
Great stuff. Those powders come in very handy.
One word of warning though:
A little goes a long way, use too much and the you will see more pearl/mica than actual paint.
Actually from the pearls I moved onto glazes and have found that for some kits I exclusively use clear colors, pearl powder and glazes.
Back to the GB:
Started to assemble the Nataku(major sections), once those are done it is cleanup and putty time. Will do the dragon hangs last as they require a LOT of sanding and puttying between each assembly.
If all goes well I should finishe the build this year, as I got a few other projects on the burner too.
1/72 Battroid Valkyrie Minmay Guard
1/35 Batmobiles x 3(2 Tumblers and 1 Batman Returns Batmobile)
1/48 Porco Rosso plane
1/24 Mini 1275S Mk1+ acesories
