South Pacific Group Build 7 August 2006 to 7 August 2007
    September 2006
Posted by NucMedTech on Friday, October 27, 2006 7:43 PM
Well, I started on the P-61. Soon after my xacto knife slipped and cut my finger. Nothing serious just a little cut, but a bad start on a new project. Hopefully this is not a portent of things to come. So I figure I'll stop get some rest and pick it back up tomorrow.
Most barriers to your successes are man made. And most often you are the man who made them. -Frank Tyger
    August 2013
Posted by JerrynFrog on Friday, October 27, 2006 10:22 AM
I did go over the technique on filling without sanding, using putty, fingernail polish remover, and so on. Your directions were great to get there.
What I didn't explain very well....is... I think there should be a 'line' or 'seam' where the fuse meets the wing root as the kit is designed.....a thin line, not a huge gap as I had......I would fill using the above technique, then upon completion, try to scribe a fine line in the middle of the filled seam....kinda hard to explain.
But.......the gap is now not so bad.......while working on the lower area in front of the wing, sanding and so on, to improve the fit, I noticed the wing root gap was opening and closing and I realized that I did a poor job of attaching the wing assy. So, I added a little solvent cement and closed up the gap some, and it made a big improvement. The dihedral increased slightly, and I think it looks better, more accurate.
Still, after I sand off the crazed paint and look closely at the gap, I am sure I will be doing some filling, using the technique you suggested.
Frog flies.........................Jerry repairs
    July 2004
Posted by mucker on Thursday, October 26, 2006 8:16 AM
I tried to find the "link", but they have it protected. What I am referring to is the technique with squadron putty, nail polish remover and Q-tips. If you tape off the area around the seam, you shouldn't have any issues.
Another thing I've found is that in larger gaps, such as a wing-root, usually 2 - 3 application of putty are needed to offset any shrinkage from prior applications. The nice things is no sanding is required so you don't screw up existing lines.
Oh yeah, and great looking airplane so far. I look forward to more pictures of the progress.
    August 2013
Posted by JerrynFrog on Thursday, October 26, 2006 7:04 AM
Mucker, Thanks for the tip. I had never visited that site before and it looks to be a very good one. Many tips and techniques to explore........forums.......group builds....lotsa good stuff.
I am going to try the technique you suggested and maybe try to rescribe the panel line where the wing and fuse join. It looks to be quite do-able to me.
    July 2004
Posted by mucker on Wednesday, October 25, 2006 5:52 PM
Here's a little tip for fixing those pesky gaps that I picked up from another modeler. You can also check it out at the Aircraft Resource Center under "Tools and Tips". You will find an article under the tab for "Filling" by Steve Bamford for filling gaps without sanding. It is very simple and easy to get good results. It is copyrighted, so there is no direct link.
    August 2013
Posted by JerrynFrog on Wednesday, October 25, 2006 4:55 PM
Howdy Everyone.  I have a little progress to report. I've spent a fair amount of time on my plane, but just seem to accomplish little.  I re-did the silver pencil and future 'dots' on the instrument panel about 4 times and finally got a sort- of acceptable panel and after installation, the gauges hardly show up. Big Smile [:D]
The cockpit is in place and I am happy with it, considering it is my first one.  I made seatbelts out of masking tape, a techinque that was discussed in these forums.
The wing assy is installed, but I have a large gap in the lower-front to deal with..so will be sanding and puttying for awhile.
A question for you guys............There is a rather large gap at the front of the wing root (The rear area is fine). Any ideas how to fix this??  I believe it should be a panel line. I think in hindsight, I should have built up the area with some thin styrene strip and sand it down to reduce the gap prior to installation. Anyway, I may just leave it, but....any ideas how to correct it??
Here is a progess pic.....the interior green enamel was in my airbrush when I was looking at my seam filling job and I decided to shoot the top areas as an undercoat for the Tamiya acrylic brown to come later.
I'm really enjoying this group build...........is much fun to be building with others.
    November 2003
Posted by JoeRugby on Wednesday, October 25, 2006 1:04 PM
Wulf
Welcome!
To all other participants...do not worry on changing builds, just remember to stay within the confines of the build requirements.
The Jug is done...all fiddly bits attached etc.  Now one problem...I have misplaced my camera.  I was out spotting deer for the coming hunting season and can not find it.  I do know I did not leave it in the woods, so I have to tear into my jeep and look through the mess...
My next build will be the Dinah recon plane.  I have the old LS kit, not a bad little deal that one...
Check out the WW I Special Interest Group @ http://swannysmodels.com/yabb/YaBB.pl?board=WW1SIG
Posted by espins1 on Thursday, October 19, 2006 12:28 PM
I'm getting ready to start on my P-38F for this build.  The parts have been washed, all my reference material is in my backpack with me at the office to review on my lunch Wink [;)].  I'm in the final stretch with my Spitfire for the Battle of Britain GB then this build will be one of two main projects I'll be working on for the next month (along with the Axis Aces GB).
Scott Espin - IPMS Reno High Rollers  Geeked My Reviews
    February 2006
Posted by Wulf on Thursday, October 19, 2006 12:09 PM
I am in the middle of a B-25 Air Apache. I'd like to join. It's an Accurate Min. 1:48 "Red Wrath".
Thanks,
Andy
Posted by Anonymous on Tuesday, October 17, 2006 1:41 AM
Im almost finished, but it has been at this stage for some time.  I need to get it finished up so I can focus on my other hobby, medieval recreation and our event is coming up in Febuary.  I need to make 6 Tudor/Elizabethan outfits by then, which is alot of work but I should have them done on time.
    October 2005
Posted by gulfstreamV on Tuesday, October 17, 2006 12:32 AM
 JoeRugby wrote:
How is the progress on everyone's build?  I have hit a bit of a block...just the fiddly bits to finish now....I will hold off until I complete some of the other builds I have going...please post your progress though!
Sorry Joe for slackin' on this one, Been busy with the work. Hey, I might change my original aircraft idea to somethin' else. Hope thats OK. Will (tryBlack Eye [B)]) to post WIP pics soon. Thanks for hosting this, and your build looks great. Join the Santa GB and maybe he will bring you a 1/48......Smile [:)] Just kidding bro.  you got skillsCool [8D]
Stay XX Thirsty, My Fellow Modelers.
    September 2006
Posted by NucMedTech on Monday, October 16, 2006 12:07 PM
I'm still in the process of gathering am parts (mostly getting the money for it). Trying to find a place for one stop shopping to limit S&H.
    November 2003
Posted by bobbaily on Monday, October 16, 2006 9:26 AM
Progress update...or lack there of....I have gathered all the components except the decals for my Hasegawa P-38.  I'm stuck (lack of motivation) on my CBI group build with this one and the Axis Aces GBs awaiting in the wings.  Hope to get my mojo back soon.  Might even switch subjects if I can come across something less challenging than the P-38.  Maybe.
Bob
    November 2003
Posted by JoeRugby on Monday, October 16, 2006 9:09 AM
    September 2006
Posted by NucMedTech on Thursday, October 12, 2006 12:53 PM
Cool, I'll take a look at twobobs and see what they have. Discovered that pms also go to my e-mail, guess I'll have to check it more often as I had another pm their that I didn't know about. I'll pm you in regards to your previous one.
    July 2004
Posted by mucker on Thursday, October 12, 2006 12:46 PM
 NucMedTech wrote:
Mucker, looked at the site you provided and it has alot of good decals. So far I only found one for the P-61 so I'll keep looking.
No, I'm here in Texas.Which means I have to pay sales tax and then S&H from squadron. Don't you think shipping is high if all your buying is a photo-etch set or two? I shop at plastic-models.com mostly and they have shipping prices at 3.99 on alot of their items. Of course they don't carry special items like resin  kits or pe stuff but for basic kits and supplies they have a good selection.
P.S. I'm kind of new to the forum, How do I look at the pm you sent?
Definately...I try to bundle a few things together to justofy the S&H charges. $7 to ship PE and Decals is expensive. For decals only, there is a site with free shipping: www.twobobs.net ("Bobs" with only 1 "o")Smile [:)] They have more jet aircraft, and I am a WWII junkie, but every once in a while they have what I need.
For the PM, click on the link "Modelling Subjects" directly above the forums. From there I believe you can access Private Messages.
    September 2006
Posted by NucMedTech on Thursday, October 12, 2006 12:39 PM
    July 2004
Posted by mucker on Wednesday, October 11, 2006 10:01 PM
NucMedTech: PM sent regarding P&W R-2800 engines.
    July 2004
Posted by mucker on Wednesday, October 11, 2006 7:27 PM
You can buy Pyn-Up at various sites (Greatmodels, etc.), but www.meteorprod.com usually has the best range. I haven't checked out which squadrons the P-61 sheets are for, but I hope they have what you're looking for.
I envy you...a B-29 done in metal foil or a nice BMF finish looks awesome on display.
If Squadron shipping is high, my guess is you live outside of the States...where are you located?
    September 2006
Posted by NucMedTech on Wednesday, October 11, 2006 4:01 PM
No I have not seen this line of decals. I am unable to find anything for the P-61 or the unit I'm looking for, the 419th NFS. If they have a web site or you know where it is that I can look at them I would appreciate your help. Right now the best that I can find for AM parts is Squadron, but their shipping is high plus I would have to pay taxes.
I'll take a look at Swanny's sight for re-scribing. BTW I've got the B-29 sitting on my shelf waiting to be built. It is a huge model, I need to get a little better at my natural metal finishes before I decide to take that one on.
    July 2004
Posted by mucker on Wednesday, October 11, 2006 2:28 PM
NucMedTech: Have you seen the Pyn-Up line of decals? I'm partial to "Cooper's Snooper", but there some other cool ones there too.
I'd like to "learn" how to re-scribe, too. Swanny's site is pretty good, but practice makes perfect I suppose. If I ever got good, I'd love to re-scribe a B-24 of B-29 and do it up nicely with AM parts.
    September 2006
Posted by NucMedTech on Wednesday, October 11, 2006 12:49 PM
First apologies, I thought  I had the last post on that page so I did not see legends and your posts. Did not mean to ignore what you both said.
I myself don't mind raised panel lines, but one day I'm going to try rescribing just to see if I can. Zipmeister if you can find a cheap kit I recommend picking one up. This will be my second time building it (first time I was just beginning) Hope to do a better job this time around. Your tip will be very useful as I will most likely kill quite a few panel lines during the build. Thanks again for the info.
    September 2006
Posted by NucMedTech on Tuesday, October 10, 2006 12:36 PM
Most likely I'll use AM decals. Not to fond of the ones in the monogram kit, I would also like to find a P&R 2800 engine and try the Edwards photo etch sets. I think True Details has a wheel set for this plane too. Although this would be a large investment altogether for a $5 kit. But if I can get the money then why not?
Did not know that AM Tech was releasing a new kit. It's about time someone did, I think the P-61 is a nice looking plane. Will it be 1/48 scale or 1/72?
    July 2004
Posted by mucker on Monday, October 9, 2006 1:39 PM
I'm with you. I've "re-scribed" my errors when I sand too much, but never attempted the whole plane. I look forward to your build. I've always liked the Black Widow. By the way, are you going with AM decals?
I'm holding out for the annual anticipated AM Tech release of the "new" P-61...with engraved panel lines.
    September 2006
Posted by NucMedTech on Monday, October 9, 2006 12:24 PM
Thanks for the info mucker.Call me chicken but I just don't think I'm ready to try rescribing a whole plane yet. I'm planning on doing the black scheme and a similar weathering technique that I've tried before. Thanks for your help.
    July 2004
Posted by mucker on Monday, October 9, 2006 12:31 AM
It's your call on the panel lines, but my two cents are this:
If you're going with an all black scheme, the shadows on the raised panel lines provide decent highlighting. Also. there was a technique in Finescale last year about pre-painting the airplane silver (your choice of shade) before painting it black, and then lightly rubbing the top coat (black) off of the raised panel lines. The way the author performed this it looked really nice.
Either way, I'm looking forward to your build.
    May 2006
Posted by zipmeister on Sunday, October 8, 2006 11:23 AM
 NucMedTech wrote:
Great! I can't wait to start. So I'm going to start by asking for opinions. With the age of the kit the panel lines are raised. Should I try rescribing them? I've never done this before. Difficult or hard to do in a somewhat limited time frame?
 I for one will be very interested in this build because every where I go this model is there. I always pick it up and look at it but for some reason I've never bought it. I agree with Legend, it doesn't affect me either way as to whether a model has raised panels or not. I enjoy all models I build. Yes some require more work (modelling) than others but when your finished those are the ones you take more pride in. I've built a lot of Revells in my life and will continue to.I enjoyed every one of them.
As far as scribing panel lines, I was building the Revellogram P-51 and I wanted a bare metal finish (BMF). During sanding of course I sanded some panel lines off. A BMF shows about every foul up. I remember somewhere I read you can duplicate a raised panel effect by scribing with an x-acto knife if you hold it at and angle when you scribe. So I tried it and wow it works. By holding it on an angle it will raise the plastic on one side of the scribe line simulating a raised panel line. I hade to do several of these on the body and both wings. They came out great. You cant't even tell unless you have a magnifying glass. Even then they look great. I wouldn't suggest doing the whole plane like this but when I sand down a raised panel now I'm in no way worried about it.
Thanks
Zip
Posted by Anonymous on Sunday, October 8, 2006 4:23 AM
Personally raised/engraved panel lines doesnt bother me.  Sure Id rather build modern kits with engraved lines, but I dont frett about it.  I know this is heresy to some and others wont build kits without engraved panel lines, Im just neutral.  I have that kit btw and Im going use the ETO markings.
    September 2006
Posted by NucMedTech on Saturday, October 7, 2006 8:27 PM
    November 2003
Posted by JoeRugby on Friday, October 6, 2006 11:09 PM
No way do I mind!  A P61, not something seen every day!  Welcome aboard...I will update the list eventually, but do not let "paper work" get in the way...
