Well, some more progress on the Hellcat. Here it is with a decals on and a light dusting of flat over the Gloss Sea Blue finish to give the weathering that I'm about to start something to hold on to.
This Academy Hellcat is an interesting kit. It's got some shortcomings, but was/is probably the best 1/72 Hellcat available. I've used aftermarket in the pit and for the engine, but you could definitely do something with the kit items if you want to. Unfortunately, they didn't show the same diligence with the wheel wells, which have all the detail of an Airfix or Frog circa 1960 kit. I've bothered to close in the wheel wells, and add some detail, which is not completely accurate, but better than what it was. The trailing edges are clunky too, but that is remedied with a bit of sanding. Amazingly Aires have a detail set for this kit that does over the pit, gun bays and engine but does nothing for the wheel wells, it's major shortcoming. It retails at USD $66+, there is a review here if you're interested : http://www.cybermodeler.com/hobby/details/aires/detail_aires_7035.shtml
The Hasegawa 1/72 Hellcat is an old kit. It does come with some very interesting markings if you get the right boxing. It has some wheel well detail, and once again a little detail in the engine and pit that is at least a starter. The big downer is that it has raised panel lines, so I prefer the Academy one. I've built a couple of these over the years, I used to love this kit before the Academy one was released.
I've had a recent look at the Hobby Boss easy build kit. The wheel wells are better, similar to the Hasegawa kit, the trailing edges are nice and fine. Excellent, sharp engraved panel lines. The cockpit will need to be replaced, or enhanced, which is do-able, but I disliked the simplified molded in engine in the cowling. In my view, a must for replacement. Unfortunately neither the Academy nor Hasegawa cowlings are compatible. I think I have an Italeri bird somewhere in the garage, I must try that. Don't have a Frog, Airfix or Matchbox one anymore. If I can get over the cowling, this might be the best option as a base for another 1/72 Hellcat.
Anyway, without further ado and commotion, here is where it's at tonight, hopefully some more progress tomorrow after I pack the Christmas tree down.
CheersTony
