Thanks everyone for their comments!
Marc, I too really did want to do the squiggly line scheme but after some experimentation did not have the confidence to tackle it. And I was not terribly keen on the idea of stripping an entire model if it had come out the way I thought it probably would (badly). I probably wouldn't use the spaghetti method to enact this scheme on any future build, as I'd much rather eat the spaghetti than paint it , but I have a lot more confidence in my abilities with a brush and Tempera paints than with an airbrush.
John, yes there were major fit problems with the wings on the 88. The wing tips are separate pieces - neither fit snugly and required a fair amount of filler. I used Swanny's method to apply putty to both of these builds - taping off the area to be puttied, applying the putty then removing the tape, which apparently keeps putty from getting into areas where you don't want it, like panel lines, etc. I think I ended up getting the putty on a bit thick and didn't sand it down as much as I should have, so if you really look, you can see where the putty lines are (the pictures don't show this, however ). The wing roots didn't want to go together well either, which caused the dihedral issue. I resolved that by attaching each wing (I used a medium viscosity CA that gave me a little time), eye-balling it head-on, and making minor adjustments while the CA set. I do think that I got the dihedrals pretty close to accurate.
Guy, well I'm not sure what "pair" you're referring to, but I suppose if I was a woman .... oh nevermind! But yes, these were both time consumming efforts to mask. I used the Eduard masks for the canopies and windows, and I've become a believer in these masks. Any time I have a kit with this kind of canopy framing, like the B5N2 Kate, I'll be checking on the availability of masks. Roughly $12 US but that saved me loads of frustration in using my standard 3M blue tape, cutting all those tiny pieces and putting them on. Here it was just a simple process of matching a piece on the mask sheet to a glass panel and putting it on. Done! To do the desert scheme I cut varied shapes in card stock and sprayed through those. I used the 3M blue tape cut to shape to effect the splinter scheme on the 217. Finally I used some Tamiya tape to mask off the ID band on the 88.
- Steven
